Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 05-01-2006, 10:42 PM   #1
RoadRunner Mastermind
guino's Avatar
Arrow RR 5-2-06.. HQCT & More ..
A bit early for the monthly release cause I gotta travel for work this week. Still Lots of additions and fixes.
I'm going to spend some left out donation money to get a copy of Mappoint 2006 to see what I can do with the interface. Just letting you guys know that I plan to work on it.
This 5-2 version is basically the updates from Robby_BMW with the 5-1 version (many Thanks!):
-Added the ability to fade-in the master volume when a call ends and the player restart (see the notes).
-Added the ability to display caller's picture on the CALL_IN/CALL_OUT skins (see the notes).
-Added the ability to disconnect the BT-Headset when PhoCo exits.
-Added the "HEADSET_CONNECTED_PHOCO" indicator.
-Added AM/FM indicator for HQCT support
-Improved the command "PHONEDISCONNECT" that force PhoCo to disconnect and reinit the phone.
-Improved the BT audio gateway support.
-Improved compatibility with PhoCo 1.5.
-Fixed isues with some old phones (like Sony Ericsson T68i).
-Fixed issue with AddContact when in CallList.
-Fixed issue with PHOCO.PST (see the notes).
-Fixed various minors bugs.
-Fixed RRConfig not loading "World" weather setting
In version 5-1:
-Added HQCT support (Major work)
-Added support for Loadable Extension Plugins (Major work)
-Added FastMode option to load screens faster (Major work)
-Added SpeedFan Support (Thanks to deus_ex_machine)
-Added Built In Voice Control support (Thanks to whodwho)
-Added Dual Monitor support (Thanks to MatrixPC)
-Added support to pre-load specified screens at startup
-Added "WAIT" command to delay between multiple commands
-Added "EVAL" command to evaluate expressions with variables
-Added support for Thai language/charset
-Added AutoIt SDK example (Thanks b8bboi)
-Added label info XMFAVNUM/SRFAVNUM
-Added ONSKINSTART event
-Added support to execute secondary commands on press-and-hold of buttons (1 second holds)
-Added COVERART indicator and label code
-Added CPU Load slider support
-Improved Album Art display to be layered as indicators
-Improved List display of non-selected items to use all space available
-Updated Delphi SDK example (fixed bug receiving messages from RR)
-Updated RRConfig's Radio options
-Fixed list highlight issue with trs=true
-Fixed Issue with XMD1000 not updating current channel information
-Fixed Issue with parsing Flash commands including '$'
-Fixed Issue with ; appearing after custom FD labels
-Fixed Issue with Text object font setting not working
-Fixed Album Art Thumbnail Browse support not showing some thumbs
Notes:
-I still intend to add a little onto the extension plugin support (sliders etc)
-FastMode is an ATTEMPT to make loading of screens faster (I basically added a way to load screens as it used to be on previous versions of RR) -- details on readme.txt
-SpeedFan, DualMonitor and VoiceControl support was merged from the spin off versions posted here in the forums (many thanks to those who took the time to help the community).
-Users of the Brushed skins that use album art, will notice that this version of RR will layer the album art BELOW the flash logo in the audio player. This was done to speed up and improve the way the album art display works and to make it more consistent with the way other imaging functions work in RR -- specially in what it comes to the VIS plugin. Unfortunately, there's no way to layer the flash logo UNDER the art, but it shouldn't be hard to make a flash plugin that displays the art when present or the logo of your choice when no art present -- anyone up for this challenge ? feel free to step in.
-Pre-loading of skins actually works better than I expected, so you may want to give it a try -- look it up in readme.txt to know what to do.
-Everything else you want to know you'll find either at readme.txt or skin commands.txt
Again thanks for your support,
Guino.
Road Runner,RR's Myspace
guino is offline   Reply With Quote
Advertisement Sponsored links
Old 05-01-2006, 10:52 PM   #2
Awesome!!!
Guino, did the issue with RR flashing in front when receiving a SendMsg get fixed in this release? I haven't had a chance to test it.
b8bboi is offline   Reply With Quote
Old 05-01-2006, 10:54 PM   #3
mick0uziel's Avatar
thanks guino, amazing job!!!
