Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR FAQ
Old 04-15-2009, 10:35 AM   #1
Sal R.'s Avatar
Sal R. is an unknown quantity at this point
FAQ Guide to using RR v4-1-09 NEW HORM features for EWF Systems
Requirements:
- EWF setup and enabled
- RR v4-1-09 and Winamp must be installed on the EWF protected drive (installing on a unprotected drive will cause corruption errors)
- USB flash drive (USB external harddrives won't work)
1: Check to make sure you have the following settings in rr.ini:
hibernateaware=true
hormdrive=x (where x is the drive letter of your connected usb flash/thumb drive without the ":\"; i.e. e, f, g, etc.)
2: Connect usb drive
3: Start RR
4: Clear Winamp Playlist
5: Make sure you have all your required programs running or not running (i.e xport, gpsexec.exe, iGuidance, etc.)
6: Hibernate thru RR
You have now set your HORM point.
After you resume and add your playlist, listen to radio, whatever, it is IMPORTANT to shutdown the system. Shutting down SAVES your resume information to the USB drive to be used on your next powerup/resume.
If you've setup your EWF system correctly, even after shutting down your sytems will result in your system resuming everytime.
If you find that you are not resuming the last playback position, adjust the following rr.ini setting:
resumedelay=x (where x is in seconds)
(this allows TIME for the USB drive to reconnect to the system)
and repeat the steps above.
Simple.
Big thanks mitch for his hard work on getting this feature working correctly.
ALSO, look at DEBUG.txt, there is alot of HORM info there
Pico-ITX / nLite'd XP Pro with EWF-HORM / RR v9/22/2009 / Winamp v5.13 / RRMedia v1.2.2
Sal R. is offline   Reply With Quote
Advertisement Sponsored links
Old 04-15-2009, 12:32 PM   #2
Raw Wave
mitchjs is on a distinguished road
TY for the Mini-Guide!
Oh, if you use RRCONFIG to set your HORM save Drive, make sure you have it plugged in before u start RRCONFIG
it will see that a USB Removable drive is present, and offer that choice for HORMDRIVE
-Thanks
Mitch
www.rush2112.net
Spread before you is your soul
So forever hold the dreams
within our hearts
Through nature's inflexible grace
I'm learning to live
mitchjs is offline   Reply With Quote
Old 04-15-2009, 12:53 PM   #3
Sal R.'s Avatar
Good to know.
Old 04-16-2009, 03:01 PM   #4
mstaedt's Avatar
mstaedt is an unknown quantity at this point
Is EWF-HORM only available on XPe? Or can it also be enabled on XP Home?
Thanks....
Mark
Project completed! (almost)
My Truck as featured in Custom Classic Trucks magazine.
mstaedt is offline   Reply With Quote
Old 04-16-2009, 03:08 PM   #5
Sal R.'s Avatar
Thanks....
Mark
Theres a tutorial under Optimization forum that can take some of the features of XPe and apply them to XP Home. Namely, EWF.
Old 04-21-2009, 10:41 PM   #6
Maheriano will become famous soon enoughMaheriano will become famous soon enough
Shouldn't a guide for setting something up explain what it is?
Ampie Case
256 MB DDR2 PC5400
Xenarc 700TSV - VGA Monitor
Intel D945GCLF Motherboard
M2-ATX-HV
2005 Honda Civic
Maheriano is offline   Reply With Quote
Old 04-21-2009, 11:29 PM   #7
Sal R.'s Avatar
Already of plenty of info in the archives that explains the nitty gritty of HORM & EWF.
Besides, to utilize the info posted above, the user should already know about the topic at hand before attempting to use the new HORM features of RR.
Old 04-21-2009, 11:41 PM   #8
The Curator
Blue ZX3's Avatar
Blue ZX3 will become famous soon enoughBlue ZX3 will become famous soon enough
And if one has to ask what is HORM OR EWF then they need to research lots before even asking any Q's.
RR Media >>HERE <<
RRExtended Plugin
Updated RR Config (Current Ver 1.0.2.0)
Old RR Versions
Complete CFX PSD Set
RRSkinEditor v.76c
DFX Btn Editor
Blue ZX3 is offline   Reply With Quote
Old 04-27-2009, 09:51 AM   #9
LYHTSPD is on a distinguished road
So the only thing the usb drive is used for is to store the resume data, correct?
LYHTSPD is offline   Reply With Quote
Old 04-27-2009, 10:03 AM   #10
Raw Wave
yes... im sure it can be used for other stuff too
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 04-27-2009, 11:57 AM   #11
Well, I am going to run my OS on an 8GB CF card, so I won't need anything big. I have a 256mb usb stick just laying around I can use.
Old 04-27-2009, 01:42 PM   #12
CoryF is an unknown quantity at this point
Can the "USB Drive" be an un-protected partition on the protected drive? Or do I have to use a USB?
-CoryF
2001 Camaro SS #2070
CoryF is offline   Reply With Quote
Old 04-27-2009, 02:19 PM   #13
Raw Wave
NOPE, HAS TO BE A USB DRIVE!
unprotected drives, while unprotected, are still cached in the hibernation file
the whole EWF is a hack by microsoft...
im sure it will be better on next embedded os
-Thanks
Mitch
www.rush2112.net
within our hearts
Old 04-27-2009, 02:32 PM   #14
The Curator
Blue ZX3's Avatar
Well, my interpretation of embedded is not quite the same as running xp with ewf/horm. In an embedded system you usually have the "image" written in a ROM type memory and any thing that would change would be written to ram. So its like comparing apples to oranges...
Makes sence in my head, but probably not here..hehe
RR Media >>HERE <<
RRExtended Plugin
Old RR Versions
RRSkinEditor v.76c
DFX Btn Editor
Old 04-29-2009, 12:53 PM   #15
bambam's Avatar
bambam is on a distinguished road
Quote: Originally Posted by Sal R. View Post
Requirements:
- USB flash drive (USB external harddrives won't work).....
Which USB flash drive is most recommended by those who have done this?
"Imagination is more important than knowledge." -AE
bambam is offline   Reply With Quote
Looking for a good base guide to using Flash in RR Splash-X RR Skins 3 12-11-2007 06:07 PM
Indexing music in 1.0.9.8 Failed hovalistic StreetDeck 0 07-07-2007 12:19 PM
Is there a guide to getting voice recognition in RR? vettejock99 Road Runner 10 12-26-2006 05:47 PM
How do I integrate my application with RR ? guino RR FAQ 0 09-23-2006 09:38 PM
status update.... 0l33l PowerVoice 17 05-05-2005 01:22 PM
