The MP3car.com Store
Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR Bug Tracker
Thread Tools Search this Thread Display Modes
Old 05-10-2005, 12:44 PM   #1
MySQL Error
MatrixPC's CarPC Specs
MatrixPC's Avatar
Vehicle: 89 Supra Turbo, 04 Toyota Matrix XR
My Photos: (0)
GPS:MM shutdown RR when switch skin
I found a weird problem.
Here it goes. If MM is running and I switch skin (any), the skin is load but then RR and MM all shutdown. From the debug log the last line before shutdown is Winamp window not found.
Music is still playing at the last second it shutdown. When reload RR, music is resume to that last second.
Previous version (4/25) and the latest version of RR (5/6) also has the same problem. MM is also the latest one. Winamp is 2.95. No problem with latest Freedrive version as External GPS. This is regardless of GPS mode to show Menu or directly launch MM.
Anyone has this same problem?
Y2K Accord Dell GX150
EmoRebellion is a SCAMMER
MatrixPC is offline   Reply With Quote
Sponsored Links
Old 05-10-2005, 04:33 PM   #2
RoadRunner Mastermind
guino's CarPC Specs
guino's Avatar
Vehicle: 04/Mazda/RX-8
My Photos: (5)
If you switch Skins.. RR is forced to unembed MM (to get it out of the previous skin).. it isn't supposed to close though.. so I'll take a look..
Road Runner,RR's Myspace
guino is offline   Reply With Quote
Old 05-11-2005, 08:31 AM   #3
MySQL Error
MatrixPC's Avatar
My Photos: (0)
I watched as the process goes.
- Unembed MM.
- Switch skin
- Re-embed MM
- Shutdown. (all MM, RR, Winamp)
With Freedrive, there is No problem switching skin while embeded.
Old 05-12-2005, 12:01 AM   #4
guino's CarPC Specs
guino's Avatar
My Photos: (5)
I tested it and found no issue ?? which skin are you using ?
this is what's supposed to happen if you switch skin with MM open:
-Show MM screen
-Unembed MM
-Uload All Screens
-Load new (selected) MENU.SKIN
Nothing beyond that is supposed to happen..
Old 05-12-2005, 09:16 AM   #5
MySQL Error
MatrixPC's Avatar
My Photos: (0)
This is the full debug file from start RR to the time it shutdown.
Code:
5/12/2005 7:09:16 AM: Start 5/12/2005 7:09:16 AM: Master Vol: Volume Control/4 5/12/2005 7:09:16 AM: No Master Volume 5/12/2005 7:09:16 AM: GetLineControl Failed: 401 5/12/2005 7:09:16 AM: No Treble Support 5/12/2005 7:09:16 AM: GetLineControl Failed: 401 5/12/2005 7:09:16 AM: No Bass Support 5/12/2005 7:09:16 AM: GetLineControl Failed: 401 5/12/2005 7:09:16 AM: No Master ON/OFF 5/12/2005 7:09:16 AM: Source: Wave=&H1008/1 5/12/2005 7:09:16 AM: Source: SW Synth=&H1004/2 5/12/2005 7:09:16 AM: Source: Analog Connector=&H100A/3 5/12/2005 7:09:16 AM: GetLineControl Failed: 401 5/12/2005 7:09:16 AM: Can't Open Source 5/12/2005 7:09:16 AM: GetLineControl Failed: 401 5/12/2005 7:09:16 AM: No Mute for Source 5/12/2005 7:09:16 AM: Source: Analog Connector=&H100A/4 5/12/2005 7:09:16 AM: GetLineControl Failed: 401 5/12/2005 7:09:16 AM: Can't Open Source 5/12/2005 7:09:16 AM: GetLineControl Failed: 401 5/12/2005 7:09:16 AM: No Mute for Source 