10-26-2009, 05:06 PM
#1
SetLabel
Is it me or is the command SetLabel not working anymore? I have a command where I call a MENU but the label is not populating. Here is my command.
"ESC||RM_Add2Disk1||MENU;AddSong.skin||SETLABEL;!D iskNumber;1"
Now, AddSong pops up but the label is blank.
11-07-2009, 11:11 AM
#2
One Sharp Cheddar
NOT working for me either... Using the skin tool I cant get it to work even using the exact syntax from the Skin Commands.txt
I think this bug can be considered CONFIRMED...
11-07-2009, 11:12 AM
#3
One Sharp Cheddar
OH yeah, I using the October release of RR...
11-07-2009, 12:36 PM
#4
November update neither. Need to be looked at by the Gurus.
11-08-2009, 07:40 AM
#5
RoadRunner Mastermind
I just tested this here (and works):
L,625,25,117,25,28,68,227,18,"Arial:B","!test",""
with command:
setlabel;!test;Hello!
can any of you post a .skin and command combination which isn't working ?
Ride Runner RR's Myspace
11-08-2009, 11:02 AM
#6
One Sharp Cheddar
Im testing using the skintool
command
label code
!test
11-08-2009, 11:11 AM
#7
One Sharp Cheddar
Ok works if I put the label in a skin and put the ! before the label code.
If there is no ! then the label displays then goes blank.
Still can't get the skin tool to get the label information though.
11-08-2009, 06:54 PM
#8
The Curator
with command:
Why use a test label that starts w/ a "!"?? Was there something new that the "!" in front of a std lbl changes or does?
11-08-2009, 11:52 PM
#9
Raw Wave
yes... the ! does do something
it sounds obsoleted
and one should use a label and a var
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
11-09-2009, 09:05 AM
#10
! in front of a label is the same as "CUSTOM" in front of a label. This IS AN OBSOLETE feature and only works in the SKIN itself as setlabel will directly set the label text without ever setting/reading it again -- this means that skintool (or any other plugin) will never be able to read it.
As mentioned, this feature is obsolete and is only available to support older plugins/applications still using it. The RECOMMENDED way of doing exactly the same is:
LABEL CODE: Instead of "!TEST" use "=$TEST$"
COMMAND: Instead of "SETLABEL;!TEST;Hello!" use "SETVAR;TEST;Hello!"
The results are the same, however you CAN read the variable from skintool/plugins and furthermore, the command will work for displaying the data on ALL screens of RR without having to resend it for every screen (using SETLABEL you'd only set that label on the CURRENT screen and if you wanted to show the data on different screens, you'd have to execute SETLABEL again after every screen change - or on a timed basis).
11-09-2009, 12:35 PM
#11
The Curator
The only drawback to using vars in lables that I found when starting my RRMedia PI, was that a lbls that have/use a var for the text take longer to update when you change the var compared to using the custom route. The custom route is almost instantly updated...
| Thread Tools |
| Display Modes |
Linear Mode
