03-31-2008, 11:56 AM
#256
Location: Washington, DC - Alexandria, VA N/W Area - NOVA
Same here.
Thing is this install IS mainly for the newbies, hence the reason for including the basic bmv2 skin, helpfile, etc. If they're going to be installing a more advanced/intense skin, they should know by reading the thread/readme what prerequisites there are and can choose whether or not to install BMV2 and/or WinAmp 2.95. I can add the option to have one or the other installed...
03-31-2008, 06:59 PM
#257
The Curator
I just thought I'd give my feedback thats all...
03-31-2008, 07:59 PM
#258
Confusion Master
feedback is not good in an audio enviroment.
03-31-2008, 08:03 PM
#259
it's all good bro
04-01-2008, 04:09 PM
#260
Installed RR using the installer, copied some skins over from a different computer, couldn't get the background to work. The skin.ini entry for the background used C:\program files\road runner\etc....
The installer has a default directory of C:\program files\roadrunner\
Did I miss the change to no space? Or is that what most people are using
04-01-2008, 04:19 PM
#261
Not sure to be honest. I know the roadrunner executable name went from "RR.exe" to "RoadRunner.exe" a while back, but for the folder name, I've always used "RoadRunner".
04-01-2008, 04:33 PM
#262
Most of the time it doesn't matter...all the little scripts I build just use rrpath anyway. I just changed one of my installs to RoadRunner....everything works. Just had to change the background definition.
04-01-2008, 05:16 PM
#263
Confusion Master
I always have program files\road runner\
04-01-2008, 06:46 PM
#264
The Curator
Mine too has always been "\Road Runer\.."
And I thought that WAS the default RR folder name, with the space...
04-03-2008, 05:34 AM
#265
damn this topic is hard to find..
04-15-2008, 01:00 AM
#266
I just updated my server info for the mirror site
W3bMa5t3r can you check that its running ok for all files
04-15-2008, 11:16 AM
#267
I have a 1-15-06 road runner installer....probably the last one I used until recently. 1-15-06 installer installs to \road runner\ which is probably why I always assumed that was the default.
04-17-2008, 08:14 AM
#268
@ woof-n-stuff, I'll check it out. thanks for the heads up.
@ the folk talking about the default RR directory. I'll update the next installer with \Road Runner\ as the default directory, but 1 note for the coders/skinners, file paths shouldn't be hard coded, at the very least they should be relative to your application/skin... I've noticed this in quite a few apps/skins floating around here, but I guess that's off topic
anywho....  I'll change the default on the installer so it won't throw people off.
Cheers
04-17-2008, 11:16 AM
#269
The Curator
Thanks...
P.S.  There's only one user that I know of that uses hard coded paths...the letter S comes to mind....
04-17-2008, 12:07 PM
#270
Thanks...
lol well I won't point any fingers, but with rebuilding my system recently and installing alot of support apps from the forums, I've run into more than a few... but yeah  and of course
This weekend will be hectic for me, but I'll try to tackle all the projects on my plate asap.
| Thread Tools |
| Display Modes |
Linear Mode
