02-19-2005, 08:57 AM
#16
Quote: Originally Posted by RhinoT16S
so RR 19 2 05 actually runs on both machines now, both have vis working.
however, both machines show no title scrolling regardless of settings (i am using the updated skin file - also tried older skin with "scroll" amendment).
is there anything else required other than the "scroll" text to initiate the scrolling function?
also; the flash logo on the front menu IS working - so i'm not sure if this is a flash problem still.
Thanks..
Also if It seems stupid... it works only if the text to be scrolled is longer than the text-box in your skin.
To Guino:
I have a problem on my carpc. With scrolling enabled I have to double-click to use any button of the skins where there si scrolling text. In my desktop don't... and vis is still blinking. Probably video card sucks!
02-19-2005, 12:50 PM
#17
good tip ildena
i tried shortening the text box and it does now scroll in all three settings, so, nearly there Guino!
i don't have the double click problem showing though (thankfully  )
02-19-2005, 02:52 PM
#18
RoadRunner Mastermind
To Guino:
Does this problem "Stop" when the song title fits and scroll is not "running" ? I never seen that before.. Can you make me a "Log" file of activity when you actually have to "click twice" ? also, does the button respond (go down/up) the first time you click it ?
I'll try to add even more prevention for the vis thingy... I swear this should work ...
Ride Runner RR's Myspace
02-19-2005, 02:56 PM
#19
good tip ildena
nearly there what ? hahaha I meant it not to scroll if it fits.. I mean, as ildena mentioned, that'd be kind of stupid to scroll text that actually fits..
02-19-2005, 03:05 PM
#20
my mistake  i thought the scroller was for all text length - i had a pioneer head unit that would scroll title, even if it was a couple of characters; i guess'd it was the same effect trying to happen here. oops!
still looks damn cool..
02-23-2005, 04:53 PM
#21
I don't know if this is related but with version 2-20 when I hit the visualization button it takes two tries each time to get it to start or stop the visualization. Hit the button once, nothing happens, hit it again=visualization starts. Hit the button, nothing happens, hit it again=visualization stops. Any ideas?
Using milkdrop of course.
02-23-2005, 04:57 PM
#22
Check RRConfig, make sure you have MilkDrop selected and not "Other" or "AVS".. if it is set correctly, let me know..
02-23-2005, 05:41 PM
#23
visualization plugin (*)Milkdrop
Nothing else bubbled in.
I checked it out again and it goes into visualization mode correctly on one press the first time, but trying to close it takes two presses and any subsequent attempts to start the vis takes 2 presses.
02-23-2005, 09:14 PM
#24
Sounds like RR is failing to send the Close command to MilkDrop.. what winamp version u running, and also, do you think you have an old MilkDrop Plugin ?
maybe you want to try this one:
http://rmc.pimpedwheels.com/RoadRunnerBinary.zip
| Thread Tools |
| Display Modes |
Linear Mode
