Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 06-20-2006, 09:41 AM   #1
Terminal flasher
Sonicxtacy02's Avatar
Sonicxtacy02 has a spectacular aura aboutSonicxtacy02 has a spectacular aura about
Problem compling rr with latest source code
I'm tryin to add some modifications to the phoco module and i'm having trouble compiling with microsoft visual basic 6.0 enterprise. No matter if i try to compile my modified project or the one downloaded directly from guino's site i get the same issue. Compiling inside of vb 6.0 gives me the following error:
Compiling in the packaging wizard gives me this error:
Compile Error: Cant Find Project or Library
Compile Error in File 'C:\Documents and Settings\Shaun\Desktop\RoadRunnerSource\SubFolders .cls', Line 2 : Can't find project or library
Build of 'rr.exe' failed.
Also attached a pic of the section of code thats supposively causing the error. What gives?
03 Acura RSX Coupe
Developer of: RRFusion, MovieTimes.NET, (new)RRMail, RRShoutcast, & RRVehicle Maintenance
Currently working on: RRVehicle Maintenance
Old 06-20-2006, 10:10 AM   #2
Griff1's Avatar
Griff1 is on a distinguished road
Sorry sonic,I can't code but i'm curious as to the nature of your mod?
What are you changing??
Griff1 is offline   Reply With Quote
Old 06-20-2006, 10:48 AM   #3
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
the Mid function is very basic within VB6 (seems to be your issue from the screenshot) .. I'm guessing one of the default libraries is shot on your install. Those are the references you need to make sure are in place before compiling RR (make sure you have microsoft scripting runtime checked):
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 06-20-2006, 11:01 AM   #4
Terminal flasher
yea the runtime is checked by default, as are all the other ones shown in your picture. I'll try reinstalling vb6 and hope that it goes away. If that doesnt work where else should i turn?
Griff the only mod i'm doin is to add a button to disconnect the audio gateway thru rr. I need this as without it phoco is only usable as a standalone program. Have somethin else u need me to modify?
03 Acura RSX Coupe
Old 06-20-2006, 11:07 AM   #5
guino's Avatar
You may want to try installing SP6 if you haven't done that yet.
Old 06-20-2006, 11:26 AM   #6
Terminal flasher
i got all the available updates and that got me past the mid function but i still have a problem in subfolders.cls. Same Error:
03 Acura RSX Coupe
Old 06-20-2006, 11:39 AM   #7
guino's Avatar
that's part of the microsoft scripting runtime I told you about.
Check that you have scrrun.dll, not blocked etc.
SOMETIMES.. vb6 goes nuts and has issues with references, then you can try unchecking that reference, save/close the project & vb6, reopen it and re-check the reference and it starts working.
Old 06-20-2006, 12:00 PM   #8
MySQL Error
MatrixPC's Avatar
MatrixPC is on a distinguished road
The touchlist module some time drive me nut. I am sure I didn't change/mod anything on that module, and still give me error.
save/close/reopen work just fine.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 06-20-2006, 12:25 PM   #9
Griff1's Avatar
Yes i have a request please,I've been hoping for a change to the TEXT boxes in Phoco skins.
Currently they are not transparent ( but LISTS are ).Any Ideas?
Before going any further i should add that Guino considers this mod a lot of code.
Thanks for asking
Old 06-20-2006, 04:53 PM   #10
Terminal flasher
ugh this is driving me MAD! I checked scrrun.dll, it exists. Its not in use and not blocked (as far as i can tell). I tried the method guino suggested and it still doesnt work. I replaced scrun.dll with another version from the net.... same error. Anything else anyone can think of? If push comes to shove i'll just use a different version of vb6.
Unfortunately griff i'm not that versed in VB to add that much code. The changes i'm making only require 2 lines of code. That makes it even more frustrating lol
03 Acura RSX Coupe
Old 06-20-2006, 05:20 PM   #11
Griff1's Avatar
No Problem Sonic,thanks anyway,good luck with your error mate.
Old 06-20-2006, 05:43 PM   #12
guino's Avatar
you can try to regsvr32 the scrrun.dll file.. have you disabled any services in windows ? or disabled anything script-related ?
Old 06-20-2006, 05:52 PM   #13
Terminal flasher
i registered the dll. Made no difference. I havent changed any of the services on this xp sp2 corp installation. Will try on my work pc tomorrow before just givin up.
03 Acura RSX Coupe
Old 06-22-2006, 02:55 AM   #14
valery is on a distinguished road
Use Windows 2000 profesional.
I downgrade XP to win 2000 for work in VB6.0.
Sorry, i bad write english.
valery is offline   Reply With Quote
Old 06-22-2006, 08:58 AM   #15
Terminal flasher
well it worked fine on my work computer thats running xp. I have no idea why it wont compile at home but i got it done here
03 Acura RSX Coupe
HQCT Source Code for C#? mtrax Coders Corner 8 06-10-2006 03:26 AM
weird problem with RR and mapmonkey rasheedn Road Runner 8 05-30-2006 12:03 PM
How do I use the Base plugin sources ? guino RR FAQ 1 04-24-2006 04:43 PM
GPS code for RR wanted FiGu Road Runner 5 04-05-2006 05:59 PM
c++ LCD source code mprover Software & Software Development 3 01-19-2001 04:32 PM
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
