Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 04-01-2006, 03:16 AM   #1
RR Web Cam Skin Help
Hi,
I managed to get "capture!" web cam app integrated to RR BVA2 skin.
when I hit "RIP" button cam app opens up.(This is good)
When hit any of the buttons on the cam skin (top left corner) cam skin exits and RR main skin appears as expected but cam app won't exit, it just goes to background.
How do I get these two buttons "bind" to the app?
Please check the pic for more clarification.
My cam.skin file
MEDIACAR Skin
MEDIACAR "CAMSKIN" Skin
/, C, x, y, w, h
C01,000,090,800,600
/, B, x, y, w, h, Command;COMMANDCODES, Tooltip
B01,700,0,65,85,"Close","Close"
B02,750,0,65,85,"Exit","exit"
/, A, x, y, w, h, color R;RGB, G, B
A01,0,93,800,505
END
babyface is offline   Reply With Quote
Old 04-01-2006, 04:48 AM   #2
Confusion Master
Enforcer's Avatar
hmm close should close the app, but not exit the skin.
exit exits the skin but does not close the app.
that's how they should work. unless RR has not actually embedded the app properly.
what is the command you are using to 'call' the cam skin and !capture app?
you could always put a "CLOSEWINDOW;<windoetitle of app>" as the close button.
Enforcer is offline   Reply With Quote
Old 04-01-2006, 05:22 AM   #3
Hi,
I've put below line in my menu.skin file to call the app.
B02,348,70,104,75,"LOAD;cam.skin;cam;E:\Downoads\o ther Car Apps\Capture\Capture!\Capture!.exe"
I have cam.skin file to call the skin.
Do you mean to put something like this to my cam.skin file?
B01,700,0,65,85,""CLOSEWINDOW;<windoetitle of app>","Close"
Old 04-01-2006, 11:09 AM   #4
Confusion Master
Enforcer's Avatar
Quote: Originally Posted by babyface
Hi,
OK well that line does not have the window title to embed so that is why the app is not closing down.
try adding the window title after a ; at the end, like so (assuming Capture! to be the window title)
B02,348,70,104,75,"LOAD;cam.skin;cam;E:\Downoads\o ther Car Apps\Capture\Capture!\Capture!.exe;Capture!"
No, try (again assuming capture! to be the window title), although you shouldn't need this if doing the avbove works.
B02,750,0,65,85,"CLOSEWINDOW;capture!||Exit","exit "
Old 04-02-2006, 03:23 AM   #5
Fixed
Thanks Enfocer your tip worked!
Step 1
Menu.skin file
Step 2
cam.skin file
MEDIACAR Skin
B01,700,0,65,85,"Close","close"
B02,750,0,90,85,"Exit","exit"
A01,0,93,800,505
/, C, x, y, w, h
C01,000,090,800,505
END
Old 04-02-2006, 08:44 AM   #6
Confusion Master
Enforcer's Avatar
x e lent.
Old 04-03-2006, 08:03 AM   #7
The Vauxhall Vectra Project
ccsnet's Avatar
Now if you could get that screen to come up when reversing the car ( and may be mirror the image too ? ).....
Terran
ccsnet is offline   Reply With Quote
Best RR Skin for BMW dasha877 Road Runner 5 06-27-2006 05:55 PM
pink transparency not working if skin is resized by RR liquid_smoke RR Bug Tracker 3 02-06-2006 12:23 AM
How to show many web page in rr dabper Road Runner 1 01-17-2006 02:32 AM
status update.... 0l33l PowerVoice 17 05-05-2005 12:22 PM
Min Requirements for a web cam edie209 Off Topic 7 05-17-2001 03:50 PM
