Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Old 03-02-2007, 01:55 AM   #1
VENDOR - SpatialMinds
millec's Avatar
millec
Integrating my Nav Software
Hi,
I've written a navigation package that I'd like to integrate embed inside of RoadRunner. I've read through the FAQs but am still unable to get my system work with RoadRunner. I was hoping someone might be able to help.
I have edited the external GPS section in RRConfig to point to my application's exe. I have included the window name as well. When I start the application via RoadRunner I get a variety of odd results including:
- Text output to the name of one of my C++ files used to create the program
- The directory that the exe lives inside (Eg. c:\vault\mynav\Release).
Are there particular requirements that my application must meet to be "embedable"? Right now it is designed to run full screen with no borders (root window is WS_POPUP).
Any suggestion you might have would be very helpful.
Regards,
Craig
millec is offline   Reply With Quote
Old 03-02-2007, 03:10 AM   #2
jonessc's Avatar
jonessc is an unknown quantity at this point
Hi,
You need to create an application area on the skin that you want to embed the program onto, youll get the idea from these 2 posts...
http://www.mp3car.com/vbulletin/rr-faq/52568-how-do-i-launch-application-its-own-skin-screen.html Launching applications from ANY skin/screen in RR
http://www.mp3car.com/vbulletin/rr-faq/45526-how-embbed-any-application-rr.html To embbed an application
put this on the button that calls for your satnav program
this is an example for my satnav using iguidance:
LOAD;iguidance.skin;GPS;c:\Program Files\iNav\iGuidance Europe\iGuidance.exe;iGuidance",""
this is contained in the iguidance.skin, which is where i am embedding the sat nav software:
A01,204,42,596,516,192
ive attached the 2 skin files, so you can have a look at the code, and change them to work with your program.
Have Fun!
File Type: rar iguidance.rar (651 Bytes, 41 views)
File Type: rar gpsselect.rar (487 Bytes, 53 views)
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
jonessc is offline   Reply With Quote
Old 03-02-2007, 11:06 AM   #3
millec's Avatar
millec
Thanks for the help. I'll read through the links. I'm a bit confused why I would need to modify a skin. In the past I've embedded a variety of external Nav systems just by changing the "external app" GPS settig in rrconfig. I've used USGS Topo, DeLorme TopoMap USA, and Freedrive w/o having to modify my current skin. I believe my application is doing something that is preventing it from running correctly.
My application was designed to automatically run as a full screen window, and if it was smaller than the screen size to run centered on the screen. By full-screen window I mean that it is a borderless window, always on top, that occupies the full size of the screen (not full-screen mode like a game). I noticed that RR runs in the upper left hand corner when it is running smaller than the current screen size. Rather than just experimenting around to figure out how my app should behave to be compatible with RR, I thought I'd ask so I know that I have a clear understanding of the requirements.
Thanks,
Craig
Quote: Originally Posted by jonessc View Post
Hi,
http://www.mp3car.com/vbulletin/showthread.php?t=52568 Launching applications from ANY skin/screen in RR
http://www.mp3car.com/vbulletin/showthread.php?t=45526 To embbed an application
Have Fun!
Old 03-02-2007, 11:26 AM   #4
jonessc's Avatar
the way your talking, it should also work, i find it more efficient to have a seperate skin for each nav program, for example i run tom tom, freedrive, iguidance but the only program that i have specified in rrconfig is "freedrive" with the "external" selected.
each satnav i use has a skin, like the files i attached for example i have a button with this code:
"LOAD;iguidance.skin;GPS;c:\Program Files\iNav\iGuidance Europe\iGuidance.exe;iGuidance",""
it will then embed the prog into iguidance.skin
Iguidance.skin has the following code to define how its going to embed:
A01,204,42,596,516,192 (this is the application size parameter)
C01,204,42,596,516,192 (This is the clipping area)
This works fine for me, you may also want to check if you have the program details defined correctly, so it knows what program it is embeding into skin, attach your skins if you want me to take a look
My application was designed to automatically run full-screen, and if it was smaller than the screen size to run centered on the screen. I noticed that RR runs in the upper left hand corner when it is running smaller than the current screen size. Rather than just experimenting around to figure out how my app should behave to be compatible with RR, I thought I'd ask so I know that I have a clear understanding of the requirements.
