Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Bug Tracker
Old 11-04-2009, 08:49 PM   #1
anuchit is an unknown quantity at this point
Riderunner from save playlist error
I save playlist and load playlist to play it error about font and can not play..
I test on foobar plugin player
When I test on winamp player it error too.
anuchit is offline   Reply With Quote
Old 11-04-2009, 09:58 PM   #2
Raw Wave
mitchjs is on a distinguished road
you might want to read this
http://www.mp3car.com/vbulletin/rr-f...ml#post1353843
playlist cannot load/save from a dir with NWU chars (NWU (Non-Western Unicode))
thats prob, your problem
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
mitchjs is offline   Reply With Quote
Old 11-04-2009, 11:58 PM   #3
Thank you for answer.
Old 11-05-2009, 08:11 AM   #4
MeeM is on a distinguished road
I'm having a problem with RideRunner's playlist. When I click the 'eject' button to show the music directory, I see all the music files there as normal. When I click the top item (the three dots '...') it is supposed to move to the previous directory, but it doesn't. It simply takes me back to RideRunner's music player and starts playing the current music. I've just switched to using Foobar2000 and previously I was using Winamp, this never used to happen when I used Winamp.
Any idea why? I wanna load different playlists and I need this to work, but it won't let me change my playlist. Even if I run Foobar on its own and load a new playlist into it, and then close it, and run RideRunner, RideRunner still shows the previous playlist and plays from that only.
MeeM is offline   Reply With Quote
Old 11-06-2009, 01:37 AM   #5
Now
about bug saveplaylist is fix by edit skin command .. use .m3u8
edit save and open playlist it work for Thaisong . I wish other language work too..
"osktocmd;listname;savelist;$playlistpath$$listnam e$.m3u8",
"$PLAYLISTPATH$",".m3u.m3u8",0,,,,,,,
Old 11-06-2009, 10:27 AM   #6
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
Unless you have a folder called "..." (THREE dots), RR will not put it there -- RR should only show ".." (TWO dots) to go back to a previous folder -- when you don't the use hide dots option. You should make a debug log to see if the skin you're using (which you haven't mentioned) is overriding the default double click action. I can also suggest you try a different skin to see if double clicking the ".." (TWO dots) takes you back one folder.
RR doesn't use or mess with the Foobar playlist - it creates a separate playlist to work with, then removes it before exiting - messing with the playlist in foobar will do no good.
NOTE: that if you're trying to double click the ".." in the default MUSIC folder or default VIDEO folder -- the default action is to load all your songs! You can only back out of the default MUSIC/VIDEO folder if you set pathlimit=false in RR.INI (probably option in RRConfig as well).
Ride Runner RR's Myspace
guino is online now   Reply With Quote
Fusion Brain program for Linux malcom2073 Fusion Brain 33 06-20-2009 09:46 AM
Virtual Earth cache builder? Or even gps simulator to make it cache? thepunkerguy DigitalMods (Scripts / API) 183 08-28-2008 09:58 PM
Playlist Strangeness nasa Road Runner 2 08-17-2008 10:05 AM
how can you save a playlist? brandensin Road Runner 11 07-30-2008 12:15 AM
Playlist and save bugs tolisn RR Bug Tracker 6 04-05-2005 12:16 AM
