The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner
Thread Tools Display Modes
Old 03-24-2007, 01:53 PM   #1
My Photos: (0)
Strange RR problem with auto day/night switching
I have auto skin and gamma switching enabled in RR, setup using an alternative config program posted on this forum. Settings in RR.ini are like this -
gammamode=2
autogammamode=1
autoskinmode=1
gpsgammamodeoffset=0
gammadaytime=08:00
gammanighttime=18:00
gammaday=0:0:0
gammanight=-50:-50:-50
The auto switching is setup to change between day and night settings at the set times. However, whenever RR changes between the day and night skins and gamma, the screen becomes corrupted, and a large grey rectangle appears in the top left of the screen (see screenshot below). This disappears if you change the RR screen (e.g. to music), but when you minimize RR it's still there, and comes back to the top every time the day/night change is activated. When you close RR, the rectangle disappears, otherwise no amount of minimizing RR or refreshing the desktop will get rid of it. The letters "RAN" appear in the middle of the rectangle, in yellow text.
Any ideas how to get rid of this window? It seems as if the VB code is opening up a form it shouldn't be.
See the attached screenshot for a picture of what I mean.
hellodave is offline   Reply With Quote
Sponsored Links
Old 03-24-2007, 01:59 PM   #2
My Photos: (0)
Having had a brief look at the RR source code, the form called "frmSkin" looks like the most likely culprit - it's grey, and the correct size.
Any ideas why this would randomly appear?
Screenshot -
Old 03-24-2007, 03:10 PM   #3
john1701's Avatar
Vehicle: 2001 Ford Crown Victoria
My Photos: (1)
got the same prob also. good so it just wasnt me.
CAR:2001 Ford Crown Victoria
PC: Dell 600 NoteBook with Vista
CPU:specs
Memory:1G
Drives:usb 250gig
WI-FI:Cingular
misc:inverter 300w
GPS:IG 4
Screen:Xenarc 700TSV
The Florida Meets Thread
Simple Fix to Road Runner and Vista
john1701 is offline   Reply With Quote
Old 03-24-2007, 03:38 PM   #4
Confusion Master
Enforcer's CarPC Specs
Enforcer's Avatar
Vehicle: 1997 BMW E36 328I
My Photos: (1)
This may be way of base, but check to see if you have a wait.skin.
Enforcer is offline   Reply With Quote
Old 03-25-2007, 11:50 AM   #5
My Photos: (0)
Yup - I'm using BAV2 as my day skin and BMV2 as my night skin - both have a wait.skin
Old 03-25-2007, 02:01 PM   #6
wizz's CarPC Specs
wizz's Avatar
Vehicle: 03 Focus Zetec
My Photos: (0)
Are you sure you have set the Config up correctly ? Are you using the Skippy config, and are you trying to change the Gamma or the Day/Night skin ?
See this thread and in particular my post #22
http://www.mp3car.com/vbulletin/road...ing-skins.html
Car : Ford Focus Zetec 1.6
Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
BU303 GPS/Mercury 11b WiFi/Parking Sensors
Colour I/R Reversing Camera
wizz is offline   Reply With Quote
Old 03-25-2007, 06:41 PM   #7
My Photos: (0)
I'm using the same config as you show in that thread (I assume it's Skippy's?). I've got it set to change both Gamma and skin fully automatically, currently via GPS.
Old 03-26-2007, 01:08 AM   #8
wizz's CarPC Specs
wizz's Avatar
My Photos: (0)
Yes it is Skippy's. Why don't you try just one, say changing the skin and not the gamma because that's the most important function, and see if that stops the problem.
I'm using BMV2 and do just that, and I have no problems with it. I use the same BMV2 skin for both day and night, one being re-coloured for day use.
Old 03-26-2007, 03:13 AM   #9
My Photos: (0)
I do need to change both skin and gamma, otherwise everything is too bright at night!
