The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Thread Tools Search this Thread Display Modes
Old 01-22-2007, 06:59 PM   #1
Fusion Brain Creator
My Photos: (0)
Full Support for Phidgets Interface Kit - Finished!
See attached, search the code for greenman100 if you like. meant to be compiled with 11-12-06 version.
button commands:
phigdonXX - turn on digital output XX
phigdoffXX - turn off digital output XX
Indicator:
phigdoXX - returns digital output XX state
phigdiXX - returns digital input XX state
greenman100 is offline   Reply With Quote
Sponsored Links
Old 01-24-2007, 04:48 PM   #2
My Photos: (0)
here's the roadrunner.exe
http://www.filefactory.com/file/a8ddc4/
Old 01-24-2007, 05:53 PM   #3
inh
Vehicle: 91 CRX Si
My Photos: (0)
good work man, now i just need my new car, a phidgets kit, and a carpc, so i can ditch the climate controls
inh is offline   Reply With Quote
Old 01-24-2007, 07:43 PM   #4
Road Runner & Mp3car Gatherings Moderator
JohnWPB's CarPC Specs
JohnWPB's Avatar
Vehicle: 99 Mitsubishi Eclipse
My Photos: (0)
Ok, I had no idea what a "phidget" was till I did a quick Google This looks like it could open up a pretty big world to the already amazing RR front end.
Has this been submitted to Guino, so it can become part of the official releases?
With a little research, I can see this used so many ways! Of particular interest is the Distance sensor Phidget to place on the rear of the vehicle for distance to an object when backing up. (Good for a range of just over 2 feet)
Now for a question
Can the input be turned into useful data with Road Runner? For instance the distance sensor, mentioned above, outputs a range of numbers from 0 to 500. Having that converted to the actual distance would be much more useful.
CarPuter: 2.8Ghz P4 with 1 Gig Mem, 500 Gig HD, Iguidance 4.0
7" Motorized Touchscreen, XM PCR1000, Visteon HDZ300 HD
Radio, WIFI, Fusion Brain.
Powered By Road Runner & the DigitalFX 4.0 Skin www.johnwpb.com
JohnWPB is offline   Reply With Quote
Old 01-24-2007, 08:43 PM   #5
My Photos: (0)
Now for a question
many of the sensors already support conversion through a tooltip:
Code:
Case "c2f" 'Show in C N = N - 200: N = N / 4 N = (N * 9) / 5: N = N + 32 GetPhid = Format(N, "0.0F") Case "f2c" 'Show in F N = N - 200: N = N / 4 GetPhid = Format(N, "0.0C") Case "volt" 'Show in V N = N - 500: N = N * 0.06 GetPhid = Format(N, "0.00") Case "50amp" 'Show in Amps N = N - 500: N = N * 0.1 GetPhid = Format(N, "0.00") Case "15amp" 'Show in Amps N = N - 500: N = N * 0.03 GetPhid = Format(N, "0.00") Case "gp" 'Show in Pressure N = (N / 4) + 10 GetPhid = Format(N, "0.00")
I could add code for the rest later, but I really need people to beta test the code to confirm it works before I submit anything to guino.
Old 01-24-2007, 09:28 PM   #6
inh
Vehicle: 91 CRX Si
My Photos: (0)
your code is for digital i/o not sensor reading, right? theres already commands in skin commands.txt for reading phidget sensor data. is it possible to do math and/or simple scripting in the skin files, or would that have to be output to a specific program for proccessing?
sorry for goin off topic, but yea, your code, digital i/o not sensors..
Space Navigator - 6 Axis input device: Take it apart - Driver App
RRCam - Video/webcam capture, text overlay, and recording: 2.0 Stable
Old 01-24-2007, 09:28 PM   #7
My Photos: (0)
Is the EXE still available? I can't get the above link to work, but I'd like to test out the Phidget integration.
bruha is offline   Reply With Quote
Old 01-24-2007, 09:36 PM   #8
inh
Vehicle: 91 CRX Si
My Photos: (0)
scrol abotu halfway down and click on 'Download for free with FileFactory Basic'
Old 01-24-2007, 09:52 PM   #9
My Photos: (0)
yes, this is jsut for digital i/o, analog is already built in.
the code above allows for predetermined conversions in the skin files. I could probably expand the functionality to do any sort of math.
Old 01-24-2007, 09:56 PM   #10
inh
Vehicle: 91 CRX Si
My Photos: (0)
Ah very cool i'll have to spend more time with skinning in RR.. using your addition, i can have a nifty lil setup that keeps my car at whatever temp i want
Sponsored Links
Old 01-24-2007, 10:06 PM   #11
My Photos: (0)
yup, already done this
Old 01-24-2007, 11:18 PM   #12
My Photos: (0)
here's my skin
Old 01-25-2007, 04:28 AM   #13
JohnWPB's Avatar
My Photos: (0)
WoW, I guess I should have done a little more research into this. I was not even aware that RR already was able to support an analog version of this.
I knew that RR was capable of simple conversion from Fahrenheit to Celcius, but was not aware that it extended to plugins (such as this one) as well.
I just need to take a step back and familiarize myself a little bit more, before asking such simple and redundant questions. I was acting so much like a newbee here! (NOT that that is a bad thing, as that is how we all learn).
Thanks for all the info!
This code is gonna add a lot of functionality to RR on top of what it is already capability of!
Old 01-25-2007, 11:38 AM   #14
pyros's Avatar
Vehicle: 2004 Ford Mustang Mach 1
My Photos: (0)
Any plans on adding functionality for the motor control kit?
Specs: Epia M2-1000, 512mb ram, SB Audigy NX, Lilliput 7" Touchscreen, M2-ATX, DVD, 160gb HDD, gps, obdII, wifi, bluetooth, XM radio, HQCT and Logitech wireless gamepad.
Install Status: DONE
My XM FAQ
pyros is offline   Reply With Quote
Old 01-25-2007, 12:16 PM   #15
My Photos: (0)
if people chip in to buy me one, I'd be happy to.
I can't test it or write code without one, though.
http://www.phidgets.com/index.php?mo...138.55&IID=112
$70.
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Try this out Full OBD II support jnafpas Engine Management, OBD-II, Engine Diagnostics, etc. 50 05-17-2007 06:32 PM
RR 08-02-05... SIRIUS Support ... guino Road Runner 76 03-09-2006 01:44 PM
RR 08-30-05 ... Ipod Support & Fixes ... guino Road Runner 41 09-09-2005 05:50 AM
RR 06-06-05 .. Winamp Library Support ... guino Road Runner 76 06-19-2005 12:36 AM
Radiator : not full support ? eldiablol13fr FrodoPlayer 2 03-19-2005 12:45 PM
Sponsored Links
Ad Management by RedTyger
