Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR FAQ
Old 07-20-2008, 08:35 PM   #16
rijndael's Avatar
rijndael is an unknown quantity at this point
so i guess it is safe to say now that Garmin Mobile PC is now fully embedded into Road Runner?
Trouble deciding on car speakers? Clicky Clicky
My Myspace page (view my pics for carputer worklog...needs updated)
Speakers: DLS Ultimate Iridium 6.3 Link
Subwoofer: removed
Amplifier#1 (Front Stage): DLS Ultimate A4
Amplifier#2 (Sub) removed
rijndael is offline   Reply With Quote
Old 07-21-2008, 08:35 AM   #17
jonessc's Avatar
jonessc is an unknown quantity at this point
As far as i'm aware it's fine, they just need an osk
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
jonessc is offline   Reply With Quote
Old 08-05-2008, 12:08 PM   #18
rev1richie is an unknown quantity at this point
I've searched and searched, and tried all the combinations, but i just Cant get sygic to work from Road Runner....
any help from any one would be appreciated
Thx
ric
rev1richie is offline   Reply With Quote
Old 08-06-2008, 05:13 PM   #19
jonessc's Avatar
Thx
ric
Code:
Embedding Details: GPS Path=C:\DRIVE_XP\drive.exe |-no-safety -r800x530 GPS Window Name= Sygic DRIVE
Change the part in bold to the resolution that best fits the window of your skin...
CarPuter Progress:
Old 08-06-2008, 05:22 PM   #20
Sorry, but i cant get it to work at all, i'm at the end of my teather and am considering a different FE...
Ric
Old 08-06-2008, 07:55 PM   #21
jonessc's Avatar
What is there is correct, but what version of sygic drive are you using?
What skin are you using?
As long as you have entered the gps and path correct it will work, thats exactly what i use on mine.
CarPuter Progress:
Old 08-07-2008, 04:51 AM   #22
Looks like its the skin thats stopping it, i was using "simplistique" skin, when i went back to the default bmv2, it worked like you said it would, apologese..
Regards
Ric
Old 08-11-2008, 08:08 AM   #23
k1hog's Avatar
k1hog is an unknown quantity at this point
Can someone provide the info for Co Pilot, a good program for RV'ers.
Johnnie
k1hog is offline   Reply With Quote
Old 09-13-2008, 01:55 AM   #24
tempgp's Avatar
tempgp is on a distinguished road
Angry
need help with mappoint 06
i just installed RR and using default skin w/ GPS windo name set to mappoint.
When I click on gps button nothing happens however mappoint does start as eternal gps if i select external options...
does any one know why map point doesnt want to load w/ the skin?
tnx!
tempgp is offline   Reply With Quote
Old 09-17-2008, 04:57 PM   #25
Jammerlabz is an unknown quantity at this point
Okay I found my navigator6.... and did what you said... and it opens... but it takes over the screen... either that or arent squized into the skin...
Jammerlabz is offline   Reply With Quote
Old 10-25-2008, 11:08 AM   #26
snoopbiscuit is an unknown quantity at this point
I'm having the same issues... None of the buttons work, and Mappoint just runs normally like it would in windows. I'm using Mappoint 06 on XP btw
snoopbiscuit is offline   Reply With Quote
Old 10-30-2008, 06:05 PM   #27
jonessc's Avatar
Version 6 of PC Navigator does not support any window re-sizing, it is designed to run stand alone only. When Navigator 7 was released, a patch was released (following forum members requesting it, if I do recall) to allow the window to be re-sized correctly by RR.
Have never used map point I'm afraid. I would advise you to search for a program called Win Spector, which will allow you to get the program info to allow it to be embedded into RR correctly.
These are the details other members are using, unless I typed them in wrong, can anyone else confirm these settings are ok with Map Point?
MapPoint
Product Home Page:
http://www.microsoft.com/mappoint/pr...6/default.mspx
Embedding Details:
GPS Path:C:\Program Files\Microsoft Mappoint\Mappoint.exe
GPS Window Name: Mappoint
CarPuter Progress:
Old 11-01-2008, 11:09 PM   #28
phanaka is an unknown quantity at this point
hi all....
1. i tried GARMIN setting (DFX4, mode "MENU", path:c\garminmobilepc\que.exe, gps name:GARMIN MOBILE PC), did'nt launch GARMIN apps (just RR background). When i run RR Garmin (overlay skin version) first, then press GARMIN (DFX4), thats all work....
need help, why i can't launch GARMIN by RR config?
2. how to set "GAUGES" (satellites, speed, compass) to make full functioning for GARMIN?
phanaka
ROADRUNNER....HARD begin,COOL end
phanaka is offline   Reply With Quote
Old 11-12-2008, 04:41 AM   #29
the_gooner is an unknown quantity at this point
MapPoint 2009 Europe edition
Gps path : - X:\Program Files\Microsoft MapPoint Europe 2009\MapPoint.exe
Gps Windows Name - Map - Microsoft MapPoint Europe
Change the X to your drive
Not sure how the us version works, but the euro one opens in another window then loads into RR as well
Prob 60% complete
the_gooner is offline   Reply With Quote
Old 11-12-2008, 03:46 PM   #30
jonessc's Avatar
Post #1 Updated
CarPuter Progress:
How to make the Garmin GPS 35 Work with Copilot 2003 fluffy2097 GPS 16 09-05-2007 05:19 PM
Getting Started with GPS grepzen The FAQ Emporium 12 09-26-2006 06:54 AM
How to put GPS on personal organizer? A cry out for sticky! Ladzio GPS 4 04-29-2005 05:16 PM
The Ultimate GPS Test ( Lake District ) Jamez_Warner Off Topic 41 04-28-2004 04:45 AM
How could I make the ultimate car PC powersupply and what should it do? kiddigital Power Supplies 12 12-04-2001 07:36 PM
