Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Bug Tracker
Old 04-27-2007, 12:06 AM   #1
Sirius shows mp3 list-xm logo , not channels
I cant figure this out (screen shots below).
When I click the sirius button in either skin RR shows the XM banner and my mp3 play list and does not tune sirius channels.
My sirius connect is on com5 and works with sirius recorder.
Steps I have taken.
upgraded RR using auto updater.
uninstalled RR and installed manually
uninstalled RR and auto-installed/updated
deleted and re-installed skins each time
used both the usb driver that came with sirius connect and the latest from the web
updated flash player
updated windows
HELP!
Intermission....
sentiensx is offline   Reply With Quote
Old 05-07-2007, 03:36 PM   #2
I am having the same issue, did you get it sorted out?
kegbus is offline   Reply With Quote
Old 05-08-2007, 06:21 AM   #3
Road Runner & Mp3car Gatherings Moderator
JohnWPB's Avatar
Quote: Originally Posted by sentiensx View Post
Steps I have taken.
updated windows
HELP!
A couple things you did not mention. Did you change the settings in RRConfig? You have to put a 0 for XM port in there, and the port that your Sirius device is on for Sirius.
Secondly, you need to open the menu.skin in notepad, and find the line with XM in it, and change it to "SIRIUS".
For the BMV2 skin it would be this line:
Code:
B06,11,305,339,106,"XM",""
and change to this line:
Code:
B06,11,305,339,106,"SIRIUS",""
Hopefully that will get you guys going.
Front End of Choice: Road Runner (Is there anything else??? )
& Powered by the DigitalFX 4.0 Skin
Available at www.JohnWPB.com
JohnWPB is offline   Reply With Quote
Old 05-09-2007, 01:34 AM   #4
Yes, XM is set to 0 and Sirius is on com 5 and set that way in config and confirmed in ini. I tried renaming the xm skin to sirius at one point and that just changed the xm logo to the sirius logo.
OK, That totally worked and now RR totally ROCKS!! Changing the menu.skin fixed it.
Was that a total newb mistake on my part or what? I didn't see that documented anywhere.
One thing though, now the play list is correct and it friggen works so I dont really care too much but the sirius logo is gone from the upper left.
JohnWPB -Thank you so much!!! I had all but given up. Spent a whole weekend working on this.
Old 06-05-2008, 12:51 AM   #5
Sentiensx,
I am having the same issue. Sirius works in RR but it is saying that it is not activated and to call the number. Which when I open up satamp it shows all the channels and works perfectly. Do you know what I am dong wrong?
Cameron
cameronlazzari is offline   Reply With Quote
SIRIUS vs Xm antennas... the same..? Tim97rs Newbie 15 09-04-2005 04:05 PM
XM screen shows mp3 list wysocki RR Bug Tracker 2 08-17-2005 09:24 PM
XM + MP3 -> Amp....how? MikeH MacCar 6 04-28-2005 07:41 AM
MP3 list Tha Hombre MediaCar 3 01-19-2004 06:09 PM
