09-28-2006, 12:33 AM
#1
Location: Raleigh, NC.... Nbi, Alpha quadrant (1 00 N, 38 00 E ) !!!
Vehicle: 1998 Range Rover
Interesting problem with iGuidance
09-28-2006, 01:10 AM
#2
SMKFree
Vehicle: VW Passat
do you have the gps com port in RR set to the same com port as IG ?
09-28-2006, 08:59 AM
#3
Yes...both are set to com 3...still does not work
09-28-2006, 09:02 AM
#4
You need to change it to something else. iGuidance will manage the com port on it's own.
09-28-2006, 09:24 AM
#5
SMKFree
Vehicle: VW Passat
thats the problem, that they are both set to the same com port.
AFAIK IG will not manage a com port on its own, you have to set it or scan for it, but once you do it once, it will remember.
What you need to do is either disable the com port in RRConfig, set it to zero
OR, do a search for xport which is a com port splitter. Xport will allow you to have multiple applications connect to the same gps device, by default gps devices only allow one connection to its port at a time.
When you split the com port you can then create virtual comports that have different numbers but all contain the same data. So you can RR, IG and other gps apps all running at the same time.
09-28-2006, 09:28 AM
#6
Yeah, that's what I meant.
09-29-2006, 09:23 AM
#7
Vehicle: 1998 Olds Aurora
To sum it all up... You can't have RR and IGuidance set to the same port. They will both try to access it and RR will win! So... just change the port in RRConfig and you'll be fine.
K301 7" Motorized Screen
Mini SLIMPRO SP625 Cappucino PC
RoadRunner / IGuidance 3.0
Pioneer 7700MP HU
MTX 1500D 1500 Watt Sub Amp
2 x 12" MTX 8000 subs
1998 Olds Aurora 4.0 V8
09-29-2006, 12:36 PM
#8
This worked guys....thanks a million
09-29-2006, 08:49 PM
#9
Yeah ditto.
Just installed my GPS receiver, IG, ran into the same problem. A Quick "Search" and bingo! All's good.
10-01-2006, 12:34 PM
#10
Vehicle: '05 Subaru WRX STi
Hey, in RRConfig, what is the "Window Name" for IGuidance? (Not the new 3.0, the older one)
Thanks for the help.
10-01-2006, 12:46 PM
#11
SMKFree
Vehicle: VW Passat
they are both the same
"iGuidance"
10-01-2006, 12:53 PM
#12
Seriously? Damnit, then I guess something else is going wrong.
Well, I'll try the com port and see if it does the trick. Thx
10-01-2006, 12:57 PM
#13
SMKFree
Vehicle: VW Passat
well the lack of a window name will not cause IG to not connect to the gps device. The window name is only used so RR can embed the correct app window.
10-01-2006, 12:59 PM
#14
I think what I was doing was opening an iguidance window first, then opening RR and wondering why it would work minimized, but not through the GPS button.
| Thread Tools |
| Display Modes |
Linear Mode
