01-25-2008, 12:39 AM
#1
Vehicle: 2004 Ford F150 FX4
custom variable sliders
they dont update. if i have a variable slider which is currently equal to the master volume, and i increase the master volume with a button or some other external stimulus, the slider does not update.
however, you can use the slider as a normal slider. (i.e. you can slide it up and down and + and - the volume.
01-26-2008, 07:14 AM
#2
RoadRunner Mastermind
Vehicle: 04/Mazda/RX-8
give examples... a variable slider is meant to work only as a variable slider, it won't work as two things at once.
Road Runner,RR's Myspace
01-26-2008, 10:02 AM
#3
umm, well if i have a variable slider for example equal to SONGPOS, it does not move. the master volume example above i thought was okay... im not asking it to do more than it should, but if i have a slider that is equal to volume and i increase the volume without using the slider, the slider does not move even though the volume goes up.
03-04-2008, 01:32 AM
#4
bump? custom sliders still do not update themselves..... will this ever be accomplished? also, sliders and BYVAR? dont mean to bother, but these would be extremely handy features.
04-20-2008, 10:55 AM
#5
Wants to make it harder
Vehicle: 2007 PT Cruiser Touring
Here's what I had to do for the Custom Font Color sliders:
Each slider (Red, Green, Blue, songpos)
Code:
/, S, x, y, w, h, x1, y1, w1, h1, O, Style, Pointer file path, h2, Code;SLIDERCODES, Tooltip
S,218,97,41,307,218,97,41,307,v,01,"slider2.PNG",41,"$Red$",
S,363,97,41,307,363,97,41,307,v,01,"slider2.PNG",41,"$Green$",
S,507,97,41,307,507,97,41,307,v,01,"slider2.PNG",41,"$Blue$",
S01,129,419,530,7,129,415,530,15,h,"bar.png","Slider.png",21,"SONGPOS",
These buttons check where the sliders are positioned, and converts the number to a whole number between 0 and 255, then saves the result to a file. First button tests the result, the second saves it to the skin.
Code:
/, B, x, y, w, h, Command;COMMANDCODES, Tooltip
B005,680,261,120,60,"EVAL;REDSLIDER;$Red$\257||WRITETOFILE;$skinpath$test.skin;=/DEFINE TRed $REDSLIDER$||EVAL;GREENSLIDER;$Green$\257||ADDTOFILE;$skinpath$test.skin;=/DEFINE TGreen $GREENSLIDER$||EVAL;BLUESLIDER;$Blue$\257||ADDTOFILE;$skinpath$test.skin;=/DEFINE TBlue $BLUESLIDER$||ADDTOFILE;$skinpath$Test.skin;=END||RELOADSKIN||Load;TextColor.skin",
B005,680,322,120,60,"EVAL;REDSLIDER;$Red$\257||WRITETOFILE;$skinpath$color.skin;=/DEFINE FRed $REDSLIDER$||EVAL;GREENSLIDER;$Green$\257||ADDTOFILE;$skinpath$color.skin;=/DEFINE FGreen $GREENSLIDER$||EVAL;BLUESLIDER;$Blue$\257||ADDTOFILE;$skinpath$color.skin;=/DEFINE FBlue $BLUESLIDER$||ADDTOFILE;$skinpath$Test.skin;=END||RELOADSKIN||Load;TextColor.skin",
These buttons allow me to fine adjust the sliders so that it increases or decreases by just one.
Code:
B001,131,137,72,58,"EVAL;Red;$Red$+257||EVAL;REDSLIDER;$Red$\257",
B001,131,306,72,58,"EVAL;Red;$Red$-257||EVAL;REDSLIDER;$Red$\257",
B001,274,137,72,58,"EVAL;Green;$Green$+257||EVAL;GREENSLIDER;$Green$\257",
B001,273,306,72,58,"EVAL;Green;$Green$-257||EVAL;GREENSLIDER;$Green$\257",
B001,418,137,72,58,"EVAL;Blue;$Blue$+257||EVAL;BLUESLIDER;$Blue$\257",
B001,419,306,72,58,"EVAL;Blue;$Blue$-257||EVAL;BLUESLIDER;$Blue$\257",
These labels show the mathematical result of the slider's position:
Code:
L,423,237,65,31,#FRed#,#FGreen#,#FBlue#,18,"BankGothic Md BT","=$BLUESLIDER$","CENTER"
L,278,236,65,31,#FRed#,#FGreen#,#FBlue#,18,"BankGothic Md BT","=$GREENSLIDER$","CENTER"
L,135,236,65,31,#FRed#,#FGreen#,#FBlue#,18,"BankGothic Md BT","=$REDSLIDER$","CENTER"
from my exectbl.ini:
These are necessary so that when I move each slider, it automatically refreshes the code to update all the labels and codes necessary:
Code:
"ONSLDRed","EVAL;REDSLIDER;$Red$\257"
"ONSLDBlue","EVAL;BLUESLIDER;$Blue$\257"
"ONSLDGreen","EVAL;GREENSLIDER;$Green$\257"
I hope this helps with what you were looking to do with your sliders.
| Thread Tools |
| Display Modes |
Linear Mode