7" Lilliput
Opus 150
mini itx 1Ghz
1GB sdram
97 Prelude
mick0uziel is offline   Reply With Quote
Old 05-01-2006, 10:56 PM   #4
guino's Avatar
Quote: Originally Posted by b8bboi
Awesome!!!
Should be fixed. This was a minor touchup I didn't put on the change list. I thought I sent you a PM about it.
Old 05-01-2006, 11:23 PM   #5
Yes you did. Thank you.
Old 05-02-2006, 01:56 AM   #6
djmickyg's Avatar
thanks!
seems to be running a lot better than the past few versions
and im likeing the pre loading of skins
works real well
thanks agian
djmickyg is offline   Reply With Quote
Old 05-02-2006, 03:01 AM   #7
FreeDrive Creator
CdRsKuLL's Avatar
Another great release :-)
p.s clicked on a couple of links for u
www.extremeoc.co.uk me building a murcielago kitcar ! - check it out !
www.cellsecurity.co.uk are my new employer ! - yeah I got a job !
CdRsKuLL is offline   Reply With Quote
Old 05-02-2006, 04:30 AM   #8
tolisn's Avatar
Hey Guino, great release.
Lets help and click on those banners
The road is long but we are getting there.
tolisn is offline   Reply With Quote
Old 05-02-2006, 07:52 AM   #9
I can write an IE bot to click on your links a bunch of times randomly.
Old 05-02-2006, 08:19 AM   #10
MySQL Error
Sonicxtacy02's Avatar
i know this is probably a stupid question as its not referenced above but does this update include robby_bmw's phoco changes?
03 Acura RSX Coupe
a K.I.S.S Flash, VB, and Autoit Programmer
HARDWARE PROGRESS: 90%[/////////-]
Developer of: RRFusion, MovieTimes, (new)RRMail
Coming Soon:RRChrome, RR Plugin Browser & CentraFusion
Old 05-02-2006, 08:46 AM   #11
goosey2099's Avatar
Guino thank you for the update. Everything seems to be working so far and this is exactly what i wanted!!!
4G64 5 SPEED
MY CAR - MY 5SPD - MY CARPUTER - MY GARAGE SALE
goosey2099 is offline   Reply With Quote
Old 05-02-2006, 09:07 AM   #12
Raw Wave
Blue ZX3's Avatar
Awesome work as always Guino!!
Will have to check this out....!!
Blue ZX3 is offline   Reply With Quote
Old 05-02-2006, 09:34 AM   #13
MGD
MGD's Avatar
Great work Guino. Now since we have the HQ radio is there a command to switch between AM and FM. Could not find one.
Also click away on your banner. But this is just to funny........
MGD is offline   Reply With Quote
Old 05-02-2006, 10:24 AM   #14
thank you Guino..also clicked on the ads
can we just update the rr.exe and rrconfig.exe or are there more files in this build that we have to update?
thanks again
camsgs3 is offline   Reply With Quote
Old 05-02-2006, 10:29 AM   #15
MGD
MGD's Avatar
Quote: Originally Posted by MGD
If you using the HQCT module then you need to copy the HQCT folder into the Road Runner directory and create a startup script for RRHQCT.exe.
For example on the radio button put in "RUN;C:\Program Files\Road Runner\HQCT\HQCT.exe"
Guino> Actually, all you have to do is unzip the subfolder and select HQCT in RRConfig. no need to mess with buttons etc.
RR doesn't start Phoco on initial load.. DutchBurner Road Runner 16 11-04-2005 01:17 PM
RR Interchange - Update RR via a USB Media Stick Gobby Road Runner 60 10-04-2005 04:48 PM
IE in RR bug accentsound RR Bug Tracker 2 07-10-2005 01:21 PM
status update.... 0l33l PowerVoice 17 05-05-2005 12:22 PM
Bruno Speech Recognition with RR? ruairi Road Runner 12 05-03-2005 12:20 PM
