Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Bug Tracker
Old 02-05-2008, 08:14 AM   #1
Machinehead's Avatar
Machinehead will become famous soon enoughMachinehead will become famous soon enough
Winamp Linein and Music Resume Bug
When the winamp linein plugin is checked in RRConfig, the music resume function doesn't work at startup or out of hibernation. When the linein plugin is unchecked, music resume works perfectly.
I've reproduced this bug on more than one system now.
Machinehead is offline   Reply With Quote
Old 02-15-2008, 08:46 AM   #2
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
Interesting... I'll have to look at it, but from what I understand, The linein plugin should not affect music playback.
Ride Runner RR's Myspace
guino is offline   Reply With Quote
Old 02-15-2008, 09:17 AM   #3
Thanks Guino, it's an odd bug to say the least.
By the way, it's a problem with both the 2.95 and 5.13 version of winamp.
Old 02-22-2008, 01:49 PM   #4
GTO
GTO's Avatar
GTO is an unknown quantity at this point
This is something I suffer from on 90% of my start-ups and makes RR virtually unusable.
Where is the check box in RRConfig, is it where you select what RR controls, i.e. Master volume? If it is then this isn't a fix for my problem because I have deleted the linein plugin from WA.
GTO is offline   Reply With Quote
Old 02-22-2008, 02:39 PM   #5
Depends which version of RRconfig you're running, but it's in the XM/Sirius options.
Or you can edit it right out of the RR.ini if you know what you're looking for.
RoadRunner 09/09/07 -- Line-In/Winamp volume resets to 0% on resume 2k1Toaster RR Bug Tracker 11 10-16-2007 09:56 AM
How to getting xtremepcr to run with winamp linein in MC mdrt4me MediaCar 1 08-31-2004 06:19 AM
