The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Thread Tools Display Modes
Old 11-29-2006, 06:28 PM   #1
miwise's Avatar
My Photos: (0)
Visualization and startup problems with roadrunner
Hi again everyone,
I'm using Roadrunner/bluedevil/standard windows xp, and I'm having issues with roadrunner. Here they are:
1st, when switching screens, the visualization (milk drop) gets hid behind roadrunner and doesn't return until I push a button on the player screen. After I do that, I can switch b/w any screens I want and the visualization will come back with no problem when going back into the player skin until I stop then restart the visualization again.
2nd, when I forget to turn off the visualization in roadrunner and hibernate upon ignition turn off, roadrunner locks up (but music continues to play and the mouse works) for about 5 minutes upon resume after the ignition has been engaged and windows comes out of hibernation. I can do nothing to roadrunner during this period, but I will eventually unfreeze if I wait. It only happens when I forget to turn off the visual, Milkdrop.
Lexus SC400/Factory Amps/Sub
HP/AMD 1.1 Ghz Mobile/Upgrade Imminent
512 RAM-DVD/7" Touchscreen
WinXP-Shelled to Roadrunner for now
Progress:
Software: Still trying to decide
Hardware: 95% done. . .need GPS
Installation: 90% done. . .clean up phase
miwise is offline   Reply With Quote
Sponsored Links
Old 11-29-2006, 07:00 PM   #2
My Photos: (0)
What version of winamp are you running. I was running the current version of winamp and had trouble with RR locking up periodically when loading it. I regressed back to the 2.9 on Guino's site and no problems sense.
1Munkey is offline   Reply With Quote
Old 11-29-2006, 07:23 PM   #3
miwise's Avatar
My Photos: (0)
Using winamp 2.9
Progress:
Old 11-29-2006, 09:43 PM   #4
Road Runner & Mp3car Gatherings Moderator
JohnWPB's CarPC Specs
JohnWPB's Avatar
Vehicle: 99 Mitsubishi Eclipse
My Photos: (0)
Visulizations in Road RUnner
It sounds like Milkdrop is not configured completely for use with Road RUnner. Did you select that as the Visualization in RoadRunner config? I am also using the Blue Devil skin (Duh! ) and have not seen this happen. If I start the visu, it will stay in place, if I go to another screen, and return to the player, it is still running and embed correctly.
On the 2nd part, I can offer no help there, as I do complete shutdown and restart with my CarPC.
CarPuter: 2.8Ghz P4 with 1 Gig Mem, 500 Gig HD, Iguidance 4.0
7" Motorized Touchscreen, XM PCR1000, Visteon HDZ300 HD
Radio, WIFI, Fusion Brain.
Powered By Road Runner & the DigitalFX 4.0 Skin www.johnwpb.com
JohnWPB is offline   Reply With Quote
Old 11-29-2006, 10:27 PM   #5
miwise's Avatar
My Photos: (0)
Tried several settings in milkdrop, no luck. I just tried AVS, and it works correctly. It seems to do the same thing on both my computers. I'm going to search the forum again now that I know it is primarily a milkdrop issue. Thanks! Good job on the equalizers. Just tried them out today.
Progress:
Old 11-29-2006, 10:42 PM   #6
miwise's Avatar
My Photos: (0)
Not the same problem, but it seems to have fixed my issue. I'll test it with the hibernation later.
Progress:
Old 11-30-2006, 09:42 PM   #7
miwise's Avatar
My Photos: (0)
OK, it fixed the screen switching problem where it wouldn't reload the vis upon switching screens, but not the hibernation problem in my car. It still locks up when coming out of hibernation. Trying to search again to see if I missed something in the forums.
Progress:
Old 12-02-2006, 11:12 AM   #8
RoadRunner Mastermind
guino's CarPC Specs
guino's Avatar
Vehicle: 04/Mazda/RX-8
My Photos: (5)
You should try two things: set the visualization to OTHER in RRConfig and type in: milkdro (without the P), then put this in your exectbl:
"ONSUSPED","CLOSEWINDOW;Milkdrop"
this *should* close the vis before hibernating for you, though just doing the first change may already help.
Road Runner,RR's Myspace
guino is offline   Reply With Quote
Old 12-04-2006, 10:08 PM   #9
miwise's Avatar
My Photos: (0)
I did the milkdro thing combined with other (I found a post you wrote in another article), but have not yet tried the other. I'll try it this week. Thanks!
Progress:
Old 02-25-2007, 08:32 PM   #10
megagoo's CarPC Specs
megagoo's Avatar
My Photos: (0)
"onsusped"? or "onsuspend" ??
also, if you're changing the window name of milkdrop to "milkdro" in the rr.ini, shouldnt you put that after the "closewindow"?
just so im covering my bases, i added all 4 possibilities to my exectbl:
"ONSUSPED","CLOSEWINDOW;Milkdro"
"ONSUSPEND","CLOSEWINDOW;Milkdrop"
"ONSUSPEND","CLOSEWINDOW;Milkdro"
because i was having the occasional freezes on resume from hibernate. i dont know which line is the correct but it seems to have worked in closing milkdrop upon hibernate. when i pop back in to rr after hibernate, milkdrop shows the song title, which of course it only does when you first start it, so im hoping those winamp/milkdrop freeze days are over which wouldnt be too bad considering ive only been using RR a week now
eddie
megagoo is offline   Reply With Quote
Sponsored Links
Old 02-25-2007, 09:11 PM   #11
megagoo's Avatar
My Photos: (0)
well nevermind. locked up again. i uninstalled a plugin called jumptofile or sometihng. maybe i'll downgrade winamp versions or re-install. running 2.95 now
Old 02-26-2007, 02:50 AM   #12
megagoo's Avatar
My Photos: (0)
actually maybe it did work. i thought i was outside of RR when i was in rrconfig. either i wasnt, or i had to reboot for everything to set itself and for that jumptofile plugin for winamp uninstalled... but now when i resume from hibernate, milkdrop isnt even running which i'm assuming thats how its supposed to be.
i still have all 4 of those closewindow lines in my exectbl but guino told me he meant to say "onsuspend" so i can safely take the other 2 out. i'm thinkin "ONSUSPEND","CLOSEWINDOW;Milkdro" is the correct line if i've named my vis "milkdro" as guino suggested
at some point this week after i've verified that its not locking up anymore on resume, i'll take out that closewindow line and see if thats the fix, or if uninstalling that plugin was the fix
Old 03-06-2007, 01:17 AM   #13
Goddy's CarPC Specs
Goddy's Avatar
Vehicle: Toyota Corolla 2.0 Sport Anniversary
My Photos: (0)
Im having the exact same issue with hibernate and milkdrop. Just never forget to close the vis before you shutdown the ignition
Goddy is offline   Reply With Quote
Old 08-30-2007, 09:27 PM   #14
warnockm's CarPC Specs
warnockm's Avatar
Vehicle: 2002 Subaru WRX
My Photos: (11)
This fix helped me. Is there a "turn on visualization" command for "ONRESUME" that will turn Milkdrop back on?
Progress - VIA EPIA SP8000 | 120 Opus Power Supply & Case | 1GB Ram | 120GB 2.5" Hard Drive | Bluetooth 2.0 | GPRS/3G | Wifi | Road Runner/LSX 2.0 (waiting for a day skin for 3.0) | iGuidance 4.0 | Lilliput 7"
warnockm is offline   Reply With Quote
Sponsored Links
vB code is On
Trackbacks are Off
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
