The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Bug Tracker
Thread Tools Display Modes
Old 12-21-2007, 05:02 AM   #1
Road Runner & Mp3car Gatherings Moderator
JohnWPB's CarPC Specs
JohnWPB's Avatar
Vehicle: 99 Mitsubishi Eclipse
My Photos: (0)
SKIPTO Not working correctly with Custom Lists
When you have a hidden value, and a displayed text field, the SKIPTO is working on the hidden Description, and not on the the viewable text.
The SKIPTO works fine, if you are just using one field to create the custom list, the problem happens when you use the "Text" AND the "Description Value".
For instance, you are viewing list of MP3 folders in your root MP3 directory. All of the paths begin with the drive letter, H in my case (H:\MP3). When I try the SKIPTO "L" for instance, the list does not move. However if I press "H" (My drive path) it will go to the top of the custom list. As it should, as "H" is the first letter for the command text in the custom list.
I hope this makes sense Its kind of hard to explain.
CarPuter: 2.8Ghz P4 with 1 Gig Mem, 500 Gig HD, Iguidance 4.0
7" Motorized Touchscreen, XM PCR1000, Visteon HDZ300 HD
Radio, WIFI, Fusion Brain.
Powered By Road Runner & the DigitalFX 4.0 Skin www.johnwpb.com
JohnWPB is offline   Reply With Quote
Sponsored Links
Old 12-21-2007, 07:50 AM   #2
RoadRunner Mastermind
guino's CarPC Specs
guino's Avatar
Vehicle: 04/Mazda/RX-8
My Photos: (5)
The issue here is that this command is only useful for "sorted" information. If you start placing things at random order in there, it won't work even if I make it work with the description.
Road Runner,RR's Myspace
guino is offline   Reply With Quote
Old 12-21-2007, 08:08 AM   #3
JohnWPB's Avatar
My Photos: (0)
Yes, thats definitely understood The items in this list I am referring to, are in alphabetical order.
Old 12-21-2007, 05:14 PM   #4
Raw Wave
Blue ZX3's CarPC Specs
Blue ZX3's Avatar
Vehicle: 01 Ford ZX3
My Photos: (16)
Maybe some flexibility of the skipto cmd. ie..."SKIPTO;k;TEXT" or "SKIPTO;k;DESC", so this would make the cmd syntax:
SKIPTO;<letter>;<section of list to apply to>
Just puttin my thoughts out on this...
Blue ZX3 is offline   Reply With Quote
Old 12-24-2007, 04:55 AM   #5
JohnWPB's Avatar
My Photos: (0)
SKIPTO in Custom Lists
So Guino, is this possible?
Old 12-24-2007, 09:39 AM   #6
guino's CarPC Specs
guino's Avatar
My Photos: (5)
will see what i can do..
Old 12-24-2007, 11:24 AM   #7
Raw Wave
Blue ZX3's Avatar
My Photos: (16)
Thanks once again....
Old 02-13-2008, 12:19 AM   #8
Raw Wave
Blue ZX3's Avatar
My Photos: (16)
Hey guino, I KNOW that you are a VERY busy man, just checking if you had a chance to look into this at all...
No rush by any means..
Old 02-13-2008, 11:17 AM   #9
Vehicle: 91 Ford Probe
My Photos: (0)
If you're already looking at the code for this command : Could you also add SKIPTOPREV and SKIPTONEXT ?
Konrad is offline   Reply With Quote
Old 02-13-2008, 09:06 PM   #10
Raw Wave
Blue ZX3's Avatar
My Photos: (16)
This can be done currently with use of using RR code..
Here is what you want, with full roll around scrolling supported ...
Add this to your rr.ini file
LTRNUM=0
In your skin folder's Exectbl.ini file or RR's folder Exectbl.ini file add the following...
Code:
"SKIPTOPREV","EVAL;LTRNUM;$LTRNUM$-1||MYSKIPTO" "SKIPTONEXT","EVAL;LTRNUM;$LTRNUM$+1||MYSKIPTO" "MYSKIPTO","BYVAR;LTRNUM;MYSKIPTOSTART<<SKIPTO;A<<SKIPTO;B<<SKIPTO;C<<SKIPTO;D<<SKIPTO;E<<SKIPTO;F<<SKIPTO;G<<SKIPTO;H<<SKIPTO;I<<SKIPTO;J<<SKIPTO;K<<SKIPTO;L<<SKIPTO;M<<SKIPTO;N<<SKIPTO;O<<SKIPTO;P<<SKIPTO;Q<<SKIPTO;R<<SKIPTO;S<<SKIPTO;T<<SKIPTO;U<<SKIPTO;V<<SKIPTO;W<<SKIPTO;X<<SKIPTO;Y<<SKIPTO;Z<<MYSKIPTOEND" "MYSKIPTOEND","SETVAR;LTRNUM;1||GOTOFIRST||MYSKIPTO" "MYSKIPTOSTART","SETVAR;LTRNUM;26||GOTOLAST||MYSKIPTO"
Now just use your "SKIPTONEXT" or "SKIPTOPREV" cmds like stated above
And as always...ENJOY!!
Sponsored Links
Old 02-14-2008, 01:51 AM   #11
guino's CarPC Specs
guino's Avatar
My Photos: (5)
havent had the chance to look at it yet... should be easy though.
Old 02-14-2008, 03:59 AM   #12
My Photos: (0)
Thanks for your help, really, but I don't this this will work correctly because of two problems:
1. It doesn't check the actual letter you're at.
I'll try an example:
I'm at letter A. If I execute SKIPNEXT it will increase the VAR LTRNUM and jump to letter B. So far, so fine. But if I now manually scroll down to another letter, say O, and I execute SKIPNEXT, it won't jump to letter P, but instead to letter C.
2. Also, I don't know what happens when you have no songs with the letter C in the list. I guess RR does nothing then, right ?
Of course SKIPNEXT should jump to ne next letter in the alphabet, which also EXISISTS in the playlist. So if there's no letter C in the list, RR should jump directly to letter D.
I wrote a little program in AutoIt, but it's working too slow. But again, I think this can be added really easy by guino, when he's already looking at the SKIPTO command.
If he finds to time to look at it, that is. No rush ...
Old 02-14-2008, 08:14 AM   #13
Raw Wave
Blue ZX3's Avatar
My Photos: (16)
Minior details....
Sponsored Links
vB code is On
Trackbacks are Off
Bluetooth Dongle Not Working correctly KingsDude Wireless Communications 6 05-17-2007 01:30 PM
m1-atx is this working correctly? llajumpvid Newbie 5 05-28-2005 11:12 AM
cant change skins??? Hell-Stopper FrodoPlayer 19 11-05-2004 10:10 PM
BU-303 not working correctly Mik GPS 9 08-21-2004 04:28 PM
Everything working correctly? bgoodman Off Topic 16 09-15-2002 12:13 AM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
