The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Thread Tools Display Modes
Old 01-12-2006, 12:20 PM   #1
cherrybomb's CarPC Specs
cherrybomb's Avatar
Vehicle: 1999 Ford Explorer
My Photos: (0)
Skin "TIMER" events
I've found the TMR event that you can add to a skin, to execute something xxx seconds after the skin is loaded/run.
It appears as though providing 0 is not acceptable, I have to provide at least 1 second.
Is there any way to execute a command the exact instant I load a particular skin?
Thanks!
'99 Ford Explorer Eddie Bauer
CarPC Progress ~= 97%. Everything is installed, and operational. Still need to tweak and tune, and do some "finish" fabrication.
CarPC Project Web Site
SpaceNavigatorDriver SourceForge Project
Check out my blog.
cherrybomb is offline   Reply With Quote
Sponsored Links
Old 01-12-2006, 04:02 PM   #2
SMKFree
liquid_smoke's Avatar
Vehicle: VW Passat
My Photos: (0)
well that depends, you can execute a command from any button that takes you to another skin by putting the commad after the load xx.skin command. But if you want to say execute a command when the skin first loads i dont know any other way other than w the timer.
beer replenishment fund
mp3car live search
liquid_smoke is offline   Reply With Quote
Old 01-12-2006, 04:41 PM   #3
cherrybomb's Avatar
My Photos: (0)
*nod*
That's pretty much what I thought.
I suppose I could rethink my plans.
What I wanted to do was trigger an event in girder, so that each skin, would have it's own input profile.
Technically, if I'm inputting commands from girder, I could just add that as another action for the same event. But I was worried about cases where girder would send the command to RR, and for whatever reason, it may not actually load the requested skin. Then I'd have my controls setup for a skin I'm not on!
Eep!
Check out my blog.
Old 01-12-2006, 04:49 PM   #4
My Photos: (0)
Do something like this.
In ExecTBL.ini, define a skin-specific command like this.
"DO_THIS", "RR_command_here",audio_player.skin
"DO_THAT", "Another_command_here",video_player.skin
Then have girder execute "DO_THIS" when you push a button. This way, the command only gets carried out when audio_player.skin is active.
You can have the same button trigger "DO_THAT." Depending on which skin is currently active, only one command gets carried out (or none at all if both are not active).
However, this method will get cumbersome and out of hands quickly if you have lots of skin-specific commands.
I humbly suggest guino add support for sending skin-specific commands to RR from girder (or an external app).
Somthing like this would work.
"Next;audio_player.skin"
This way we don't need to define these commands in ExecTBL.ini.
b8bboi is offline   Reply With Quote
Old 01-12-2006, 06:16 PM   #5
cherrybomb's Avatar
My Photos: (0)
Ohhh yeah..
That's much more elegant!
I think I'll give that a try.
Thanks for the pointer. :-D
Check out my blog.
Old 01-14-2006, 09:50 PM   #6
RoadRunner Mastermind
guino's CarPC Specs
guino's Avatar
Vehicle: 04/Mazda/RX-8
My Photos: (5)
the reason why 0 doesn't work is maily because RR will only load a screen when a load command has been issued -- in which case, you could add the command you wish to excute right behind it using the || command separator.
Road Runner,RR's Myspace
guino is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Open Source Skin Editor for RR lbooker Road Runner 66 04-16-2007 01:51 AM
Roadrunner Skinning Tutorial Meelobee RR Skins 14 12-30-2005 07:28 PM
Thoughts on skin design guidelines? Arathranar RR Skins 2 06-13-2005 05:54 PM
Frodoplayer 1.0.9 Skin Released WeeZyFellA FrodoPlayer 43 02-13-2005 10:38 PM
New Skin - Spaced_Out for FrodoPlayer 1.08 WeeZyFellA FrodoPlayer 24 10-17-2004 09:50 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