5/12/2005 7:09:16 AM: Source: Front=&H100A/5 5/12/2005 7:09:16 AM: GetLineControl Failed: 401 5/12/2005 7:09:16 AM: Can't Open Source 5/12/2005 7:09:16 AM: GetLineControl Failed: 401 5/12/2005 7:09:16 AM: No Mute for Source 5/12/2005 7:09:16 AM: Source: Surround=&H100A/6 5/12/2005 7:09:16 AM: GetLineControl Failed: 401 5/12/2005 7:09:16 AM: Can't Open Source 5/12/2005 7:09:16 AM: GetLineControl Failed: 401 5/12/2005 7:09:16 AM: No Mute for Source 5/12/2005 7:09:16 AM: Source: Center=&H100A/7 5/12/2005 7:09:16 AM: GetLineControl Failed: 401 5/12/2005 7:09:16 AM: Can't Open Source 5/12/2005 7:09:16 AM: GetLineControl Failed: 401 5/12/2005 7:09:16 AM: No Mute for Source 5/12/2005 7:09:16 AM: Source: Lfe =&H100A/8 5/12/2005 7:09:16 AM: GetLineControl Failed: 401 5/12/2005 7:09:16 AM: Can't Open Source 5/12/2005 7:09:16 AM: GetLineControl Failed: 401 5/12/2005 7:09:16 AM: No Mute for Source 5/12/2005 7:09:16 AM: Source: Stereo Wide=&H100A/9 5/12/2005 7:09:16 AM: Source: CD Player=&H1005/10 5/12/2005 7:09:16 AM: Source: Microphone=&H1003/11 5/12/2005 7:09:16 AM: Source: Aux=&H100A/12 5/12/2005 7:09:16 AM: Source: Video=&H100A/13 5/12/2005 7:09:16 AM: GetLineControl Failed: 401 5/12/2005 7:09:16 AM: Can't Open Source 5/12/2005 7:09:16 AM: GetLineControl Failed: 401 5/12/2005 7:09:16 AM: No Mute for Source 5/12/2005 7:09:16 AM: Source: Line In=&H1002/14 5/12/2005 7:09:16 AM: Source: Phone=&H1006/15 5/12/2005 7:09:16 AM: Source: Mono Out=&H100A/16 5/12/2005 7:09:16 AM: Winamp window not found. 5/12/2005 7:09:17 AM: Shell: "C:\Program Files\Winamp\Classic\winamp.exe" 5/12/2005 7:09:18 AM: 0 5/12/2005 7:09:18 AM: 0 5/12/2005 7:09:18 AM: 1 5/12/2005 7:09:18 AM: 2 5/12/2005 7:09:18 AM: 1 5/12/2005 7:09:18 AM: 1 5/12/2005 7:09:18 AM: 1 5/12/2005 7:09:18 AM: 1 5/12/2005 7:09:18 AM: 1 5/12/2005 7:09:18 AM: 1 5/12/2005 7:09:24 AM: Executing: GPS 5/12/2005 7:09:24 AM: 0 5/12/2005 7:09:24 AM: 0 5/12/2005 7:09:27 AM: Executing: DESTINATOR 5/12/2005 7:09:27 AM: 0 5/12/2005 7:09:27 AM: 0 5/12/2005 7:09:27 AM: 0 5/12/2005 7:09:27 AM: 0 5/12/2005 7:09:27 AM: 0 5/12/2005 7:09:27 AM: 0 5/12/2005 7:09:27 AM: Shell: "C:\DestinatorApps\Map Monkey\MapMonkey.exe" 5/12/2005 7:09:27 AM: 0 5/12/2005 7:09:27 AM: 0 5/12/2005 7:09:27 AM: 0 5/12/2005 7:09:27 AM: 0 5/12/2005 7:09:27 AM: 0 5/12/2005 7:09:27 AM: 0 5/12/2005 7:09:27 AM: 0 5/12/2005 7:09:27 AM: 0 5/12/2005 7:09:27 AM: 0 5/12/2005 7:09:27 AM: 0 5/12/2005 7:09:27 AM: 0 5/12/2005 7:09:27 AM: 0 5/12/2005 7:09:27 AM: 0 5/12/2005 7:09:30 AM: 0 5/12/2005 7:09:30 AM: 0 5/12/2005 7:09:30 AM: 0 5/12/2005 7:09:30 AM: 0 5/12/2005 7:09:31 AM: 0 5/12/2005 7:09:31 AM: 0 5/12/2005 7:09:31 AM: 0 5/12/2005 7:09:31 AM: 0 5/12/2005 7:09:32 AM: 0 5/12/2005 7:09:32 AM: 0 5/12/2005 7:09:32 AM: 0 5/12/2005 7:09:32 AM: 0 5/12/2005 7:09:32 AM: 0 5/12/2005 7:09:32 AM: 0 5/12/2005 7:09:32 AM: 0 5/12/2005 7:09:32 AM: 0 5/12/2005 7:09:32 AM: 0 5/12/2005 7:09:32 AM: Executing: EXIT 5/12/2005 7:09:32 AM: 0 5/12/2005 7:09:32 AM: 0 5/12/2005 7:09:32 AM: 0 5/12/2005 7:09:32 AM: 