11-03-2007, 10:44 AM
#1
Vehicle: 2005 Chrysler 300
New iList Bug/bmp mode
With the newest RR 11/02/07, I have a strange problem now. When I select the unsel.bmp, sel.bmp the list is totally empty. I can click in it and it changes the playing song. If I select the transparent.bmp the list shows up with the fonts jagged, whereas in the browser skin the list behaves as it should. See the attatched screen shots.
11-04-2007, 11:25 AM
#2
RoadRunner Mastermind
Vehicle: 04/Mazda/RX-8
Well, I forgot to mention this thing.. in order for Transparent iLists to work, I have to disable the "standard" anti-aliasing of fonts normally used in Windows -- meaning: most fonts will loose some quality, but hopefully, not too much (will greatly vary with the font used).
The issue with your first iList I think is because you're trying to use the same BMP for two parameters (endbmp = unsel.bmp as well) -- this may be breaking the initialization of the iList since the file is already in use for the unsel BMP. You can probably just copy the file to some other name to prevent the issue.
Road Runner,RR's Myspace
11-05-2007, 09:00 AM
#3
Well, I tryed that too with a seperat end.bmp file. No matter what I do in the Audio_Player.skin, the iList is just not showing anything.
11-05-2007, 10:16 AM
#4
I'll test it right now (waiting on the airport anyway) -- You should not use the SD definition in the Audio player, unless you use a folder list in there as well.. in any case, place the IL definition BEFORE the S definition to try it out -- this is the "intended" way for it to work.
11-05-2007, 10:29 AM
#5
Got it Guino, I was missing a color definition in the my S definition.
Thanks for your great work.
11-05-2007, 10:33 AM
#6
was just about to say it worked as it should in my tests.. thanks for trying again :P
11-06-2007, 05:17 PM
#7
Will there be any way for the initialising to be enabled with transparent ilists? The sharp jagged text is a pet hate for me. Lol
11-07-2007, 11:25 PM
#8
anti-aliasing with transparent ilists will not be possible simply because it makes the transparency stop working right -- and instead of showing jagged edges it shows darkish-pinkish dots all around the fonts.
| Thread Tools |
Search this Thread |
| Display Modes |
Linear Mode
