12-07-2006, 03:16 AM
#16
- the popup comes only one time @ start, and only for 2 seconds - on the other hand, this ocx is stable, and does not produce garbage with id3v2 tags (like RR, Zortam, etc), does not corrupt files and works like a charm. 4 all that i can endure the "ad".
- to get results, your files must have the proper id3v2 tag (but if somebody wants lyrics and his files but he named them track1...track2...then better think about it)
- no lyrics even with the right tags? Write your own search module!
- dont like it? stop trashing the thread and dont use it!
12-07-2006, 03:39 AM
#17
Super Moderator
- The ad popped up hera and I had to manually close it.
- I have all of my tags 100% correct. I have spent many, MANY hours over the past months making sure of that. With 18,000 songs, it was a tedious task! I also I did all this in id3v2 tags, then syncronized all that information into the v1 tags.
- It still is just getting like 2% of the songs I throw at it, and adding the lyrics.
- Thanks for all your work on this, but I guess I will just have to go with "option 4"
12-07-2006, 06:45 AM
#18
Not sure if people are trashing your thread. I think it is in the effort to make imporvements, brainstorming. I would be so sensitive about it. But if your app is "as-is" and you have no intention to develop any further, you may want to state that.
12-07-2006, 07:35 AM
#19
- the app is as it is. I wrote it 4 my needs and i share it, just in case somebody is interessted.
- guess why i made it modular? if somebody is really interested in it, he can use his favorite datasource and make a module 4 it. And maybe he is so generous to post it.
@johnwpb:
no lyrics? if they are not on the site, what are you expecting? if they are and the program does not get them, maybe you've found a bug, so let me know, fix it yourself...or take option 4!
@jeffreyd_tx:
brainstorming? most posters even dont know how it's working and start complaining. (the lyric site brings up an ad popup window on the first call, so why the hell is this the fault of the program?)
If there are serious proposals, improvements or bug reports, i am glad to know about - but just jelling "it finds only 2%..." is far away from that.
12-07-2006, 10:08 AM
#20
You'd have to using something stupid like an IE control get popups that way. I wrote a class that downloads web pages (without actually rendering them in IE) using the Winsock API, if you want it.
12-07-2006, 10:49 AM
#21
sure, but nobody released his superb solution before (or at least i couldnt find it), and that was from my point of view the easiest and fastest way...
- you dont have to use the ie control - just use your control and return the search result - you can do all that in the search module...
- if you want, i can also integrate your class, but i think all search modules must be changed then cause of the different interface.
12-07-2006, 11:11 PM
#22
Try this out. It will probably go a lot faster if you download the text of the page in VB and just use the scripts to parse it. Make sure you have a reference to MSWINSCK.OCX if you try to use these in your project.
12-08-2006, 05:54 AM
#23
Super Moderator
my 27 cents worth (Inflation)
@johnwpb:
Dude, I was trying to be nice in my last post, and even thanked you for your work. Well... I guess you did not see it that way.
Maybe the rest of us are wrong to make suggestions, report bugs and the like.
A VERY good suggestions was a couple posts back, that if you are offering no support for this, and it is released "As Is" then you should have made that very clear at the beginning as a simple statement.
When something is released, it is typical in these forums for people to make requests, and offer suggestions to improve upon whatever the item is. I have released scripts and skins myself, and have only been able to improve on them from suggestions from others.
In my case, your "plugin" locks my computer tight (3.2 Ghz machine), where the window can not even be dragged, the log stops and stays on one song for an EXTENDED amount of time, and crashes quite frequently. After all that it gets only about 10% of the lyrics at most when it does finally finished with what it was doing.
Lyrics are not available? sorry, thats not it, after running your plugin on a test directory, I ran Zortam on the SAME test directory, and it gets at least 75% of the SAME songs that yours gets maybe 10% of. (with the binary characters /unicode and clutter mixed in unfortunately)
My opinion, take the criticism from Liquid Smoke, myself and a few others and learn from it. We DO know computers, custom scripting and programming both inside and outside of RR.
Sure, when something is released, some people will blindly criticize the work that has went into something. But, if you decide to release something to the public, you better damn well be prepared for that and not attack people for their criticism or opinions!
Again, thank you for your work on this, and for sharing, next time, however, you should make it clear that you do not want criticism or suggestions on what you have done and then you will just have "Thank You" posts in your thread..
12-08-2006, 06:19 AM
#24
@deus ex machina:
thx, i will take a look at it
@JohnWPB:
please use zortam
12-08-2006, 09:52 AM
#25
SMKFree
nice attitude
12-08-2006, 10:58 AM
#26
New search module - copy the code 2 the new file "00_lyricsplugin.vbs" into directory searchmodules.
(JohnWPB asked 4 it, but he didnt know what 2 do or he was 2 lazy to do it ...  )
Code:
' search lyrics
'by Reflex 2006.12.08
Dim sartist,soldartist,stitle,bFound,sresult,serror
'Set oWscript = WScript
'Set oIe = CreateObject("Internetexplorer.Application")
'sartist = "Prince"
'stitle = "Kiss"
'Call searchtest()
Function searchtest()
Call search()
MsgBox sresult
End Function
Function dosearch()
serror = ""
sresult = ""
stitle = oSearch.stitle
sartist = oSearch.sartist
Call search()
osearch.sresult = sresult
osearch.serror = serror
End Function
Function sleep(ms)
owscript.sleep ms
End Function
Function search()
On Error Resume Next
sartist = LCase(sartist)
If InStr(stitle, "(") > 0 Then
stitle = Left(stitle, InStr(stitle, "(") - 1)
End If
oie.Navigate "http://www.lyricsplugin.com/plugin/?artist=" & Replace(sartist, " ", "%20") & "&title=" & Replace(stitle, " ", "%20")
iReset = 0
'While oIe.busy
Do While oie.ReadyState <> 4
Sleep 100
iReset = iReset + 1
If iReset > 1000 Then
Exit Do
End If
Loop
Sleep 500
If Len(oie.Document.body.innertext) < 130 + Len(sartist) + Len(stitle) Then
serror = "Song not found"
Else
sresult = LCase(oie.Document.body.innertext)
For i = 1 To 2
sresult = Right(sresult, Len(sresult) - InStr(sresult, Chr(10)))
sresult = Left(sresult, InStrRev(sresult, Chr(10)) - 2)
Next
End If
End Function
12-08-2006, 11:38 AM
#27
Quote:
(JohnWPB asked 4 it, but he didnt know what 2 do or he was 2 lazy to do it ...)
That's a funny one. Apparently you haven't been following JohnWPB's work on this forum. We all appreciate your work and willingness to share, but in one short thread you have managed to insult two of the biggest contributors to the forum - Liquid Smoke and JohnWPB.
12-08-2006, 11:56 AM
#28
SMKFree
eh, i could care less. I just asked a simple question about how it works. For some reason some people always think they are being attacked or criticized when they aren't. Im sure JohnWPB could easily just say the app was crap and that would be enough for a lot of people to just avoid it. Suggestions are made to largely help you or your efforts become better, they shouldn't be taken as insults or trashing your thread. But i do see you have a new search module now
| Thread Tools |
| Display Modes |
Linear Mode
