Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Closed Thread
Old 04-26-2007, 10:25 AM   #106
W3bMa5t3r's Avatar
Location: Washington, DC - Alexandria, VA N/W Area - NOVA
W3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of light
Quote: Originally Posted by leatherboy View Post
No, I downloaded 3 times the binary zip file. All the times when it tries to unzip the roadrunner.exe file I get the message tha the file is missing. I can see it in the file list of the binary zip but i cannot extract it right
Ok, If you're not able to extract the binary file correctly that's telling me there must still be something with your AV (or something... best I can figure...) that is killing it before it can extract the full archive to your RoadRunner folder. Make sure NOD has Advanced Huristics Detection turned off and if your Zone Alarm install has the AV portion running with it, make sure that's off as well.
W3bMa5t3r is offline
Old 04-26-2007, 10:27 AM   #107
W3bMa5t3r's Avatar
Iget the message ie cannot receive this file from http://guino.home.insightbb.com when it reaches 99%. Can I get it from another mirror?
I just downloaded from that site, it finished 100%... something on your system is holding it back. It's killing roadrunner.exe inside the archive.
Old 04-26-2007, 10:32 AM   #108
leatherboy's Avatar
leatherboy is on a distinguished road
I ve once again with my AV disabled. I get the some message. I think i will try it from onother pc.
leatherboy is offline
Old 04-26-2007, 10:34 AM   #109
W3bMa5t3r's Avatar
Ok, good luck
Old 04-26-2007, 10:38 AM   #110
leatherboy's Avatar
what AV do you use? Or should I always work without AV if I want to run RR?
Old 04-26-2007, 10:40 AM   #111
W3bMa5t3r's Avatar
I use AVG and I know a lot of people on here do. You can use it with RR, but you have to turn off the Advanced Huristics Detection because it gives a lot of false positives and deletes the RoadRunner.exe file
Old 04-26-2007, 10:43 AM   #112
leatherboy's Avatar
Thanks my friend. I will try it at home later.
Old 04-26-2007, 10:53 AM   #113
W3bMa5t3r's Avatar
No problem and good luck. Hope you get it
Cheers.
Old 04-26-2007, 02:54 PM   #114
leatherboy's Avatar
Hi again. It seems very strange but.... it is true. I 've tried to find this roadrunner.exe using 2 pcs without AV. I download the RoadRunnerBinary.zip.
without problem. But when I extract it roadrunner.exe is missing. Can someone send it to me with an email or what else.
Old 04-26-2007, 11:27 PM   #115
W3bMa5t3r's Avatar
Binary Version April 11,2007 - grab it here from SourceForge
Old 04-27-2007, 06:47 PM   #116
leatherboy's Avatar
FINALY. I did it . It is a great program. Thanks. And I already start to make plans for a skin. I have to find some hours to make it. Perhaps between 02 and 04 am. Thanks again.
Old 04-27-2007, 06:59 PM   #117
W3bMa5t3r's Avatar
Good to hear. What was the final solution?
Can't wait to see the skin
Cheers... The W3bMa5t3r
Old 04-28-2007, 11:10 AM   #118
N6BER is an unknown quantity at this point
A lot of AV progrmams allow you to put in exclusions although you may have to still turn it off when installing programs. Check if you have an exclusions list.
As fars as a good AV program I've been very happy with Avast. It's one of the best AV programs I've found, it has a small memory foot print, does not take a lot of overhead, gives you lot's of control and it's free for non-commerical use. You do have to reregister every 14 months.
N6BER is offline
Old 07-12-2007, 06:46 AM   #119
PSI70Y is an unknown quantity at this point
Hey guys
I also had problems with roadrunner.exe not being present, turned advanced heuristics off in Nod32 and voila...bob's ur uncle!
However when I run the updater it is able to verify which version of RR I have and is able to identify that a newer version is available but i get a "Download Failed" message. Any ideas????
PSI70Y is offline
Old 07-23-2007, 01:04 AM   #120
sebberry is on a distinguished road
What is the latest version of roadrunner...
It looks like I have version 1.0.0.0 (as indicated in the "version" tab when righ clicking the roadrunner exe and selecting properties.
Thanks.
sebberry is offline
Closed Thread
Content Relevant URLs by vBSEO 3.3.0
"VaultWiki" powered by VaultWiki v2.5.2.
Copyright © 2008 - 2009, Cracked Egg Studios.Ad Management by RedTyger
