The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Bug Tracker
Thread Tools Display Modes
Old 09-24-2007, 07:49 PM   #1
crooper's CarPC Specs
crooper's Avatar
My Photos: (0)
Screen resolution awry when set to "default"
When using the current RR Config program I find that if I don't manually set the screen resolution/refresh EVERY time I open the Config program, it sets RR to a "default" of 1920x1200x32 (or something like that) and my Xenarc can't handle it (unintelligible lines across the screen). This is especially problematic since I have RR in the startup folder so it'll start with Windows. It requires a Safe Mode boot to fix the problem.
Anybody else get this?
crooper is offline   Reply With Quote
Sponsored Links
Old 09-25-2007, 09:32 AM   #2
wizz's CarPC Specs
wizz's Avatar
Vehicle: 03 Focus Zetec
My Photos: (0)
Try setting resolution in general.ini file in your skin.
OriginalWidth=800
OriginalHeight=600
ShowWidth=800
ShowHeight=600
ie.
Original to the original resolution of the skin / Show to the resolution you want it to be.
Car : Ford Focus Zetec 1.6
Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
BU303 GPS/Mercury 11b WiFi/Parking Sensors
Colour I/R Reversing Camera
wizz is offline   Reply With Quote
Old 09-25-2007, 12:09 PM   #3
RoadRunner Mastermind
guino's CarPC Specs
guino's Avatar
Vehicle: 04/Mazda/RX-8
My Photos: (5)
do you actually need RR to set the resolution for you ? cause you could look for the
"resolution=" in RR.INI and remove it.. but it could be an issue with the config.. I haven't tested it, but it should not save the resolution= line to the INI if it's set as "default".
Road Runner,RR's Myspace
guino is offline   Reply With Quote
Old 09-25-2007, 12:41 PM   #4
Raw Wave
Blue ZX3's CarPC Specs
Blue ZX3's Avatar
Vehicle: 01 Ford ZX3
My Photos: (16)
I guess I'll speak up, that WAS an issue with the config that was issued with the last RR release, but if you go and get the latest config, it won't happen.
@wizz
FYI, those settings only apply to the skin part, his problem is the actuall reslolution that the screen is using.
Blue ZX3 is offline   Reply With Quote
Old 09-25-2007, 04:13 PM   #5
crooper's Avatar
My Photos: (0)
Thanks Blue ZX3! I thought I had the latest version, apparently not.
Sponsored Links
vB code is On
Trackbacks are Off
T3 screen resolution and Infill Station irdrive Infill T3 4 05-08-2007 12:42 PM
need help to set up touch screen !!!!! choier1983 LCD/Display 2 03-29-2007 08:45 AM
Lilliput 70NP flickers when I set resolution to 800x480. Please help! zac_haryy LCD/Display 5 02-13-2006 08:51 PM
touch screen resolution problem dugg35 Newbie 4 08-25-2005 12:20 AM
Screen resolution futuresweets10 General Hardware Discussion 5 01-18-2005 01:16 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
