Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 11-14-2006, 10:01 PM   #1
scottgs's Avatar
scottgs is on a distinguished road
Crazy Font problem? Please save me!
Ok, I'm a relative neubie here, but been fooling with RR for most of the year. I seem to be plagued with a display problem were the fonts seem like they're too big on most skins. In particular, I've been tyring iDrive (which is awesome, by the way, just like everthying about RR...) and it's like some fonts are too big and it pushes things off to the right, or cuts them off on the screen where new windows start. I have a similar problem with iGuidance 3 and UMPC, although it doesn't always manifest itself the same way.
I've tried everything I know of in the way of changing display settings, font size i.e. normal, large or extra large. I've verified screen resolutions, tried a couple different ones, and am currently using 800x600. I've also verified that the default windows fonts are installed. I know this has to be simple, but I just can't figure it out. I swear though, it just looks like some fonts are too big. I've been struggling with this for weeks, please help before I go insane!! or insaner...
Garret
scottgs is offline   Reply With Quote
Old 11-14-2006, 10:09 PM   #2
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
1-Make sure the DPI setting of the display properties is set to normal
2-Make sure you have the fonts propperly installed -- you can NOT extract the fonts directly into the windows\fonts folder -- you MUST extract them somewhere else first then COPY them in there so they're propperly installed.
Those are the two only things that could cause the fonts to not look right.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 11-14-2006, 10:11 PM   #3
Confusion Master
Enforcer's Avatar
Enforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant futureEnforcer has a brilliant future
Display settings -->settings-->advanced -->General.
check you display settings DPI, normally is 96 DPI.
Also check
Display settings -->Appearance-->Font Size is normal.
dammit guino got in before me, again.
Enforcer is online now   Reply With Quote
Old 11-14-2006, 10:11 PM   #4
EL CAMINO's Avatar
EL CAMINO is on a distinguished road
are you positive that all the fonts required by the skin are installed in your computer?,do you have a stripped down xp? some people do erase default fonts, another thing, almost all the skinners use some custom fonts be sure to have them properly installed.why dont you try the skin editor for more info on the skin.
EL CAMINO is offline   Reply With Quote
Old 11-14-2006, 10:23 PM   #5
scottgs's Avatar
DPI!!! I just remembered that back last December, when I started the project, I did reset that DPI to try and run native windows on a 7" Xenarc, before I discovered this forum. Then I had to leave home and drop the project for 7 months... How could I forget the DPI!
I had it at 115%. Rebooting now. Moment of truth is fastttttt approaching...
Old 11-14-2006, 10:40 PM   #6
scottgs's Avatar
YES! That fixed it! You guys are great. THANKS!!
Ok, now to figure out this red ball everytime I click and drag? and then the music/XM changes channels without even being on their window?
Old 11-14-2006, 10:41 PM   #7
Confusion Master
Enforcer's Avatar
You need to do a search for gestures and how to disable.
Old 11-15-2006, 12:43 AM   #8
scottgs's Avatar
usegestures=false . I figured it out myself just before I read you post Enforcer. I'm proud of myself.
Thanks again. This is incredibly nice software. I can't wait to get it all sorted out and installed. I'm aiming for next week for my carputer install. And I figure it will take the whole week
Old 11-15-2006, 10:13 AM   #9
Confusion Master
Enforcer's Avatar
This is only the start.
Mine went in over three years ago, and is still not finished. There's always something new to add on or change.
Not your typical flicker problem JPuma LCD/Display 17 05-30-2007 10:28 AM
Car Idle - power/amp problem? TheFaze Car Audio 1 12-16-2005 12:10 AM
had an all day (9 hr) problem at work.... wizardPC Off Topic 13 10-20-2005 12:50 PM
audio problem tiburonputer General Hardware Discussion 0 08-11-2005 04:58 PM
Lilliput TouchKit problem solved! AAVfReaK LCD/Display 2 10-16-2004 04:51 PM
