12-03-2007, 08:18 PM
#1
Cant start RR after installation (win98 SE)
Hi Guino, thanks a lot for RR
i downloaded and installed RR installshield package (roadrunner.exe) on my win98 SE (Pentium II 333, 64MB, 4.3GB HDD) yesterday. the installer ran fine but failed to start RR Config after that. I got error some VB6 DLL not found (msvbvm60.dll to be exact). I then download vbrun60sp3.exe from microsoft and installed, when i started RR Config, RR didnt produce any error but did nothing. the mouse pointer just change to sandclock for several seconds and back to normal, nothing happened
please advise what i should do to get it run?
12-03-2007, 11:08 PM
#2
Raw Wave
Vehicle: 01 Ford ZX3
RR or the Config when nothing happened?
12-04-2007, 04:45 AM
#3
Config
config was the one which required msvbvm60.dll, RR asks for another dll as well but lets solve it later
12-04-2007, 06:45 AM
#4
RoadRunner Mastermind
Vehicle: 04/Mazda/RX-8
You can download an older RR and use the Config from it which is tested on 98SE.. RR itself should also run on 98SE, but advanced features such as skins with transparency will NOT work in 98SE. Older skins such as BMV2 should work normally.
Road Runner,RR's Myspace
12-04-2007, 10:43 AM
#5
which version you recommend? thanks
12-04-2007, 11:25 AM
#6
I always recommend the latest RR, but either you'll have to set it up manually in RR.INI (the settings are explained in readme.txt) OR you'll have to download an earlier version like 4-11 which includes the older config which definitely runs on win98SE.
12-04-2007, 12:24 PM
#7
Raw Wave
I was going to post a test version of the config that "might" work for win98, just been really busy trying to finialize my Media plugin for a complete test by the end of the weekend.
12-04-2007, 06:12 PM
#8
Raw Wave
Here goes nothing....give this one a try.
Make sure you rename it back to "RRConfig.exe"
12-04-2007, 07:03 PM
#9
thanks a lot Blue ZX3 and Guino, never imagined such a fast support for a free software. I will give it a try tonight when i am home. i am now at work. G'day
12-04-2007, 08:52 PM
#10
Raw Wave
Try also downloading a current version of the config, as I just tested it using VPC 2007 win98 and the current one ran just fine...
12-04-2007, 09:32 PM
#11
please bear with me if i am wrong, from what i think, after the installation completes, I just simply click exit button and leave the "load RR Config" checked. is that right? or do i need to open the ini text file to do something before that?
yesterday i remove RR and tried install it again, still got that same symptom, sandclock for a moment and turned back to pointer, nothing happened
fyi, sound blaster 16 card works fine, my win98 works fine, winamp works fine producing excellent music. just the RR, I am only a step away from putting the PC in car and enjoy it on the road
btw, i've been working in IT for 10 years. I am familiar with VB6 programming, windows systems, database...etc. so please dont be afraid to be so technical where actually needed (No technical slangs will help many others in this forum, so i say "where actually needed")
many thanks guys
12-04-2007, 11:42 PM
#12
Raw Wave
Ok, because of your posting...I actually did some win98 RRconfig trouble shooting and have a small list of things that will be fixed for the next config update to make it more 98 friendly, but for now using the current version and placing that dll file in the roadrunner folder should allow it to complete its starup function and pop up the config window.
One small problem is any of the comboboxes WILL NOT dropdown, but if you click on the text and scroll up/dn you will still be able to change the values...
You want to uncheck it, as I have never used the installer(untill now). The version of the config is included in the installer is not going to work for you.
12-05-2007, 08:43 AM
#13
hi guys, one good news: the new file RRConfig.exe you sent today has worked for me and one bad news: RoadRunner.exe keep asking for GDIPlus.dll but the package only has GDIPlusWrapper.dll
how do i go from this?
12-05-2007, 09:23 AM
#14
got the file from my winxp laptop, copied it over, havent registered it yet, RoadRunner.exe started its logo but stopped with an error not being able to load some outdated Flash files. it was able to load winamp before that but thats it
12-05-2007, 10:20 AM
#15
i found a flash.ocx somewhere on internet, downloaded it, copied it to c:\windows\system then registered it by running regsvr32
it is working now haha
| Thread Tools |
| Display Modes |
Linear Mode