I'm trying a different workaround at the moment - I'm not sure what frmSkin.skin is used for, but I've resized it to nearly nothing in VB and recompiled RR. The resulting program seems to run OK so I might try it out over the next few days and see what happens. It's not exactly a brilliant solution, but it might suffice until someone finds out what (if anything) is wrong with the day/night switching code.
Old 03-26-2007, 06:55 AM   #10
djmickyg's Avatar
Vehicle: 2006 Ford XR6 Turbo Ute
My Photos: (3)
i had the same issue..
i ended up tunrning it off and going back to gammacontrol. which also does freedrive.
djmickyg is offline   Reply With Quote
Sponsored Links
Old 03-26-2007, 11:37 AM   #11
Chuck's Avatar
Vehicle: 2001 Chevy S10 ZR2
My Photos: (0)
I had the same exact box happen to me at 4:30 am.
The strange thing about it is I made my own day night change for my internal skins and it uses an autoit script to change the skin.
So it cannot have anything to do with Skippy’s stuff in my skin.
The only thing I can think of in my case coming out of hibernating then switching skins right away is causing this.
And the only RR command I use for this is reloadskin.
Code:
EDIT Added my RR code the autoit will send DAYSKIN or NIGHTSKIN "DAYSKIN","BYVAR;VOICESAY;<<SAY; day time||SAVETOSKIN;WHATSKIN;0||BYVAR;SDAY;SAYDNSETUP<<SKIN1<<SKIN2<<SKIN3<<SKIN4<<SKIN5<<SKIN6<<" "RUNSKIN1","CLOSECHUCKSTOP||CLOSETOPCLOCK||SETVARBYCODE;LASTSCREEN;RRSCREEN||BYVAR;SKIN1COLOR;SAVETOSKIN;COLORPICK;0<<SAVETOSKIN;COLORPICK;1<<SAVETOSKIN;COLORPICK;2||SAVETOSKIN;THISSKIN;1||RUNQW;$SKINPATH$DAYNIGHT.BAT|0||RELOADSKIN||STARTTOPCLOCK||STARTCHUCKSTOP||SETCOLOR||LOAD;$LASTSCREEN$"
2001 S10 ZR2
Chucks Skin
Chuck is offline   Reply With Quote
Old 03-27-2007, 02:29 AM   #12
My Photos: (0)
After changing the size of frmskin.frm to 6px*6px in VB and recompiling RR, the size of the evil grey rectangle has changed accordingly - it's now a tiny square in the top left of the screen, which I can live with. No problems yet; possibly this form is used by part of RR I don't have enabled, e.g. Phoco.
Old 03-27-2007, 10:31 AM   #13
Confusion Master
Enforcer's Avatar
My Photos: (1)
frmskin is the main skin form, it's where any screen you see in RR is painted.
if you see the box you are seeing it means that for some reason RR has not been able to load the graphics onto the screen it is trying to load.
Old 03-27-2007, 10:41 AM   #14
RoadRunner Mastermind
guino's CarPC Specs
guino's Avatar
Vehicle: 04/Mazda/RX-8
My Photos: (5)
The only reason that would show up is if the skin path is wrong or the requested skin is damaged/missing. RR has a prevention to warn of the problem when FIRST loading but not on skin changes cause it assumes the skin and path are correctly setup.
Road Runner,RR's Myspace
guino is offline   Reply With Quote
Old 03-27-2007, 01:41 PM   #15
My Photos: (0)
Strange - I can switch day/night skins manually with no problem. The night skin does load when switched automatically, but the grey box appears on top of it.
Sponsored Links
vB code is On
Trackbacks are Off
RR 03-06-06 AVS problem mauri Road Runner 18 04-08-2006 11:40 PM
Any news about my strange problem? RR and Girder slimmegane Road Runner 6 07-11-2005 11:52 AM
Auto load FD when RR starts up tolisn Road Runner 2 07-08-2005 04:30 PM
RR loading screen when I press Day/Night.. Nighcrawler Road Runner 3 05-18-2005 10:09 PM
status update.... 0l33l PowerVoice 17 05-05-2005 12:22 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
