The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Bug Tracker
Thread Tools Display Modes
Old 03-01-2008, 02:20 PM   #1
spidermunz's Avatar
Vehicle: lancia delta 1.6
My Photos: (0)
when i exit from rr, winamp doesn't close
i've set in the rrconfig "close embedded applications" but nothing
i've set in the "exit" button closewinamp but nothing
i'm thinking its dipend to the avs windows but i don't found solution
using winamp 2.95 or winamp last version i have the same problem
i look the task manager, winamp is open!!!
spidermunz is offline   Reply With Quote
Sponsored Links
Old 03-02-2008, 02:26 AM   #2
carputer1's Avatar
My Photos: (0)
just something i spotted in your skin
when vis was / is running and you exit rr. the vis window is still running ,not allowing
winamp close correctly or open again.
hope this helps a bit
MKIII Skin,RoadRunner,D7 , Gatso Hunter ,MediaLaunch ,Tag Editor ,
carputer1 is offline   Reply With Quote
Old 03-07-2008, 12:12 PM   #3
My Photos: (5)
wow i never thought of that. it was getting pretty annoying having to go into task manager and manually kill it. ill do some testing now..
hari-bhari is offline   Reply With Quote
Old 03-08-2008, 08:19 AM   #4
RoadRunner Mastermind
guino's CarPC Specs
guino's Avatar
Vehicle: 04/Mazda/RX-8
My Photos: (5)
This could be an issue from a winamp plugin installed.. I have never seen this before.
Road Runner,RR's Myspace
guino is offline   Reply With Quote
Old 03-08-2008, 12:15 PM   #5
carputer1's Avatar
My Photos: (0)
that was my thought at 1st
but the only plug's i have in mine anyway is the search .dll's nothing else .
apart from the search its standard load.
Old 03-08-2008, 12:16 PM   #6
greatwhite's CarPC Specs
greatwhite's Avatar
Vehicle: 2004 Chrysler 300M Special
My Photos: (1)
I only have the standard install of winamp 5.13 and sometimes I have to kill winamp in taskmanager too...........
Leonardo Da Vinci
greatwhite is offline   Reply With Quote
Old 05-11-2008, 02:48 PM   #7
kelmk's Avatar
Vehicle: 2002 BMW 330ci vert
My Photos: (100)
I have the same problem
kelmk is offline   Reply With Quote
Old 05-11-2008, 07:55 PM   #8
treetop777's CarPC Specs
treetop777's Avatar
Vehicle: 1981 Ford F-100
My Photos: (0)
Read this: http://www.mp3car.com/vbulletin/road...n-rr-exit.html
treetop777 is offline   Reply With Quote
Old 05-11-2008, 11:43 PM   #9
Wants to make it harder
monkeyracer's CarPC Specs
monkeyracer's Avatar
Vehicle: 2007 PT Cruiser Touring
My Photos: (63)
I think it has something to do with the Visualizer. From what I've tested at least, it seems that when it's active on exit, it won't kill with RR, when it's not, it seems to work just fine.
The killtask.exe that is in the post treetop777 posted does work though, but it's a seperate script that needs to be run to close it. It would be nice to have it kill the winamp.exe upon close without needing that external script.
2007 Chrysler PT Cruiser TE
Car PC Progress:
Planning.......[---------X-] 90%
Fabrication...[--------X--] 80%
View my
Worklog
Road Runner Skins
Website
Favorite thread EVER!
monkeyracer is offline   Reply With Quote
Old 05-12-2008, 12:22 AM   #10
kelmk's Avatar
My Photos: (100)
Yeah you're right, turning vis off before exiting closes winamp. I tried adding "ONEXIT","VISU" but no go.
Sponsored Links
Old 05-12-2008, 07:57 AM   #11
My Photos: (63)
And "CLOSEWINAMP" doesn't kill it either. Have you tried the killtask.exe that johnwpb made?
Car PC Progress:
View my
Worklog
Road Runner Skins
Website
Old 05-12-2008, 11:17 AM   #12
kelmk's Avatar
My Photos: (100)
Do I need to edit my skin file to use the script or can I run it somehow using "ONEXIT". Sorry I've only been using RR for a couple days.
Old 05-12-2008, 11:47 AM   #13
My Photos: (63)
Quote: Originally Posted by JohnWPB View Post
Its not a perfect solution, but works perfectly for me. I simply wrote a small script, that I can pass the name of a task to, and it will kill it.
To Kill Winamp for instance, I have the following line in my Exectbl.ini:
Code:
"KillWinamp","RunQ;$skinpath$scripts\Kill_Task.exe|winamp.exe"
On the Exit button in my skin, I have:
Code:
"KillWinamp||QUIT"
This way when I close RR, Winamp is forced to close.
Simply change the winamp.exe to any process you want to kill and create more lines in the exectbl for each thing you want to be sure is closed, Rainlender for instnace:
Code:
"KillRainlender","RunQ;$skinpath$scripts\Kill_Task.exe|Rainlender.exe"
SO now your exit button would have the following code to close both:
Code:
"KillWinamp||KillRainlender||QUIT"
Attached it the zipped up .exe
Try this.
Car PC Progress:
View my
Worklog
Road Runner Skins
Website
Sponsored Links
vB code is On
Trackbacks are Off
Advanced Title Formatting (ATF) for Winamp ID3 Decoding GizmoQ Road Runner 3 11-23-2006 10:14 AM
use winamp 2.95 with RR still? Will Albers Road Runner 3 11-14-2005 06:08 PM
Cant exit out of RR? Will Albers Road Runner 1 11-10-2005 03:00 PM
Minimize winamp on RR Startup Shelbrain Road Runner 6 05-26-2005 01:09 AM
status update.... 0l33l PowerVoice 17 05-05-2005 12:22 PM
Sponsored Links
SEO by vBSEO 3.1.0
Ad Management by RedTyger
