03-27-2005, 01:59 PM
#1
Audio muted problem
I updated newest version and i have problem with mute. Audio is always muted when i start pc and RR. If i close RR and start again problem doesn't occur. When i restart windows everything works fine. Problem occurs only when i do shutdown and start pc again. Does anybody else have this problem?
03-27-2005, 04:06 PM
#2
RoadRunner Mastermind
never heard of it.. but you can make a mixer preset and have RR load it when starting up if you want.. that would most likely fix your issue..
How are you shutting down the PC ? because I can pretty much tell you straight out tha if RR is "killed" during the shutdown process without propper termination, there is a chance that you'd get the volume muted (if RR doesn't completely terminate)...
Ride Runner RR's Myspace
03-28-2005, 08:11 AM
#3
Shutdown is done via remote control and girder. Oh well, i have to complete my shutdown controller and start using hibernate
03-28-2005, 08:13 AM
#4
Raw Wave
Are you shutting down via RR or Windows?? If Windows, this is possibly why, try doing shutdown direct from RR using Girder.
03-28-2005, 09:23 AM
#5
I use RR shutdown command not windows. I haven't had this problem with earlier versions of RR  . This doesn't happen when i restart windows. Only when i shutdown windows. Maybe resume file is broken or something?
03-28-2005, 02:39 PM
#6
If you're using RR's shutdown option then I'll double check at this..
12-01-2005, 11:38 AM
#7
No Sound on Start up
Similar problem with mine.
When I start from cold I get a Mute message in the bottom right hand side of the screen as Road Runner executes Winamp. Did you ever find a solution to this?
I have also noticed when Win amp starts the balance setting is to one side, although sound comes from both channels!
2005 Aston Martin V8 Vantage
P4 2.4 Asus Pundit
Road Runner
Free Drive/Map Monkey
Road Angel
Snooper
1 penalty point remaining before I can add no driving License!
12-02-2005, 11:07 AM
#8
man, if Winamp is having issues with the volume stuff, than sounds like something is really funky with your sound card or drivers.. I'd try to reinstall them... You can easily put a startup command in RR to Unmuter or Set the volume of any audio line to a specidif number.. but I'd recommend getting it propperly fixed (drivers etc)... btw, my carputer is the ASUS Pundit R as well...
Sometimes I do have issues with the mixer.. if F***s up and everything is set to ZERO, the windows mixer wont open and such... but then I just need to reset... it's somewhat rare though..
12-02-2005, 11:12 AM
#9
Cheers boss,
I've been having some problems with Map Monkey also, when I checked the error messages last night it said audio overflow! I guess you may be right. This weekend I am going to do a complete reinstall of the sound card/drivers and Map monkey to see if I can solve it.
Nice to hear someone else has a Pundit. Have you had many other problems with yours?
Roadrunner is one mighty fine achievement btw. Very impressed!
Andy
P4 2.4 Asus Pundit
Road Runner
Road Angel
Snooper
12-02-2005, 11:16 AM
#10
I get the MUTE ON STARTUP with RR also...it does it randomly, but more often than not, with the new release of RR.
CarPC #3: 99% CompletePentium M 1.7Ghz, 1GB DDR2 RAM
DVD/CD-RW installed in dash below monitor
OEM LCD relocated for 7" Touchscreen
Wi-Fi, GPS, PS2 controllers...
500+ full albums
4,000+ video games
music videos, movies, & more! old carPC
12-02-2005, 11:41 AM
#11
Poet Laureate
Location: The Côte d'Azur of England - Hot totty central
Yeah, I had that problem too. I got it after I changed a setting in RR config. It bugged the life out of me for a couple of days. Everything went back to normal after I changed the setting back in RR config. I can't remember off hand which one it was but I'll check it out when I get in the car next and let you know.
Only true postwhores remember everything they post
REP CLUB IS DEAD
LONG LIVE REP CLUB
12-02-2005, 12:48 PM
#12
cool, I hope you've got the answer
500+ full albums
4,000+ video games
12-03-2005, 11:03 AM
#13
Poet Laureate
Ok, I think the problem occurred when I had the 'Reduce Sound Volume to' option checked in RR config. I seem to remember unchecking it and the problem went away. I recently updated to Guino's latest release and have just tried to re-create the problem but it didn't happen. So, either that issue has been fixed in the latest release or I've remembered it all wrong
REP CLUB IS DEAD
LONG LIVE REP CLUB
05-11-2006, 04:40 AM
#14
i had the same problem. soundcard driver was not the case.
i unchecked "reduce volume ??%" checkbox
09-15-2006, 04:00 AM
#15
O thank god others had this too.. I thought it was only me...
so this "reduce volume" checkbox is in the RR config?
| Thread Tools |
| Display Modes |
Linear Mode
