12-10-2008, 07:00 AM
#32
Hi all, how about iGo 8 ?? how can i embedd it to road runner ?? does anyone know? It seems i'm not beeing able to do that, and when it runs if i want to return to road runner it automatically pops up again (iGo)over any menus i'm on. Any ideas?
Regards,
Ricardo.
12-11-2008, 08:15 AM
#33
Hi, thanx for all that info but i'm having a problem with iGo8, not embedding but making him stay in the background when i wish to return to the FE menu... It keeps poping up the GPS image over the Roadrunner menus (even if i change skins )!! Could someone help me with that??
Regards,
Ricardo
12-11-2008, 05:23 PM
#34
Raw Wave
Regards,
Ricardo
Post your button command.
12-11-2008, 05:38 PM
#35
My button command?? do you mean the GPS Path and GPS window namein RR config?
Path: C:\IGO8_PC_30-09-2008\igostarter.exe
Hope that's what you need...
Thx for the help treetop777,
Regards
12-11-2008, 06:05 PM
#36
Raw Wave
Regards
Try changing the window name to "IGO8" (without quotes)
12-11-2008, 06:42 PM
#37
No luck on that.. still pops up when i try to go back on RR menus ! Any other suggestions treetop777?
And by the way, ty for the quick replys
12-11-2008, 07:13 PM
#38
Snooping around skin files i found this on ExecTBL.ini :
/IG2 START
/IG2.1
/path to GPS............................................... .......{ path to your gps application }{ window title}
"GPS1","GPS||RUN;LSTOOLS\SB2.9\iGuidance\IGCONTROL .exe"
/....................-path to GPS and EXITFS utility..........{ path to your gps application }{window title}
"GPSFS1","LOAD;EXTERNAL_GPS_FS.skin;RUN;;iGuidance ||RUN;LSTOOLS\SCRIPTS\EXIT_FS.exe"
/this command is used only on External_GPS.skin, close button on bottom left
/"EXIT2","RUN;LSTOOLS\SB2.9\iGuidance\kill.exe||EXI T"
/"LASTSCR2","RUN;LSTOOLS\SB2.9\iGuidance\kill.exe|| LASTSCR"
"IG2MENU","RUN;LSTOOLS\SCRIPTS\torch.exe"
Could this be the problem?? If so how can i change this in order to make the GPS stops popping?
Thx,
Ricardo
12-11-2008, 07:28 PM
#39
Raw Wave
Yeah, LSX Void doesn't lend itself to chages very easily and those commands are intended for Iguidance.
Check PM and report back
12-12-2008, 06:08 AM
#40
THE EXPERIMENTER
try GPS as the launch button cmd on main menu or where your gps launch button is.
B,xx,xx,xx,xx,"GPS"
02-03-2009, 10:28 PM
#41
I have been trying OnCourse Navigator 8 for a couple of weeks on my HTC Touch Pro.
I REALLY like it so far.
Here is a review of the software:
http://www.pocketpcthoughts.com/news/show/91282/0/1/5
It is pocketPC software, but is there ANY chance of being able to embed this?
Ron
02-04-2009, 08:41 AM
#42
RoadRunner Mastermind
OnCourseNavigator 8 = iGo8 -- there's a PC version you can use with RR:
You need to search for igo8 mysize -- http://code.google.com/p/igo-mysize/ you'll find the tool to allow you to resize the software so it embeds in the space you want.
Ride Runner RR's Myspace
02-04-2009, 06:56 PM
#43
Well, thank you!
I am trying to figure it out now.
Ron
06-01-2009, 04:11 AM
#44
Navitel Navigation and RR
Any help to make Navitel navigation (Win CE emulation) and RR front end work together ?
I have tried this in a Run.bat :
"D:\!!_Soft_!!\PC_Car\GPS Soft\Navitel\11\Navitel\Emulator\DeviceEmulator.ex e" C:\Navitel\WinCE50core_FULL2.bin /tooltips OFF /memsize 256 /nosecurityprompt /video 640x350x16 /sharedfolder "C:\Navitel\"
Using this button code:
"LOAD;gisrx.SKIN;device emulator;C:\navitel\run.bat;device emulator"
RUSSIA - WINER!!!
06-02-2009, 03:06 PM
#45
1-If you run the run.bat command (outside RR) -- does it work ?
2-If it works, post a screen shot of the window... you may just be using the wrong window title to embed it.
3-When you try it INSIDE RR, do you see the emulator loading ?
| Thread Tools |
| Display Modes |
Linear Mode
