Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 03-20-2006, 12:05 AM   #1
DaveB's Avatar
DaveB is on a distinguished road
General question about the RR program logic
I installed the RR skin editor and started playing with it today. I have a question about how the skins relate to the underlying program.
Using the Destinator_gps.skin (part of BMV2) as an example, there is a label called L07 and the code field contains "MM;ETA" This is where the ETA would be displayed in the skin.
Is there logic written into RR that knows what to do with the "MM;ETA" field specifically? In other words, does RR just take whatever fields are defined in the skin and pass data back and forth to the application or does each field identified in the skin require underlying logic to be written into RR to support that skin object?
Let's say a new version of Destinator came out and had an object for displaying a compass heading. Could that field be dropped into a RR skin and function or would the RR application have to be modified to support the new compass object?
I'm trying to get a feel for what a guy can do in skins that doesn't require RR to be modified or enhanced.
8" Lilli TS
MB896F Mini-ITX MB
2GHZ Dothan 533MHz FSB CPU
1GB SDRAM DDR2 533
Seagate 300GB SATA150 HD
ENGENIUS WiFi MINI-PCI CARD 802.11A B 400MW OUT
Pioneer Slot Load SLIM DVDRW
Bluetooth V2 USB 2 Dongle
3COM BKP Cam
DaveB is offline   Reply With Quote
Old 03-20-2006, 12:26 AM   #2
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
there are hard-coded label codes and there are dynamic label codes.. an example of a hardcoded is "DATE" -- directly from RR, independent of anything and was added directly to a list of supported label codes. Dynamic label codes are normally flexible to accept anything you throw at them.. so if MM later releases support for new information, you could start using it right away without any changes in RR .. (like "MM;NEWINFO")... there's also support in RR to allow setting labels from outside applications as well, so anybody that wants can build applications that show information directly in RR's skins (That's what FD does).. I believe there's already a code to pull out the heading from MM -- If not, the GPSXXXX tags from RR will work simply because RR reads the GPS info from MM already...
Ride Runner RR's Myspace
guino is offline   Reply With Quote
my general idea, but one nagging question... miracle idiot Newbie 1 04-08-2004 08:55 AM
General Software and Computer Question Its Lo Software & Software Development 7 04-01-2004 10:35 PM
General question on FLAC -al- Software & Software Development 1 09-19-2003 10:54 AM
general question about inages cooljavy General MP3Car Discussion 3 04-14-2003 04:43 AM
Just a general fun question, mosey on in at your leisure... haax General Hardware Discussion 11 05-03-2000 04:31 AM
