Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 06-02-2006, 09:40 PM   #1
d_sellers1's Avatar
d_sellers1 is on a distinguished road
How to easily access the Control Panel
Here's how I added easy access to the Control Panel from within RoadRunner via the Apps Menu.
Browse to where you have RoadRunner and open the LAUNCH folder
Create a new folder and call it Control Panel
In the \Control Panel\ folder, create a file called Control Panel.ini
Add these lines inside the .ini file
Code:
[GENERAL] PATH = Control.exe TryEmbeddedTimeout = 5 WindowSearchString=Control Panel
Restart RR if its running
Now you'll have the ability to open up the Control Panel from the Apps menu.
Derek
EDIT: Or if you're running dbassix's modified version, you can simply use the RELOADINIS command to refresh the .ini files and load any modifications that have been made.
Progress [||-------]
View my Worklog to see some of my progress.
Downgraded Progress - Starting with another car... 09/13/06
d_sellers1 is offline   Reply With Quote
Old 06-03-2006, 11:19 AM   #2
d_sellers1's Avatar
Or just simply download the .ini and put it in a folder called Control Panel in the LAUNCH directory. Just be sure you save it as an .ini file instead of a .txt file.
Derek
File Type: txt Control Panel.txt (87 Bytes, 123 views)
Old 06-03-2006, 11:59 AM   #3
dbassix's Avatar
dbassix is on a distinguished road
But than u have to restart Roadrunner. Or you need my moddified version with the added "RELOADINIS" Command.
2+2=Quattro
Audi S6 2.2 Turbo
RNS-E Headunit
Helix HX400=AXTON Amp
Audi Doorspeakers and 15" JBL in Sparewheel Hole
19" Alutec Alloys, ABT-Silencer, FK-Suspension
dbassix is offline   Reply With Quote
Old 06-03-2006, 12:40 PM   #4
d_sellers1's Avatar
A simple RELOADSKIN may will also work but I don't think may skins have that command enabled. Hence, the reason why I said to restart.
These instructions follow the K.I.S.S. method of doing things.
Derek
Old 06-03-2006, 12:59 PM   #5
dbassix's Avatar
RELOADSKIN wouldn't reload the inis, so it's quiet worthless.
I added a command called RELOADINIS to RR, so u can put a button in the skin which will just reload the inis and reset rr.
2+2=Quattro
Audi S6 2.2 Turbo
RNS-E Headunit
Old 06-03-2006, 01:38 PM   #6
d_sellers1's Avatar
Regardless of the facts, a restart is going to be the easiest thing to do. I'm willing to bet that more people are running guino's build of RR than your build. On top of that, you didn't even say where to get your build of RR. Someone can have their computer restarted in a shorter amount of time than it would take to try to search for your build. Until guino adds this capability to RR and skinmakers incorporate it into their skins, the instructions will remain as restart the computer.
Derek
Old 06-04-2006, 10:27 PM   #7
BLOWNZO6_pc is on a distinguished road
Someone could have also restarted in the time it took you two yahoos to argue this out...
Now kiss and make up...
BLOWNZO6_pc is offline   Reply With Quote
Old 06-05-2006, 11:06 AM   #8
dbassix's Avatar
d_sellers:
As i said, it's MY modified version.
2+2=Quattro
Audi S6 2.2 Turbo
RNS-E Headunit
Old 06-05-2006, 12:10 PM   #9
Banned
JagPuter's Avatar
JagPuter is on a distinguished road
Off topic, Stupid flame, end it now this is a getting lame....
JagPuter is offline   Reply With Quote
Old 06-05-2006, 12:11 PM   #10
b8bboi is on a distinguished road
seriously
iGMon - Integration between iGuidance and Road Runner
CFX - Skin for Road Runner
b8bboi is offline   Reply With Quote
Old 06-05-2006, 08:41 PM   #11
d_sellers1's Avatar
First post edited. Let's drop it or I'll have to request that this thread be locked and all posts with the exception of numbers one and two be deleted. Let's leave the floor open to anyone you may need help regarding this topic.
Derek
Control panel crashes explorer n8scstm General MP3Car Discussion 8 06-30-2008 06:30 AM
AIMEE Climate Control POLL Danceheaven Software & Software Development 19 08-21-2005 07:19 AM
AC97 Control Panel Switcher Program (could be useful for many) Vinister Software & Software Development 0 02-02-2005 04:50 PM
Digital View digital OSD control panel kit. $60.00 shipped to US. Pics inside. LESLIEx317537 Classified Archive 14 02-26-2002 09:42 AM
LCD + control panel almost done RWAudio General Hardware Discussion 5 05-24-2001 06:43 AM
