Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 12-30-2006, 03:50 PM   #1
miwise's Avatar
Volume control is buggy
Hi, I have a problem with the volume control. It started after switching b/w some skin files, but now it will not go away. The problem is that when I start roadrunner it sets the volume automatically to 40%, and I can't adjust it until I mute then unmute the audio. It works perfectly until I exit and then restart the program at which point the whole thing starts all over again
Lexus SC400/Factory Amps/Sub
HP/AMD 1.1 Ghz Mobile/Upgrade Imminent
512 RAM-DVD/7" Touchscreen
WinXP-Shelled to Roadrunner for now
Progress:
Software: Still trying to decide
Hardware: 95% done. . .need GPS
Installation: 90% done. . .clean up phase
miwise is offline   Reply With Quote
Old 12-30-2006, 04:05 PM   #2
MGD
MGD's Avatar
That is because of the 3 stage mute button. It will toggle between MUTE NORMAL VOLUME CONTROL and SPEEDATT VOLUME. To turn this of go into
RR.ini and change the line speedatt=false. True is 3 stage and Off is normal.
MGD is offline   Reply With Quote
Old 12-30-2006, 09:00 PM   #3
miwise's Avatar
Oh, OK. I guess that got set somehow in one of the skins b/c I don't remember setting that option. Thanks!
Progress:
Old 12-30-2006, 10:23 PM   #4
Ruffy's Avatar
i have problems with volume on my test/dev machines(laptop and desktop)
Simple things, like if Volume is already at 100% and i press volume up button the master volume level goes down to 0%, even tho the volume in roadrunner says 100%. if i go up it stays at 100%, if i go vol down it goes 95%.
Sometimes it does it regardless of where the master volume was set. If master volume was at 50% and i press volume up it goes to 0% pretty much muting.
Car : 00' Chrysler 300M
Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
Ruffy is offline   Reply With Quote
Old 12-30-2006, 10:35 PM   #5
PontiacGA's Avatar
I have the same problem. Plus the volume for the GPS doesnt change, even though I have it set at 70% when the GPS talks.
Mike
My Rides:
'03 Vibe GT!
My AED GA!
PontiacGA is offline   Reply With Quote
Old 12-30-2006, 10:47 PM   #6
Fusion Brain Creator
2k1Toaster's Avatar
The two posts above have the same solution. You need to map your RR/Winamp output to the correct line.
RRConfig, and then find the audio map area. Select Wave, Master, All or something that your system has. THen restart RR and that should be fixed. I have it set to the Wave output and I keep the master level around 5-10%. Wave between 5 and 20 percent. Good clean music. I suggest the same. Map to wave, and set master low. Escpecially if you are using onboard sound like moi.
Old 12-31-2006, 09:00 AM   #7
PontiacGA's Avatar
That fixed the first volume problem, thanks. But the volume still doesnt go down when IGuidance speaks.
Mike
My Rides:
'03 Vibe GT!
My AED GA!
Change behaviour Volume control DbXL Centrafuse 0 07-09-2006 11:09 AM
Roadie Volume Control tjp12100 FrodoPlayer 0 06-21-2006 03:30 PM
External volume control, knob, powermate, or something else? stimps Input Devices 3 12-10-2005 01:12 AM
Volume control in Xenarc 700TSV BMW-7 LCD/Display 3 04-06-2005 11:08 PM
hardware volume control ODYSSEY General Hardware Discussion 18 04-20-2001 10:43 AM
