Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 01-07-2006, 04:46 PM   #121
Raw Wave
tj!2k4's Avatar
tj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud oftj!2k4 has much to be proud of
what an excellent app! thanks!
Dr. Ron Paul for President 2008
Hope for America - http://www.ronpaul2008.com
Who is Ron Paul? - Why do we need Ron Paul?
CarPC Newbs Start Here: All your questions answered, as if by E.S.P.
tj!2k4 is offline   Reply With Quote
Old 01-07-2006, 04:48 PM   #122
Raw Wave
lostreception's Avatar
lostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud of
chuck the way its written it doesnt even need the restricted area because anything out of the area is masked
i just updated it to
if (_root._xmouse >= 0 && _root._ymouse >= 0)
its not even an issue
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
lostreception is offline   Reply With Quote
Old 01-07-2006, 04:49 PM   #123
lucianop is on a distinguished road
thx, that would be great, so you guess that my problem is related to the color picker ... but have you some idea about the fact that this is true only for me?
about the restricted area, you're right, sorry for that, but I tested this function with older releases ... newest solved this issue ...
anyway, working on my desktop with a mouse, when I reach the edge of the drawing area keeping pressed the mouse left button, and the release it ... on reentering the drawing area the mouse keeps drawing also without pressing any button ...
trying to be more precise:
press left button and move mouse to draw on the drawing area ...
go toward the right edge and sorpass it then release the button ...
reenter the drawing area without any button pressed ...
you see that the mouse starts drawing also without any button pressed ...
lucianop is offline   Reply With Quote
Old 01-07-2006, 04:59 PM   #124
Raw Wave
that is because flash then loses its ability to listen for a mouseup event
you are drawing outside of the field so it doesnt pick up the fact that you have released the mouse bacause it couldnt "hear" it outside of its own window
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
Old 01-07-2006, 05:04 PM   #125
Chuck's Avatar
Chuck is on a distinguished road
Good thx
2001 S10 ZR2
Chucks Skin - to old
Chuck is offline   Reply With Quote
Old 01-07-2006, 05:09 PM   #126
Raw Wave
btw chuck i finished adding the mousedown effect
it was a little more complicated then i thought but i got something that works
i made flash tint the existing jpgs 50% black when hit
i successfully got it to work the other way around with a 2nd jpg file but ther was a moment (quick flash) where the file would reload everytime. it didnt look nice at all. plus imrunning a faster machine then some carputers so if i wont load quick enough on mine it will never work on a 733 or 1 ghz via
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
Old 01-07-2006, 05:26 PM   #127
Chuck's Avatar
Looks real good
i will start on updating now
2001 S10 ZR2
Old 01-07-2006, 05:54 PM   #128
Meelobee's Avatar
Meelobee is on a distinguished road
Quote: Originally Posted by Chuck
meelobee how is this?
Could not send via e-mail - bounce back
If you want to change the buttons change the .jpg file
I am waiting for lostreception to send me a new .fla with button up and down state
wow nice! But I got a problem getting it to work. It works when I open the .swf in a browser, but I can't get it to work embedded in RR.
I extracted draw-skinnable.zip from post 1 to C:\draw. I also extracted meelobeedraw.zip to C:\Draw
In my skin I have this command:
B09,0,460,160,70,"LOAD;scribble.skin;;C:\draw\draw &save.exe;Draw"
It loads the scribble screen, but shows the wrong draw screen. What do I need to change on that command load the new draw skin?
When I just add a 800x530px flasharea to the skin the right half of the draw area isn't working,
[■■■■■■■■■■■■■■■■■■■■] Install 80%
WWW.ZDCLAN.NL
Meelobee is offline   Reply With Quote
Old 01-07-2006, 06:59 PM   #129
Chuck's Avatar
Meelobee Down load your file again I just fixed the .swf file - I think
let me know if it works
2001 S10 ZR2
Old 01-07-2006, 07:12 PM   #130
Meelobee's Avatar
Nope, still the same. Which way should I use it? should embed the draw tool or just add the flashfile in rr?
WWW.ZDCLAN.NL
Old 01-07-2006, 07:26 PM   #131
Chuck's Avatar
2001 S10 ZR2
Old 01-07-2006, 07:37 PM   #132
Meelobee's Avatar
When I do that it's still only working half:
WWW.ZDCLAN.NL
Old 01-07-2006, 07:44 PM   #133
Raw Wave
chuck i sent you a pm but the instructions are incorrect
i misunderstood you at 1st
dont delete the box you need to make it larger you changed the size of the movie but not the hidden fix layer i used to fix the swf embedded problem
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
CarPCNetwork
Old 01-07-2006, 08:51 PM   #134
Meelobee's Avatar
For those intrested; I've attached a jpg of the chalkboard I used in the picture above.
WWW.ZDCLAN.NL
Old 01-07-2006, 09:45 PM   #135
Mattkins99's Avatar
Mattkins99 is on a distinguished road
One usability issue I'm seeing. I'm using the version from post 100... so I think that's the newest. Anyway, everything works great except when I save an image or a few, close road runner (say I shutdown the computer for the night) then next time I start up the app, I'm taken to image 1.
Just based on how any other application acts, I'd expect to be taken to new blank screen. If I then want, I can click on the back buttons to see my old drawings (I'm mainly using this to write down phone numbers and addresses and such) I only want to look back at them when needed.... When I open the program I can see it will eventually get annoying if I have to press through all of my old images just to get to a new image.
Would this be an easy modification?
Matt Atkins
Seattle5s | President
'01 M5 Lemans Blue/two tone black and silver interior
Factory nav.... for now
Old Car (almost sold)
'98 540i-6 blk/blk
Dell 300m | Xenarc 7" | Road Runner | iBusCOMM | NaviVoice | Streets & Trips GPS
Mattkins99 is offline   Reply With Quote
