The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Thread Tools Display Modes
Old 08-11-2006, 01:37 PM   #1
GizmoQ's CarPC Specs
GizmoQ's Avatar
Vehicle: Several
My Photos: (78)
Animated Weather Radar
I have modified the radar skin to load my animated radar gifs into Internet explorer on a generic skin. It took me a while to figure out how to insure there was only one instance of IE running (otherwise, RR would crash on exit), but my needs now have exceeded my expertise. I need your help with three issues:
1. Is there a way to load a new image into the existing IE window? I currently have to close the current IE window and open a new.
2. Is there a way to run these in kiosk mode?
3. IE resizes the image to fit its window, is there a way to disable this resizing?
The following command loads the skin:
B,660,410,50,65,"weathersat||Run;C:\Program Files\Internet Explorer\iexplore.exe|http://image.weather.com/images/maps...05.jpg;Current Map","radar"
And below is an excerpt of my radar.skin:
B00,439,415,68,66,"closewindow;http://||Run;C:\Program Files\Internet Explorer\iexplore.exe|http://image.weather.com/images/maps...05.jpg;Current Map"
B00,508,415,74,66,"closewindow;http://||Run;C:\Program Files\Internet Explorer\iexplore.exe|http://icons.wunderground.com/data/6...sf_anim.gif;US Fronts"
B00,583,415,73,66,"closewindow;http://||Run;C:\Program Files\Internet Explorer\iexplore.exe|http://icons.wunderground.com/data/6...m.gif;REGional radar"
B00,657,415,70,66,"closewindow;http://||Run;C:\Program Files\Internet Explorer\iexplore.exe|http://radblast-aa.wunderground.com/.../WUNIDS;nexrad radar"
B00,728,415,72,66,"CLOSE",""
Thanx in advance
HARDWARE: Fujitsu Stylistic 4121w/ WiFi & mini dock, Sierra Wireless Aircard 550, EXP PCMCIA Portable DVD-RW, Silabs FM, WinTV USB w/-26dB diversity antenna, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 USB joystick, BluSoleil USB Bluetooth
GizmoQ is offline   Reply With Quote
Sponsored Links
Old 08-11-2006, 02:34 PM   #2
SMKFree
liquid_smoke's Avatar
Vehicle: VW Passat
My Photos: (0)
1. I dont think so, currently if a link gets sent to IE in RR, or if you type in a URL it will close IE and open a new instance.
2.you can run in kiosk mode but not inside of RR
3. image resizeing can be turned off in IE settings Tools>Internet Options>Advanced>multimedia>second option under multimedia
some work still needs to be done with the web intergration in RR, personally i just open the browser outside RR
beer replenishment fund
mp3car live search
liquid_smoke is offline   Reply With Quote
Old 08-11-2006, 08:14 PM   #3
Road Runner & Mp3car Gatherings Moderator
JohnWPB's CarPC Specs
JohnWPB's Avatar
Vehicle: 99 Mitsubishi Eclipse
My Photos: (0)
If you are using IE to display the image, why not put a couple buttons on the IE page that match your skin to load diffferent images. If you do it this way, you have the ability to take full advantage of all of the html/asp code at your disposal.
You can do rollovers to match your skin's look and feel, Click on a button to change an existing image on the page and so many other options.
You can say, have your RR menu bar at the top of the page, and a html button bar at the bottom of the page to control the images in the center of the page either with frames, iframes, tables ect.
My house is automated, with a few touch screens throughout, as well as a couple viewsonic smart displays. I have designed the interface totally in html/asp so that it will work from any web broswer, either in the house, or from the internet.
Here is a capture of my weather screen I use in the automated screens throughout the house.
the buttons along the bottom of the screen change the display in the center of the page.
Here is what it look slike when the "Radar" button is pressed:
The images are also all animated, as is what you seem to be trying to do in RR.
CarPuter: 2.8Ghz P4 with 1 Gig Mem, 500 Gig HD, Iguidance 4.0, 7" Motorized Touchscreen, XM PCR1000, Visteon HDZ300 HD Radio, WIFI, Fusion Brain.
Powered By Road Runner & the DigitalFX 3.0 Skin
http://www.johnwpb.com
JohnWPB is online now   Reply With Quote
Old 08-11-2006, 09:31 PM   #4
GizmoQ's Avatar
Vehicle: Several
My Photos: (78)
Cause I haven't coded html since college (and never thought of it for this.) Good call. Let's see where's a good UP TO DATE html manual.
Old 08-12-2006, 02:39 PM   #5
Evolution VIII's Avatar
Vehicle: 2005/Mitsubishi/Evolution VIII
My Photos: (0)
I think to include native animated gif support in RR would be a better idea.
Evolution VIII is offline   Reply With Quote
Old 08-12-2006, 05:05 PM   #6
GizmoQ's Avatar
Vehicle: Several
My Photos: (78)
Already available I thought, but only as images, i.e., I'd have to download the pics each time, create separate skins for each and unfortunately one of them doesn't download well.
Old 08-12-2006, 06:30 PM   #7
My Photos: (0)
I can make an executable to download new picture every time you accessing the skin.
Old 08-12-2006, 06:45 PM   #8
GizmoQ's Avatar
Vehicle: Several
My Photos: (78)
Websites listed above. First one is easy - std jpg. Second and third are just long web addresses for current gif. Fourth is a pain in the *** to actually define for download but it too is an animated gif.
Old 10-17-2006, 08:35 AM   #9
My Photos: (1)
Yes I was about to post on this issue but stumbled accross this post. I have RR installed on a laptop and found several sources of animated gif's for radar and sattellite. When changing the url in weather.ini, only one of the frames loads. Is there a way to "turn on" animated gifs? OR perhaps some way to convert them to SWF then load them in the same place? I really need to see the radar moving or else the image is pretty useless if you cant see which direction a storm is moving.
drdream is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Great Radar Idea swifty8083 Software & Software Development 10 04-09-2007 02:26 AM
Weather Cache danl Road Runner 8 05-28-2006 04:50 AM
Weather Radar Chuck Road Runner 61 05-07-2006 12:19 AM
Weather program for Map Monkey warnockm Other Cool Stuff 5 12-10-2005 08:14 PM
Enhanced Weather Links for Web browser GizmoQ Centrafuse 2 01-22-2005 10:25 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
