The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Thread Tools Display Modes
Old 06-20-2006, 07:58 PM   #16
Jarrod's CarPC Specs
Jarrod's Avatar
Vehicle: 2001 Holden VX S Commodore
My Photos: (0)
Thats my plan LS, Seperate skins for back and front seat passengers, etc. Maybe my first post was a little long....
Jarrod - Holden VX S!
Jarrod is offline   Reply With Quote
Sponsored Links
Old 06-20-2006, 09:38 PM   #17
SMKFree
liquid_smoke's Avatar
Vehicle: VW Passat
My Photos: (0)
ok, thats pretty cool. I may make a secondary skin specific for the backseaters with a different gps app running.
beer replenishment fund
mp3car live search
liquid_smoke is offline   Reply With Quote
Old 06-21-2006, 08:04 AM   #18
MySQL Error
Sonicxtacy02's CarPC Specs
Sonicxtacy02's Avatar
Vehicle: 2003/Acura/RSX
My Photos: (129)
ok i just gotta ask.. what kinda computer are u using that would have the power to run two rr's with all the neccessary? I have a amd 2800+ and there's no way it would run two instances with support apps effectively.
03 Acura RSX Coupe
a K.I.S.S Flash, VB, and Autoit Programmer
HARDWARE PROGRESS: 90%[/////////-]
SKIN PROGRESS: 90%[/////////-]
Current Project: RRFusion, MovieTimes, RRMail and More!!! :)
Old 06-21-2006, 08:55 AM   #19
Jarrod's Avatar
My Photos: (0)
Im running a Pentium M 1.8 Ghz. Also tested on a Celeron M 1.5Ghz and it runs fine, with GPS, two RR's, two winamps, and playing a video clip on one screen.
Havent tested with both RR's playing separate video clips yet though.
My system is running nLited XP with a custom shell app which launches the two RR instances, so that would help with resource usage.
Old 09-27-2006, 06:47 AM   #20
Iceman_jkh's CarPC Specs
My Photos: (1)
so how do you get RR to load 2 separate instances of Winamp?
and how do you set which one is controlled at what time?
I want 1 winamp playing music.
I want the other winamp running a vis plugin, monitoring the soundcard Line-In for its beatdetection and outputting the Vis as an embedded RR window...possible?
Iceman_jkh is offline   Reply With Quote
Sponsored Links
Old 09-27-2006, 10:15 AM   #21
RoadRunner Mastermind
guino's CarPC Specs
guino's Avatar
Vehicle: 04/Mazda/RX-8
My Photos: (5)
You have to have 2 copies of RR (you can point them to the same music/videos/skins and applications). Then on RR.INI you have to set the winampclass= each should control (just choose any 2 unique names) -- this is in readme.txt. Then just make sure one of the shortcuts to run RR has a in the parameters /2 so it can launch while the other RR is already running.
Road Runner,RR's Myspace
guino is offline   Reply With Quote
Old 09-27-2006, 10:35 AM   #22
My Photos: (1)
So not able to have Dual winamp control for single RR?
The second winamp doesnt even need to be controllable.. just set the input=linein and then Turn the Vis On and Off.
Old 09-27-2006, 11:34 AM   #23
guino's CarPC Specs
guino's Avatar
My Photos: (5)
This support was built in order to better support a dual monitor setup, there was never an intention to control 2 winamps at once.
If you run the second winamp manually you can start it directly with linein input, however, there will be no way to control the VIS from RR, you'd have to do it manually as well.
Old 09-27-2006, 11:06 PM   #24
Jarrod's Avatar
My Photos: (0)
Hey Guino, any chance of modifying RR so that an external app (like zoomplayer) can be used to play videos, rather than media player classic? This would allow multiple instances of RR to play different videos at the same time. At the moment each RR instance fights over the player.
Old 09-27-2006, 11:16 PM   #25
guino's CarPC Specs
guino's Avatar
My Photos: (5)
does it have any control API/SDK ? If not, then I'm not even going to look at it.. it was a pain in the A$$ to make the interface for MPC already. If I'm to integrate anything now, it better have an SDK.
Old 09-28-2006, 04:39 PM   #26
My Photos: (0)
may be a chance for zoomplayer
http://www.mp3car.com/vbulletin/show...ght=zoomplayer
Quote: Originally Posted by P3rv3rt B3ar View Post
Ive made a plugin for this purpose. It integrates ZP to XLobby. It provides progress data to Xlobby, and makes jump with progressbar possible. Among other features. Its currently still on my personal use, theres still one feature and two major bugs i want to implement and hunt down before public release.
Hey Guino, Not sure if this may help you as I'm not sure what P3rv3rt B3ar coded his plugin in for zoomplayer to work with Xlobby, but I would think he knows how to talk Zoomplayer and that may be a way around the need for an SDK.
dashboard is offline   Reply With Quote
Old 10-05-2006, 09:47 AM   #27
john05srt4's Avatar
Vehicle: 2008 Scion xB
My Photos: (0)
very cool thread.
I am building a new carpc and this is a MUST for me.
Have 3 touchscreens and be able to have navi or FM up front and dvd movie in the back.
What about the sound? can you specifiy how the sound will come out like if i have FM on up frotn then the front speakers play and if they have a dvdv on in back the rear door speakers will play that?
john05srt4 is offline   Reply With Quote
Old 10-05-2006, 09:56 AM   #28
guino's CarPC Specs
guino's Avatar
My Photos: (5)
If you have 3 soundcards, you should be able to do that.
Sponsored Links
vB code is On
Trackbacks are Off
How to get RR to run on a second (external) monitor? b8bboi Road Runner 3 07-18-2005 02:42 PM
Auto load FD when RR starts up tolisn Road Runner 2 07-08-2005 04:30 PM
Multiple Monitors and Multiple inputs nixneon Newbie 1 03-19-2005 07:30 PM
Requirements to run RR properly oekundar Road Runner 17 03-07-2005 06:40 PM
Does anyone have a multiple LCD screen setup? Choser LCD/Display 5 02-04-2004 11:32 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
