The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Thread Tools Display Modes
Old 09-18-2006, 02:46 AM   #1
Road Runner & Mp3car Gatherings Moderator
JohnWPB's CarPC Specs
JohnWPB's Avatar
Vehicle: 99 Mitsubishi Eclipse
My Photos: (0)
Question Loading a saved Playlist
Ok, I have searched extensively (using this board, and google's Site search feature, the Skin commands.txt ect ect....), and can't seem to find what I am looking for.
I want to simply have a button to load a saved playlist. NOT a hardcoded button, with the name of the playlist in the buttons code.
Such as:
Code:
"LOADROCK","RUNQ;<Path>\Winamp.exe <Path>\Rock.m3u||RELOADLIST"
I am looking to press a button to go to either another screen/pop-up menu(prefered) showing the contents of the playlist directory (as configured in the RR.ini), and select one from it.
I just can't figgure out how to browse to the defined directory in the RR.ini when pressing a button, and have the playlists that are saved displayed to choose from.
I have seen lots of workarounds to load playlists such as pressing a button up to 5 times for different playlists, and a menu that chuck designed to press an icon to load a certain defined playlist.
It seems quite odd to me that you can press a button and the OSK pops up to allow you to input a name of the playlist and save it, but not be able to do anything to load it, other than hardcoding the playlist name on a buttons code.
CarPuter: 2.8Ghz P4 with 1 Gig Mem, 500 Gig HD, Iguidance 4.0
7" Motorized Touchscreen, XM PCR1000, Visteon HDZ300 HD
Radio, WIFI, Fusion Brain.
Powered By Road Runner & the DigitalFX 4.0 Skin www.johnwpb.com
JohnWPB is offline   Reply With Quote
Sponsored Links
Old 09-18-2006, 02:50 AM   #2
SMKFree
liquid_smoke's Avatar
Vehicle: VW Passat
My Photos: (0)
what i do is create a folder inside my music lib (mine is named -{saved list}-) and this is where i save all my playlist.
When your inside the audio browser just go into the folder where the playlist are and load them.
I named the -{saved list}- like this so its allways at the top of the list so i dont have to search for it.
beer replenishment fund
mp3car live search
liquid_smoke is offline   Reply With Quote
Old 09-18-2006, 02:58 AM   #3
RoadRunner Mastermind
guino's CarPC Specs
guino's Avatar
Vehicle: 04/Mazda/RX-8
My Photos: (5)
You can do exactly what you want though, make a popup screen with a Folder list in it, and use the SD definition to define where it will be showing files from. Then just use the MENU command to display it, up/down to scroll and the SELECT command to load it.. I am pretty sure a few users have done that already.
Road Runner,RR's Myspace
guino is offline   Reply With Quote
Old 09-18-2006, 03:23 AM   #4
kpjuk's Avatar
Vehicle: Peugeot 807 - 2003
My Photos: (0)
Hello John,
Download this skin Black Vinyl on Aluminium
Press the bottom right menu button to get to the main menu,
Select top left button marked MP3 to get the audio Player menu
In the centre of the screen is The button to get to the Audio Browser screen.
On the right in the Playlist section are three buttons to load, save and clear Playlists.
To get the load option working for your config, you need to make sure that you have the SD entry in the Plist.skin set to point to the directory of your saved playlists, or to the variable $playlistpath$, like this
MEDIACAR Skin
MEDIACAR Black Vinyl on Aluminium Skin
/, SD, Alignment;Alignment, Disp;MODE, Icon Width, Icon Heigth, Path
SD,oo,"00",,,"$playlistpath$"
/, S, x, y, w, h, fore R;RGB, G, B, back R;RGB, G, B, folder R;RGB, G, B, file R;RGB, G, B, selected R;RGB, G, B, select R;RGB, G, B, trs, font pt;FONT, font name
S01,15,52,232,262,0,255,0,,,,255,255,255,,,,128,0, 0,255,255,128,,16,"Arial:B"
/, L, x, y, w, h, color R;RGB, G, B, font size;FONT, font name, Code;LABELCODES, Tooltip;LABELALIGNMENT
L01,15,15,230,33,149,149,0,20,"Arial:B","=Playlist s","CENTER"
L02,21,355,98,42,255,255,0,20,"Arial:B","=Load","C ENTER"
L02,145,355,98,42,255,255,0,20,"Arial:B","=Cancel" ,"CENTER"
/, B, x, y, w, h, Command;COMMANDCODES, Tooltip
B01,4,331,127,80,"SELECT||EXIT",
B02,131,331,130,81,"EXIT",
END
If this is the sort of thing you want to do, hack the skin commands to suit your requirements.
Good Luck
KPJUK
M1000, 512MB, 512MB CF, 6GB Disk (4200rpm),
DVD/RW, Dynamix 8" screen, M2-ATX, Custom case,Too many hours building and rebuilding and rebuild.......
kpjuk is offline   Reply With Quote
Old 09-18-2006, 10:42 AM   #5
JohnWPB's Avatar
My Photos: (0)
Thanks Guys!
guino, as always thats for the quick reply and a sollution!
Thanks Kpjuk for the sample code! I appreceiate it, I just couldnt seem to get it to work here.
Thanks guys!
Sponsored Links
vB code is On
Trackbacks are Off
EniCar the RR Clone enitalp Software & Software Development 292 05-05-2008 05:28 AM
How About...A Virtual CD Changer chuckster Road Runner 30 09-30-2006 11:16 AM
Playlist and save bugs tolisn RR Bug Tracker 6 04-04-2005 11:16 PM
irman isn't loading any playlist peter3 Software & Software Development 9 02-11-2001 09:59 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
