Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 06-09-2006, 01:30 AM   #1
tolisn's Avatar
tolisn is on a distinguished road
Help required on using the extension plugin
Does anyone know how to use the extension plugin (not the base plugin) concept offered with RR.
I’m trying to make a small plugin to control a servo motor which will be used to tilt my 7” LCD. I have red the FAQ on the pluging but did not understand if I can insert code that monitors the parallel port or if it only ment for defining buttons,indicators and labels ?
The road is long but we are getting there.
tolisn is offline   Reply With Quote
Old 06-13-2006, 03:33 AM   #2
tolisn's Avatar
bump
Old 06-13-2006, 08:13 AM   #3
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
You can ADD any modules/forms/classes to the basic code of the extension plugin. If you already have a working application, simply import the BAS and CLS files from the project into your application then add the necessary code to control your applications from button codes in RR, and add any code to return Labels and indicators from your application.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 06-13-2006, 08:48 PM   #4
Raw Wave
lostreception's Avatar
lostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud oflostreception has much to be proud of
giono how would i go about executing loading a form on the start of the dll i need to use comhook with the form but cant figure out how to get it to start with the dll
.______
| '_ |__\___
[(o)|___(o)] XB
._________
| I__I I_I|_\__I
[(o)______(o)]b VanPimpin'
LostReceptions Apps D/L Here
GPSGasoline- Rewriting
CarPCNetwork
lostreception is offline   Reply With Quote
Old 06-13-2006, 10:27 PM   #5
guino's Avatar
on the Class_Initialize event, simply add:
Load myform
comhook myform.hwnd
that procedure is like the sub main of a normal application.
Garo's Extra POI Plugin 1.0 beta 1 garo Map Monkey 63 01-18-2007 01:32 PM
How do I use the Base plugin sources ? guino RR FAQ 1 04-24-2006 04:43 PM
8” Lilliput extension lead required eor LCD/Display 0 08-13-2004 02:25 PM
Winamp LCD display plugin / IRMan plugin - together? Jarrod Software & Software Development 9 06-03-2002 06:39 AM
Resumer Winamp plugin..works with MPC, too Tony S Software & Software Development 7 03-30-2002 06:10 PM
