bug with playlist and line-in plugin
I found a problem with the latest releases of Roadrunner, if you use the Line-in plugin for Radio...
To recreate the problem:
1:Set up Roadrunner to use the line in plugin for radio.
2:Load a small playlist (like 15 songs or so).
3:EXIT Roadrunner, and start it again
4:Load a much larger playlist (more than 15 songs).
5:Go to Radio, and then back to Audio.
The playlist will be truncated to 15 songs (or whatever you had when you quit Roadrunner)
Had this on 3 different installations, all uses Winamp 2.95 and all uses HCQT Radio. Tried with the latest version of Roadrunner 11-02-2007 with same result. Tried with different skins including BMV2, same...
Can someone please verify that this is indeed a problem...
