Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 11-28-2006, 10:33 PM   #1
iguidance GPS com port
Hi, i am using xport with iguidance and my gps antenna is hooked up to usb com port 8. i set my output com ports to 11 and 12 (11 iguidance, 12 roadrunner). It works fine, but every time i close iguidance it doesnt keep my selected com port saved, it resets to com1. How to i keep it set to com11? Thanks
shannara22 is offline   Reply With Quote
Old 11-29-2006, 01:42 AM   #2
Road Runner & Mp3car Gatherings Moderator
JohnWPB's Avatar
Vom port issues with iGuidance
I have had similar issues with iGuidance when I use a high numbered Com port. Check and see if you have com 1,2,3,4 or the lowest com port you have available, and set that Com port in Xport for iGuidance to use. I know this SHOULDN'T happen, but iGuidance is fickle, and this has worked for me in the past.
Front End of Choice: Road Runner (Is there anything else??? )
& Powered by the DigitalFX 4.0 Skin
Available at www.JohnWPB.com
JohnWPB is online now   Reply With Quote
Old 11-29-2006, 09:24 AM   #3
MySQL Error
MatrixPC's Avatar
IG only save selected COM port if it is under 10.
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Old 11-29-2006, 02:40 PM   #4
i had the same problem but then i swited IG port to 5 and its been working fine ever since
04 Accord Coupe Carputer
ajamils is offline   Reply With Quote
Old 11-30-2006, 11:08 AM   #5
cool.. I had the same problem.. looks like all my problems are miraculously fixing themselves..
1998 Toyota Camry LE
DWW-750FM
RR 11/2/2006,
IG3,
DELL Inspiron 4000
Carnetix p1900
drdream is offline   Reply With Quote
Old 12-04-2006, 08:23 AM   #6
i changed my iguidance com port to 6 and now it is remembering it. Thanks
Old 12-04-2006, 09:33 AM   #7
how can you get xport to route to a lower port number. I have options only for 11 and up.
hari-bhari is offline   Reply With Quote
Old 12-04-2006, 09:53 AM   #8
MySQL Error
MatrixPC's Avatar
You have to go into device mangler and re-assign one of the current COM port to a higher number so that a lower one can be grap by Xport.
I would suggest you change the COM port created by the GPS USB driver to higher port.
Iguidance COM Port issues! Cheekz185 GPS 9 03-27-2007 09:13 PM
Getting Started with GPS grepzen The FAQ Emporium 12 09-26-2006 05:54 AM
iguidance in RR cant find gps, but works outside of RR seanz0rz GPS 17 09-04-2006 12:33 PM
GPS Software with personal P.O.I. Iguidance? Or? claudioita Software & Software Development 1 08-17-2005 03:19 AM
how is iguidance compared to other gps software? emdzey01 GPS 3 05-25-2005 08:11 AM
