Go Back   MP3Car.com > Mp3Car Technical Software > Front Ends > Road Runner
Old 02-28-2007, 04:24 AM   #1
W3bMa5t3r's Avatar
Location: Washington, DC - Alexandria, VA N/W Area - NOVA
W3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of lightW3bMa5t3r is a glorious beacon of light
Thumbs up Road Runner Skin Installer
UPDATED MARCH 7th, 2007 / 5:56AM
SKIN INSTALLER: -=[ SCREENSHOTS - POST 3 ]=- Many Thanks go out to PlayerBeat for hosting the skins.
I know I talked about doing this back when I created the Road Runner Installer, Updater and Embedding Updater, but I kinda didn't follow through as I got very frustrated with the way some of the skins were laid out, the amount of editing required for some, etc... and got carried away in my own CarPC project (still in progress lol).
So, what I'm going to do, is use the more popular 'easy' skins, that don't require tons of editing, and use those. Like BAV2, Bongo, Zots Day, etc...
I figure the ones using this will mainly be newbies anyways, so they'll just be needing something basic to get them going. If you have a more advanced skin that you would like me to add to this, shoot it to me, but please have it well documented (a "Install.txt or ReadMe.txt" at the very least) so we're not trying to achieve this, nor the end users installing the skins...
The other option we have is this installer can install any skin, and if it requires more in-depth editing/configuration, just display the "Install.txt or ReadMe.txt" that would accompany each skin and let the end user finalize the setup.
I'll be updating this post/thread as the project progresses. Stay tuned...
DOWNLOAD THE ROAD RUNNER SKIN INSTALLER -=[ HERE ]=- version 1.0.0.0
Please let me know of any issues you encounter. If there is a skin you'd like added, just let me know. The installer is limited at displaying 10 skins per skinset, but you can select the 'SkinSet' to preview and install inside the program. See the SkinSets below.
Skin Info:
Bongo
Brushed_Aluminum_Version_2
TR-Blue
Pioneer
Zots.Day
Aero_Beta
FFS
CrystalBlue_Beta
CURRENT SKIN SERVER:
Code:
http://innovatedaudio.com/W3bMa5t3r/
DOWNLOAD SKINSET#.INI FILES (put these in the same folder as your RRSkinInstaller.exe, the installer comes with the first two)
You will be asked when running the program, which SkinSet you wish to use.
__________________________________________
SKINSET1.INI INCLUDES:
[config]
server=http://innovatedaudio.com/W3bMa5t3r/
skin_1=Bongo
skin_2=Brushed_Aluminum_Version_2
skin_3=TR-Blue
skin_4=Aero_Beta
skin_5=Pioneer
skin_6=Zots.Day
skin_7=_Cobra_2007_
skin_8=Fireskull
skin_9=SaabMFD
skin_10=XEON
SKINSET2.INI INCLUDES:
[config]
skin_1=FFS
skin_2=CrystalBlue_Beta
skin_3=Mustang_V1_BETA
skin_4=SilverSurfer
skin_5=Simplistique
skin_6=Triton
skin_7=
skin_8=
skin_9=
skin_10=
Check back here over time. Cheers...
W3bMa5t3r is offline   Reply With Quote
Advertisement Sponsored links
Old 02-28-2007, 04:25 AM   #2
W3bMa5t3r's Avatar
Skins to be used are rearchived to ensure folder layout, give a better archive filename, and to ensure maximum compression.
The program will detect the Road Runner skin location, or prompt you for the location. The cool thing is the skins are controlled by a "SkinSet#.ini" file.
Code:
[config] server=http://innovatedaudio.com/W3bMa5t3r/ skin_1=Bongo skin_2=Brushed_Aluminum_Version_2 skin_3=TR-Blue skin_4=Aero_Beta skin_5=Pioneer skin_6=Zots.Day skin_7= skin_8= skin_9= skin_10=
They reflect the skin's archive file names and also how the skin name's are displayed in the program. So if we wish to change the skins installed, you distribute a new "config.ini" file, ensuring the new archives are named and built correctly with proper folder layout, etc.
