Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 10-29-2006, 09:10 AM   #1
bruha is on a distinguished road
Powering XM Commander
I've been playing around with an XM Direct XMD1000 box and an XM Commander box (the same thing except it has FM modulator and external power). The XM direct gets it power through the 8-pin connector, while the XM Commander has an external connector to get its power.
Can I power the XM Commander through the 8-pin connector without hurting anything?
I think the problem people are having with the XM Commander boxes not working in RR might be how it gets powered, and I want to check without damaging my XM Commander.
bruha is offline   Reply With Quote
Old 10-29-2006, 10:28 AM   #2
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
I would assume you should be able to do it (if its based on the same box), however, I would look at some tech docs first -- if you don't have/can't read those, it would be something to ask the guys on the hardware sub-forums.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 10-29-2006, 12:28 PM   #3
The Last Good Gremlin
GizmoQ's Avatar
GizmoQ has a spectacular aura aboutGizmoQ has a spectacular aura about
The answer is unequivicably YES! I have Commanders in all my cars and it can be powered either way without damage. I ran mine for years off the USB.
Two things to note about the Commander: a) On the negative side, text is limited to 15 characters whereas the newer 1000s can do 32(or was that 30) characters. On the positive side, if you power it off the external with the FM modulator hooked up - you can use it with or without the carPC.
HARDWARE: Fujitsu Stylistic ST5031w/WiFi and dock, internal MP3Car 80G HD,, external 1TB HD, Sierra Wireless Aircard 550, DVD-RW, Silabs FM, WinTV USB, XM Commander w/Timetrax USB, Delorme GPS, Saitek X-52 joystick, BluSoleil Bluetooth, TPMS, FB, Elm327
GizmoQ is offline   Reply With Quote
Old 10-29-2006, 01:42 PM   #4
Ok, I powered it up and it works, but not in RR.
There is definitely something different between the two boxes, and RR doesn't like the Commander.
GizmoQ, have you ever had any success with running your XM Commanders within RR? I'm thinking about just buying a XM Direct box and transferring my activation.
Old 10-29-2006, 11:08 PM   #5
GizmoQ's Avatar
All the time! RR doesn't care if its a commander or an XMD, it doesn't see any difference in my boxes. They may have changed something in the newer commanders (I haven't bought on in over a year) but the trick for me was initializing the USB driver. Its been a while but it sometimes would initialize as an HID Device and I had to manually update that so it would come up as a serial port.
Otherwise, I know RR initializes the port at startup so I believe if you're running a fast PC or cut power to the Commander everytime you shutdown or both, RR is trying to initialize a box thats not ready. Try powering the external power connector, plug it into the commander, and run Timetrax to initialize it outside RR. Then close Timetrax, wait 10-15 seconds and run RR. Everything should work. I think I remember this issue once before, but since all mine are powered off the external connector it doesn't affect me.
Another benefit of using the external power connector and FM modulator (at least for me) is I get to listen to the last XM station tuned without the PC or Commander headunit just by dialing it in on the headunit.
Hope this helps,
Giz
Old 12-31-2006, 01:33 PM   #6
ramez75's Avatar
ramez75 is an unknown quantity at this point
Thats what i have installed http://www.cartoys.com/Default.cfm/p...XMDirect_Tuner. I wired it to my Car pc for juice. But how do find it on my computer. I went to device manager, tried to add a new hardware but i dunno if thats the right approach. So how can i make windows and/or RR so i can use XM. The hardware is there but i dunno what to do after that. Do i need to download a software, what com do i need to set, i was trying to find a thread other than than the FAQ one
Any input suggestions
Thanx
ramez75 is offline   Reply With Quote
FAQ: XM Cable/XMD1000 Debugging FAQ (test program included) pyros The FAQ Emporium 42 12-11-2009 02:36 PM
Got XM to work, then it took a dump DuDs StreetDeck 3 05-06-2006 05:42 PM
XM Satellite Radio to Unveil XM Advanced Services at 2006 Consumer Will Albers General MP3Car Discussion 2 03-27-2006 08:49 PM
Possible to split XM Direct cable to computer and XM commander? Jemmi General Hardware Discussion 3 12-14-2005 02:07 PM
Using an XM direct as an XMPCR dacndar General Hardware Discussion 20 10-17-2004 01:21 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
