Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Bug Tracker
Old 06-08-2008, 07:30 AM   #1
Robby BMW's Avatar
Exclamation Issue with sliders in Extension Plugin Interface (with solution)
I've noticed that if you try to load more Extension Plugin in RoadRunner, only the sliders handled by the first Plugin are properly displayed.
The problem can be easly solved by this simple change in the RRExtension class:
Public Function ReturnSlider(SLD As String) As Long
'Default (No Action) <== LINE TO BE ADDED
ReturnSlider = -1 <== LINE TO BE ADDED
I think it's important to add this change on every plugin developed with the Extension Plugin Interface in order to allow the simultaneously use in RoadRunner.
_______________________________________
Car installation 95% [■■■■■■■■■■■■■■■■■■■]
Current project: Parking sensor USB interface
Robby BMW is offline   Reply With Quote
Advertisement Sponsored links
Old 06-09-2008, 05:46 AM   #2
Road Runner & Mp3car Gatherings Moderator
JohnWPB's Avatar
Do you know if something similar to this also pertains to custom indicators? They seem to have the exact problem you describe with the sliders. If I enable one plugin or the other the indicators work with either one. Enable both and the indicators only work with one plugin's indicators. Changing which plugin is loaded first can also effect which plugins indicators work.
Front End of Choice: Road Runner (Is there anything else??? )
& Powered by the DigitalFX 4.0 Skin
Available at www.JohnWPB.com
JohnWPB is offline   Reply With Quote
Old 06-09-2008, 07:41 AM   #3
Robby BMW's Avatar
No, the indicators are not plagued by the same problem, because in the function "ReturnIndicator" of the class "RRExtension" is already present the line: ReturnIndicator = "False"
It seems more a bug in the last official beta release (05/27/08), since the indicators work well on previous releases, also loading multiple plugins.
Old 09-11-2008, 06:05 AM   #4
FYI, as of NOW (9/9/08) ReturnIndicator = "" when unprocessed
return ""
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
mitchjs is offline   Reply With Quote
Velleman K8055 USB I/O Board Extension plugin 307SW_NLD RR Plugins 196 09-11-2008 01:27 PM
Keyboard language indicator extension plugin tolisn RR Plugins 23 09-13-2006 03:49 AM
Extension plugin problems festy Road Runner 2 06-23-2006 06:20 PM
How do I use the Extension Plugin Interface ? guino RR FAQ 0 06-11-2006 05:49 PM
Extension Plugin help .... Gobby Road Runner 1 06-09-2006 10:27 AM