Running the program, if you try to install a skin that's been removed or is being updated, you will get a prompt telling you it's unavailable. If it's there, it will download it to the script directory, extract the archive and move it to the correct skin location with the correct skin folder name.
As with the Road Runner Installer and Updater, the file "7za.exe" is included for extraction processes. It is safe, it's the 7-Zip command line extractor. Also with the Road Runner Installer and Updater, if you get a Virus Alert, turn OFF advanced heuristic detection. These files are scanned by AVG with the latest updates. (You'll only see the "7za.exe" WHILE the program is running, otherwise it's embedded 'inside' the installer)
The program will give you a progress bar while downloading to let you know it's working, as most skins are 5-25MBs in size and may take a while to download depending on your connection. Once downloaded it will continue with the extraction and installation process. You will be informed if it was successful or not.
If the installation is successful and the skin includes a "readme.txt" or "info.txt" file, it will be displayed for you, to include those in the \readme\ subfolder some skinners create.
THE README INCLUDED
INSTALLATION PROCEDURE
[1] Install Anywhere, but preferably in your Road Runner directory,
i.e.
C:\Program Files\Road Runner\RRSkinInstaller\
[2] The SkinSet#.ini file controls everything. Check the thread for the latest server and skins/SkinSet#.ini files
available. The details for this are there.
[3] Run the program, if it detects the location of your RR install, you may proceed to select
and preview the skins and the install the one you choose. If your RR install location is not
detected, it will give you the option to set it. Once done it will continue as mentioned
above.
[4] The program will download and extract the skin you've chosen. Once done you will be
notified and the program will exit. If the skin includes a readme.txt or info.txt, that will
be displayed for you.
[5] Run Road Runner's Config.exe to set the new skin or if your current skin has a skin
browser, you may use it to set the new skin.
That's it... if you have any questions post them in the thread.
Please let me know if there are any issues.
Thanks and Enjoy,
The W3bMa5t3r
Old 02-28-2007, 08:22 PM   #3
W3bMa5t3r's Avatar
UPDATED: PLEASE SEE POST # 12
NEW SCREENSHOTS:
All skin names and the server it pulls the skins from are configurable by the "SkinSet#.ini" file. The screenshot will change with the selection of each skin, so you get a preview of the skin before downloading.
If you would like me to include your skin, please PM me. For the skins I'm including already, the creators are about to receive a PM asking your permission to distribute with this program and in this fashion. Thanks to all for helping out the RR community.
Cheers... The W3bMa5t3r
Old 02-28-2007, 10:34 PM   #4
Ruffy's Avatar
Ruffy is an unknown quantity at this point
hehe give it time.
I for one would welcome one. I installed the NSIS installer with the idea of creating an installer for my skin. Problem is its alittle complicated for what I want since my skin is just an addon/modification of a current skin.
Car : 00' Chrysler 300M
Speakers : Rainbow Audio SLC 265 | Subs : Diamond Audio D6 12" Subs X2
Amp's : Hifonics ZXi 6006 AB | Hifonics BXi 1606 D
CarPC: HP Laptop AMD Sempron 3000+ | 1.5GB RAM | DVD+RW | 80GB 5400RPM HD | ATI R200 Video
Ruffy is offline   Reply With Quote
Old 02-28-2007, 11:50 PM   #5
pRoFiT's Avatar
pRoFiT will become famous soon enough
Sounds good. The more programs for RR the better for the mp3car community.
edit: Maybe should have put this one more node out....RR Skins
Um, I guess this is where you put something witty.WITTY
My Web site, in the design stage. http://home.comcast.net/~cstrachn
Modified RRSkinEditor http://www.mp3car.com/vbulletin/rr-skins/65723-rrskineditor-bugs-fixes-comments-current-progress-outdated.html
pRoFiT is offline   Reply With Quote
Old 03-01-2007, 01:24 AM   #6
W3bMa5t3r's Avatar
Thanks Well it's just about done... I just need some volunteers to host the rearchived skins...
