Gps Time
Hi All,
Guino, I have a small issue with gps time. When I enable gps time updates in the ini files it will set the time properly but will be half an hour out. I believe that this is because the gps time routine uses GMT +- a number of hours. I am in Adelaide and the time zone here is +9.5hrs so when the time is set from GMT the clock is set to GMT+9hrs or half an hour out. Is this a limitation of the GPS time routines or can it be remedied??
Cheers
Thwack
Car PC - MS12000, 4Gb CF Boot, 32Gb CF Data, 1Gb Ram, M2-ATX PS, 8" 800x600 TS, SiLabs USB Radio, Garmin GPS15L, Ublox SBR-LS DR GPS, Fusion Brain, Multibay Card Reader, Panasonic Slotload DVD+-RW, Custom Fab Steel Case
Car- 1988 Nissan Patrol 4WD
