Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 04-16-2006, 01:52 PM   #1
NRGZ28's Avatar
Cool RR and built-in GPS
A simple question for everybody.... In order to use RR's tags expressed in skin commands.txt like "GPSSPEED" etc... is destinator or freedrive or anything like that required ? I was under the impression that RR only needs to be told what COM port the GPS sensor was on and that's it. My tags all show zeroes with the GPS sensor connected.
K301 7" Motorized Screen
Mini SLIMPRO SP625 Cappucino PC
RoadRunner / IGuidance 3.0
Pioneer 7700MP HU
MTX 1500D 1500 Watt Sub Amp
2 x 12" MTX 8000 subs
1998 Olds Aurora 4.0 V8
NRGZ28 is offline   Reply With Quote
Advertisement Sponsored links
Old 04-16-2006, 08:55 PM   #2
MoonShiner's Avatar
In order to utilize the labels (GPSSPD, GPSSAT,GPSHDG, etc...) in RR you do not need mapping software.
Open your RR.INI file and make sure GPSPORT=X where "X" is the com port your GPS receiver is on.
MoonShiner is offline   Reply With Quote
Old 04-16-2006, 09:30 PM   #3
nkotch's Avatar
Are you using iGuidance at the same time? If so just get xPort and set it to split out the com port the GPS unit is on to two (or more) other com ports. Then just point the iGuidance program to one of those ports and see RR.ini to use the other port.
Nick
'99 Ford Escort ZX2 CarPC <-- RIP Feb '07
2006 Chevy Equinox LS (Current Project)
**VIA EPIA PD 1ghz Mobo, OPUS 150, 7" LinITX LCD touchscreen, 512 Ram, 60Gig HD, DLink Bluetooth, Belkin 802.11g wireless,
nkotch is offline   Reply With Quote
Old 04-16-2006, 09:32 PM   #4
RoadRunner Mastermind
guino's Avatar
you don't need mapping software installed, but if you do have some software installed (most likely), then you need a port splitter like Xport to get the GPS info to BOTH RR and your GPS app... RR will attempt to collect the GPS data from FD/MM automatically though -- as longa as they're setup propperly.
Road Runner,RR's Myspace
guino is offline   Reply With Quote
Old 04-16-2006, 11:38 PM   #5
NRGZ28's Avatar
That's exactly how I have it setup. I use Xport to split com5 to com6 and com7. But it doesn't work Strange... I guess I'll try it again.
p.s. Xport doesn't work all that well anyway. It only helps the resume from hiberation problem about 50% of the time ... :/
Pioneer 7700MP HU
Old 04-17-2006, 12:12 AM   #6
deus ex machina's Avatar
I was having the same problem so I contacted the author of Xport, Curiosity, and he was very helpful. He gave me a new version to test. It's not perfect but it's been a big improvement over the previous one. I don't know if he wants me giving it out, but I doubt he'd mind.
deus ex machina is offline   Reply With Quote
Old 04-17-2006, 02:50 AM   #7
NRGZ28's Avatar
THanx I'll try that.
Pioneer 7700MP HU
My small hardware to RR mauri Road Runner 33 06-18-2006 03:36 AM
rr & winamp play same time/different videos? turbocad6 Road Runner 3 01-12-2006 03:40 AM
Implimenting Aim or any other im programs into RR ProphetX Road Runner 17 09-01-2005 06:45 PM
RR 3-30-05 ... Mappoint ... guino Road Runner 122 04-06-2005 12:47 AM
Two things with RR 2-19-05 Passe RR Bug Tracker 6 02-19-2005 02:02 PM