0 5/12/2005 7:09:35 AM: Executing: MENU;SKIN_BROWSER.SKIN 5/12/2005 7:09:35 AM: 0 5/12/2005 7:09:35 AM: 0 5/12/2005 7:09:36 AM: Executing: DOWN 5/12/2005 7:09:37 AM: Executing: DOWN 5/12/2005 7:09:40 AM: Executing: SELECT 5/12/2005 7:09:40 AM: 0 5/12/2005 7:09:40 AM: 0 5/12/2005 7:09:40 AM: 0 5/12/2005 7:09:40 AM: 0 5/12/2005 7:09:40 AM: 0 5/12/2005 7:09:40 AM: 0 5/12/2005 7:09:40 AM: 0 5/12/2005 7:09:40 AM: 0 5/12/2005 7:09:40 AM: 0 5/12/2005 7:09:41 AM: 0 5/12/2005 7:09:41 AM: Queued: "exit" 5/12/2005 7:09:41 AM: 0 5/12/2005 7:09:41 AM: Queued: 5/12/2005 7:09:41 AM: 0 5/12/2005 7:09:42 AM: 0 5/12/2005 7:09:42 AM: 0 5/12/2005 7:09:42 AM: 0 5/12/2005 7:09:42 AM: 0 5/12/2005 7:09:42 AM: 0 5/12/2005 7:09:42 AM: 0 5/12/2005 7:09:42 AM: 1 5/12/2005 7:09:42 AM: 0 5/12/2005 7:09:42 AM: 1 5/12/2005 7:09:42 AM: 0 5/12/2005 7:09:42 AM: 0 5/12/2005 7:09:42 AM: 0 5/12/2005 7:09:42 AM: 0 5/12/2005 7:09:42 AM: 0 5/12/2005 7:09:42 AM: 0 5/12/2005 7:09:43 AM: 1 5/12/2005 7:09:43 AM: 0 5/12/2005 7:09:43 AM: 0 5/12/2005 7:09:43 AM: 0 5/12/2005 7:09:43 AM: 0 5/12/2005 7:09:43 AM: 0 5/12/2005 7:09:43 AM: 0 5/12/2005 7:09:43 AM: Executing: exit 5/12/2005 7:09:43 AM: 0 5/12/2005 7:09:43 AM: 0 5/12/2005 7:09:43 AM: 0 5/12/2005 7:09:43 AM: 0 5/12/2005 7:09:43 AM: 0 5/12/2005 7:09:43 AM: 0 5/12/2005 7:09:43 AM: 0 5/12/2005 7:09:43 AM: Queued: 5/12/2005 7:09:44 AM: Winamp window not found. 5/12/2005 7:09:44 AM: Shutdown
This is what I did in sequence
-Run RR, and main menu load up with skin created by kuo.
-Push GPS button and select Destinator.
-Destinator skin load, MM run and embeded.
-Push the BACK/Exit button to go back to RR Main menu.
-Push skin browser button and select Brush Metal one from your site.
-RR shutdown.
This is from my desktop, but the problem also happen on my 2 carPC as well regardless of skins. My 2 carPCs has the same directory structures (Winamp, Destinator, RR, Music, Video) as my desktop.
guino if I am the only one who has this bug/problem, don't but too much your time into it. Spend your time on some thing else that satified more folks. When I have time I will look into this to see why. In the mean time, I just use Freedrive instead
Old 05-12-2005, 11:07 AM   #6
guino's CarPC Specs
guino's Avatar
My Photos: (5)
I'll try it with the kuo skin -- but it sounds like a skin issue at first.. as far as I know there's an "exit" command there being inpropperly executed ... the "SELECT" command in the skin browser should not be queueing that..
EDIT: Think I found and fixed the issue here..
Sponsored Links
Search this Thread:
Advanced Search
Trackbacks are Off
Flash RR Skin Beta Release CdRsKuLL RR Skins 44 01-15-2006 07:48 PM
Honda skin that released with RR 93blacksrv RR Bug Tracker 1 04-08-2005 02:37 PM
ATX shutdown controller kit / assembled for sale Mastero Classified Archive 22 01-27-2004 01:33 PM
finnaly skin uploaded liquid_smoke ME Archive 5 12-31-2003 09:13 PM
ATX power switch mtmsol Power Supplies 5 05-13-2001 12:22 PM
Sponsored Links
Ad Management by RedTyger
