The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Thread Tools Display Modes
Old 07-18-2006, 02:12 PM   #1
Vehicle: 10psi Type-S
My Photos: (0)
A few problems with latest RR Version
Hello Road Runner newbie here:
Goinf to be doing a carputer here shortly and wanted to get the Front end taking care of first. A few minor issues which I sure can be easily fixed by the carputerGODS.
Events:
Download Road Runner + BMV2 Skin InstallShield
Downloaded a few skins from the Skins button on RR's site
Downloaded Skin Editor
Downloaded reccomended Winzmp version <stable version>
Issues:
1) When I open RR, Winamp seems to open as well under RR window? If I close Winamp, Music will not play
2) On Screen keyboard "buttons" seem to type 2 of everything I type. If I use my keyboard, all types fine.
3) I unzipped the Skins to the skins directory. Tried to change skin from the Skin selector, RR locks up. Have to go back to RR configuration Tool to change back to default BMV2 skin.
4) Currently I am testing RR on my laptop with a screen resolution of 1680x1050. RR doesnt seem to resize to full screen, rather stay anchored to same size and 0,0. I see you can edit this in the INI, which I changed to 1680x1050...just made it mount to the middle of the screen, rather than resize it.
5) After making the .ini screen side changes the web now doesnt seem to open..lol
6) Rather than editing a skin, is there any tools to start from scratch with maybe an Insert_Picture option? Or am I missing something simple here. The default middle logo is "H" for Honda, i'd rather change it to a solid picture.
If you dont mind, please reply in a #1 <answer> #2 <answer fashion>. As not to get question/resolution mixed up.
MUCH THANKS
left_hooked is offline   Reply With Quote
Sponsored Links
Old 07-18-2006, 02:29 PM   #2
My Photos: (0)
1) Seems to be normal
2) If I dont edit the .ini for screen size it types fine
3) Update fixed this. Some of the skins I downloaded however are only a few .jpgs and .ini files...missing the .skin files.
4) <needing reply> and to search more and read FAQ.
5) See #4
6) <needing reply>
Old 07-18-2006, 02:40 PM   #3
My Photos: (0)
For 6), have you tried reading the "Skin Commands.txt" file from the RR package? That would be a really good place to start if you haven't already.
navank is offline   Reply With Quote
Old 07-18-2006, 03:15 PM   #4
DiNASTY's Avatar
Vehicle: 2005 Civic
My Photos: (0)
3) Make sure are downloading full featured skins as many people (including myself) like to release teasers and betas that aren't 100% finished. I believe all the skins on the rrdownloads site are mostly complete.
4) RR is designed of in-car monitors usually around 7-8in (800x480, 800x600). That's not to say RR can't display at that resolution (i have a MC skin that i run at 2560x1600 for my home theatre)... however your skin may not be designed to stretch that big. Instead, simply change the resolution of your laptop to 800x600 and it should display "full-screen".
6) search for "RRSkinEditor". Other than that, you will have to get your feet wet.
Beer is proof that God loves us and wants us to be happy — Benjamin Franklin
DiNASTY is offline   Reply With Quote
Old 07-18-2006, 03:19 PM   #5
My Photos: (0)
Yeah, I kind of thought that about needing to edit each skin per new size. I have also edited my logo.swf with a nice little one I just made . Feet wet = FTW
Old 07-18-2006, 03:51 PM   #6
My Photos: (0)
I looked in the skin command.txt and didnt find a means to create a new item for Application to call a local path .exe?
Old 07-18-2006, 05:43 PM   #7
My Photos: (0)
Do you want to launch some App.exe from your skin? The Skin Commands.txt file has some info on that..
"RUN" - Dynamic Commands: set the code of a button to: "RUN;COMMAND|PARAMETER1|PARAMETER2" will make it so clicking this button runs the specified command&parameters in the computer. As an option you can run the command specifying the application name to embed in the current screen (the application will be enbedded using the "A" settings in the skin file of screen:
Example: "RUN;C:\WINDOWS\NOTEPAD.EXE;NOTEPAD" (to run embedded)
"A,000,055,800,545,000,000,000" (.skin definition)
Optionally you can also set the text to be "spoken" when clicking the button
Example "RUN;C:\WINDOWS\NOTEPAD.EXE;NOTEPAD;NOTEPAD"
Old 07-18-2006, 06:00 PM   #8
seanz0rz's CarPC Specs
seanz0rz's Avatar
Vehicle: '98 Toyota 4Runner
My Photos: (0)
1) an option in RR config is to hide winamp. the way i do this is to start winamp on its own, make sure the playlist/eq/etc is not displayed, then go into the config and click hide winamp.
1998 Toyota 4Runner SR5 V6 4x4 in Evergreen Pearl Metallic, Lifted, Locked, and Armored. CarPc in custom console with molded touchscreen.
Pictures
Photobucket is being updated, if a picture i posted no longer works, please PM me.
seanz0rz is offline   Reply With Quote
Old 07-18-2006, 11:08 PM   #9
My Photos: (0)
I think I am missing something here. Can you provide a small step by step on how to do the above?
Got it
Old 07-19-2006, 04:07 PM   #10
My Photos: (0)
Got it
What do you want to do? And what are you missing?
Sponsored Links
Old 07-19-2006, 05:12 PM   #11
My Photos: (0)
I want to add a button to a .skin that calls a local program. Not sure where to set these features:
PrintScreen ftw!
Old 07-19-2006, 09:20 PM   #12
My Photos: (0)
You should add the RUN option to a button command. If your button coordinates are, say, B01,0,12,135,78, and say you want to launch notepad, you should add this line to your skin file.
B01,0,12,135,78,"RUN;C:\WINDOWS\NOTEPAD.EXE;NOTEPA D"
But typically you wouldn't just want to launch the application - you would want to embed it into RR so that it looks as part of your skin.
That's when you want to use the (A) Application command to restrict the application to a certain area of the skin, a background color, ...
/, (A) APPLICATION, TV Window, and Video "confine" position (for video you must also CLIP this area).
/, x y w h r g b
AXX,XXX,XXX,XXX,XXX,XXX,XXX,XXX
You could probably look at CFX_800_600 skin as an example. If you look in the menu2.skin, you'll see a button to invoke RRConfig.exe. It uses a slightly involved method of loading an app launch skin and going through that for the app, but you get the idea.
PrintScreen ftw!
Sponsored Links
vB code is On
Trackbacks are Off
VisualDesigner for creating other skins zorro Software & Software Development 145 02-17-2007 09:38 AM
Problems playing DVD with RR 03-08-05 Passe RR Bug Tracker 8 06-24-2006 12:36 PM
rr.exe wont extract on latest version GazzyB RR Bug Tracker 3 06-06-2006 11:38 AM
Latest Maps Version?? studly_steve007 Map Monkey 25 11-24-2005 08:46 PM
Latest Maps Version?? studly_steve007 FreeDrive 45 08-21-2005 01:42 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