And yeah I wasn't sure about where to put it, but I guess the skins subforum would be more logical ... @ the mods, feel free to move it if you so choose
Old 03-01-2007, 05:55 AM   #7
Confusion Master
Enforcer's Avatar
Enforcer has a reputation beyond reputeEnforcer has a reputation beyond reputeEnforcer has a reputation beyond reputeEnforcer has a reputation beyond reputeEnforcer has a reputation beyond reputeEnforcer has a reputation beyond reputeEnforcer has a reputation beyond reputeEnforcer has a reputation beyond reputeEnforcer has a reputation beyond reputeEnforcer has a reputation beyond reputeEnforcer has a reputation beyond repute
Sorry, could you remove iDrive from that list unless it is just an installer for once they have downloaded it.
cheers.
E.
Enforcer is online now   Reply With Quote
Old 03-01-2007, 07:08 AM   #8
W3bMa5t3r's Avatar
cheers.
E.
Ah no, the installer pulls/downloads a rearchived zip of the skins (done for folder layout, compression, etc)... so I'll remove it
Cheers
Old 03-01-2007, 07:18 AM   #9
Confusion Master
Enforcer's Avatar
Cheers.
Old 03-01-2007, 07:24 AM   #10
Playerbeat's Avatar
Playerbeat is on a distinguished road
I can host them for you. Let me know and I'll set you up a ftp account later today.
7" TouchScreen Carputer
Rockford Fosgate 1501BD and Rockford 551s
12" MTX 9500 in a SS* or a 12" Brahma in a SS*
ZAPCO COMPONENTS in front and RFs in rear
2 YellowTops and a 200amp Iraggi Alternator
*Snell Shell box from nolteaudio.com
Playerbeat is offline   Reply With Quote
Old 03-01-2007, 03:48 PM   #11
W3bMa5t3r's Avatar
That would be great I'm heading in to work soon so once there I'll figure out a skin to replace the iDrive skin for now and get the program for ready for testing/release. I just have one additional feature that I'm trying to work out (lol actually while writing this post I thought of another thing I want to add, so make that two more features )..
Anywho... thanks mate...
The W3bMa5t3r
See Posts 2 & 3 for updated information. Skinners, if you'd like me to use your skin in this, PLEASE shoot me a PM. Thanks to all.
Cheers, The W3bMa5t3r
Old 03-02-2007, 08:05 PM   #12
W3bMa5t3r's Avatar
Okie Doke, the RR Skin Installer has been released (see the first post). Let me know what you all think or if you encounter any issues. Cheers.
/edit: Also, if you'd like me to add your skin, shoot me a PM. Thanks...
THE NEXT GEN SKIN INSTALLER (If you downloaded the old, please grab this one, it fixes a few bugs and is just plain better)
Ok, the new version has been uploaded and is now available. It'll be the same link as in the first post.
Changes:
1. Fixed a bug that was pushing CPU usage to 100%. The program now uses next to nothing.
2. Completely rebuilt the GUI. You can now select the different skinsets inside the program and see the changes. Preview and install all the skins without having to exit the program. Progress bar and dynamic text inform you of what's occurring.
3. Changed the skinsets to hold 10 skins per.
Hope you all enjoy. Cheers.
Old 03-04-2007, 11:00 AM   #13
W3bMa5t3r's Avatar
How's this working for everyone that's downloaded and used it? Comments/Suggestions/Gripes? LMK... Later...
Old 03-06-2007, 04:56 AM   #14
W3bMa5t3r's Avatar
Skinsets updated. Download the two in the first post and drop them in your Skin Installer folder or copy & paste the contents into the two in your folder.
Cheers.
Old 03-07-2007, 10:57 PM   #15
lxt_123 is an unknown quantity at this point
is it my computer or the link with RR Skin Installer is not working?
lxt_123 is offline   Reply With Quote
iGuidance NATIVE in Road Runner skippy76 Road Runner 218 05-01-2007 01:10 AM
DVD not working with road runner miwise Road Runner 17 10-21-2006 03:20 PM
Road Runner Skin Editor rikblacketer Software & Software Development 1 10-17-2006 06:30 PM
Road Runner not loading multiple directories. xmadcowx Road Runner 2 10-16-2006 11:10 AM
Road Runner Skin web Folder maxzor RR Skins 3 08-09-2005 08:24 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