Thanks,
Craig
CarPuter Progress:
Old 03-02-2007, 11:37 AM   #5
millec's Avatar
millec
Yeah, I'm updating my software now to run either as a normal window or in it's custom fullscreen window mode if it is running stand-alone. Hopefully that will do the trick.
Thanks again for the reply. Seeing how it passes a size and a clipping region reassures me that I'm on the right track.
Old 03-02-2007, 08:28 PM   #6
jonessc's Avatar
CarPuter Progress:
Old 03-02-2007, 08:52 PM   #7
Raw Wave
ShawJohn's Avatar
ShawJohn is on a distinguished road
care to tell us more about your nav software?
ShawJohn is offline   Reply With Quote
Old 10-10-2007, 03:30 AM   #8
millec's Avatar
millec
Sure...
http://www.overlandnavigator.com
Mods, if this is a violation of the terms of use, please delete the post. My intention isn't to spam anyone.
Old 10-10-2007, 07:26 AM   #9
Raw Wave
ShawJohn's Avatar
Nice! Are those OS Landranger maps, kind of like OZi Explorer & Memory Map Navigator?
How do you stop it trying to route people down footpaths and bridalways, some UK satnavs units are a ****er for that. The GF's TomTom700 sent me down an unamed road which rapidly turned into a dirt & cobble bridalway in my lowered Nissan 200sx. This 'road' was tight and after dark had no street lighting, became very narrow and bumpy and impossible for me to turn round, and too dark to reverse... So I had to take a chance and carry on, nearly wrecking my car in the process, and another time when it wanted to take me through the private roads on a farm as it was a short cut, the farmer wasn't amused though
Maybe one day, the maps will have road restrictions like weight, width and height restrictions, low bridges etc to make routing safer and more reliable for folk in unusual vehicles.
I beleive TomTom are working on TomTom Commercial, a kind of Truckers version of a TomTom. Not sure how far off that is though.
Old 10-10-2007, 08:40 AM   #10
Valheru's Avatar
Valheru is an unknown quantity at this point
millec ... I think your issue is that your program runs in a borderless window with no title bar. RR geerally uses the title bar text to embed the app into RR, and as your program does not have one it won't embed properly.
You can however use the window class name from you app - the calss name can be found using WinSpectorSpy freeware ... There are many threads here referring to embedding apps using the window classname.
One other thing you might want to look at is the fact that your app is set to autocenter and always remain on-top .. these two prperties MAY interfere with the correct functioning of RR ... thus preventing you from using RR while your app is running ...
Valheru ...
Valheru is offline   Reply With Quote
Old 10-10-2007, 10:16 AM   #11
millec's Avatar
millec
Valheru,
Thank you for the helpful reply. I was able to resolve the issue a couple of months ago and it works great with RR now.
Craig
Old 10-10-2007, 10:23 AM   #12
millec's Avatar
millec
The maps began life as USGS Topographic Map Quads. They were fairly heavily processed before they made it into the product.
Overland Navigator doesn't support routing right now, although it will in the future. The target audience right now is back-country enthusiasts. Hunters, Fisherman, Campers, Geocachers, etc. This group usually creates a GPS Track in a GPX file of their planned route before they leave home. Should they be *exploring*, they usually record where they have gone so they can find their way back. Still, automatic routing is useful and I hope to add it as things progress.
We should start a new thread somewhere though, as this isn't Road Runner related (Beyond the fact that I tested and verified that it works with Road Runner).
Voice nav on xenarc 700idt? hotponyshoes General Hardware Discussion 0 11-08-2005 03:03 AM
Any nav software updates over internet? pip GPS 4 11-06-2005 12:50 AM
Best nav software for use in the UK? l9nux GPS 6 09-10-2004 10:27 AM
??? 3d GPS nav software for the US ??? AVmobile Software & Software Development 6 01-06-2004 12:32 PM
My numpad controlled custom MP3Car software - need your opinions PorscheMP3 Software & Software Development 7 04-11-2002 11:30 AM
