Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Bug Tracker
Old 11-08-2007, 06:40 AM   #1
djtaz is on a distinguished road
Internet Explorer wont close
Ok , this is a new one i haven't seen a bug for anywhere so ill post and see if anyone has come across this before.
Pretty much everything on RR is now working for me since i went back to XP from vista (i refuse to use a capital for that) except one problem i have discovered.
When i open an internet page all works ok , until i go back to the main RR screen and IE stays open and on top. I can move it and it moves fine and i can Alt+f4 and it closes, which is ok for me , but for anyone else using the system it seems a bit complicated.
Has anyone seen where IE wont close before ?
Thanks in advance and a great job with RR everyone
djtaz is offline   Reply With Quote
Old 11-11-2007, 09:37 PM   #2
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
You can set the button code to exit the screen to "CLOSE" and it should close it, otherwise, you can make it "CLOSEWINDOW;Microsoft Internet Explorer||EXIT" and it should also close it before exiting. There's also a web plugin which works a little better than IE by itself.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 11-12-2007, 04:56 AM   #3
Thanks Giuno ,
I am using the plugin for it - in fact im using the default skin BVM2 (i think its called) with the link to WEB on it (though moved to a different location) and it opens with the IE embedded - its when i go back to the main RR window from that after clicking the top right hand button that i still see IE on top of the RR application - i think its supposed to keep the IE open , but RR is supposed to come to the front if im working this out correctly , but IE stays on top.
Old 11-12-2007, 02:43 PM   #4
guino's Avatar
ummm.. You need to make sure you're not mixing the "WEB" command with the WEB "PLUGIN" command.. one has a built-in support to load IE outside RR and embed it, the other opens the web page inside the plugin (without running IE) -- Check the command used in the web button to see what you're actually running.
Old 11-12-2007, 03:11 PM   #5
B04,11,186,296,106,"web",""
Old 11-12-2007, 09:04 PM   #6
guino's Avatar
See, this is NOT the web plugin -- it's the built-in browser support for using IE outside RR but embedded in the skin. The actual web plugin is available on my site for download and it is called using the PLUGIN command.
Old 11-13-2007, 03:52 AM   #7
Brilliant - ill check it out - thanks a million.
Ill let you know how i get on - That RR program has myself and my friends in awe at how good and flexible it is.
(any hints as to where to find this plugin? Cant seem to see it on the site)
Old 11-13-2007, 04:39 AM   #8
peijffertje's Avatar
peijffertje is on a distinguished road
You can download it form here
http://www.kompassist.co.uk/
peijffertje is offline   Reply With Quote
Old 11-13-2007, 01:54 PM   #9
Brilliant - got it working and all is well with the world again. Thanks a million once again for all the help.
Is there a way to set a default page on that plugin ?
I figued out the bookmarks , but not the default page on it.
Old 11-13-2007, 01:56 PM   #10
Thanks for the link - made life easier.
Old 11-13-2007, 06:24 PM   #11
guino's Avatar
the web plugin should load the very first page in your bookmark by default. You should be able to set it to about:blank if you dont want anything to load initially.
Old 11-14-2007, 12:20 PM   #12
Yeah i had figured that out eventually - and i went to the webfavs.ini and edited it to the list i wanted as well - thanks again
Old 05-02-2008, 10:19 PM   #13
Grrrrrrrrrrrrrrr , i had a problem with my roadrunner and im back to square 1.
I found the webplugin but i cant seem to get it working .... i cant find the button command i used to have , can someone spell it out to me please ?
B04,11,186,296,106,"LOAD;wbrowser.skin;WebPlugin;C :\Program Files\Road Runner\WebPlugin.exe;WebPlugin","Internet"
Doesnt seem to work so im not sure any more.
Old 05-03-2008, 07:24 AM   #14
Its ok , i solved it and i uploaded the webplugin and a quick readme to
http://www.theotherzone.com/Roadrunner/WebPlugin.zip
in case anyone else is stuck with this.
Getting free internet from my Telus mobility free incoming call plan(just an idea) nobb Wireless Communications 0 02-15-2007 11:12 AM
Set RR to close a program ... not hide drPheta Road Runner 13 08-23-2006 11:19 PM
Cable TV over the internet DrBuzzo Wireless Communications 9 12-06-2004 05:57 PM
internet explorer sucks mp3z24 Off Topic 11 03-21-2002 09:11 AM
