Guino -
This is the tricky spot, I have this working but if I do it from a typical navigation in which I audiobrowse to my playlist folder - and then it works, confirm and all.
What I've done is created a PopUp with the syntax and skin above - and from that menu is where I am trying to perform the deletefile. I could only assume perhaps it's not including all of the path so tries to delete something that does not exist....
So the steps are:
1 - I bring up a small PLIST skin as a popup via. MENU; .... with the following
/, SD, Alignment;Alignment, Disp;MODE, Icon Width, Icon Heigth, Path
SD,oo,"00",,,"C:\Documents and Settings\ckolibab\Desktop\AllOfMP3-NEW\PLAYLISTS"
2 - Now on the PLIST skin I have a button to perform the DELETEFILE, and will not work - confirm comes up but the file is not deleted. Is it not grabbing the path data?
3 - If I use the same process in audio browser - I can indeed do this, and could live with it...
4 - BONUS QUESTION :-) Can u toss my some syntax on the location of that popup skin, I am searching and working with the PINK screens also but believe u made it so we could use X/Y coords to place MENU; ... skins on loads.
Thanks sir!!!!
Quote: Originally Posted by
guino
This should work indeed, the question is what do you have in your comfirm skin ? (I'm also assumming you're using a folder list to display the playlists).
