Go Back   MP3Car.com > Mp3Car Technical > Software & Software Development > Front Ends > Road Runner > RR FAQ
Closed Thread
Old 03-21-2005, 03:42 AM   #1
RoadRunner Mastermind
guino's Avatar
guino will become famous soon enoughguino will become famous soon enough
FAQ How do I setup TV / Camera Support ?
Requirements
-WDM Compatible TV Tuner or Camera
-Winamp TV plugin (You can get it HERE)
To set up a TV Tuner in RR
-Install the TV plugin
-Get a skin with TV support -- The Brushed skins for instance
-Run winamp (Alone -- outside RR)
-Press "configure" on the TV input plugin
-Tell it to use "Thin Frame"
-Tell it where to save presets and do a quick scan
-Go in RRconfig and set the location of your TV presets, when RR starts the TV, it will load them up as channels and show you the TV feed. You CAN rename those files to display the channel names in the TV screen (if you wish to).
To setup a WDM Camera (No Tuner)
When setting up a simple WebCam (no Tuner) you may get some errors because the plugin tries to find the tuner and rendering options. Simply ignore any error messages and do this:
-Change the Input Pin to "Preview"
-Select Output Frame as "Thin Frame"
-Try marking the Use Video Mixing Renderer 9 (optional)
-Click "Add manually" and add a "channel" to the input source of your camera -This is the file RR will load to show you the Camera view.
-Go in RRconfig and set the location of your Camera preset, when RR starts the TV screen, it will load it up as a channel and show you the Camera feed.
Note: It is STRONGLY recommended that you save your presets in a folder that ONLY cointains TV/Camera Presets and has NO subfolders.
Note: If your soundcard does not support/allow you to hear the Audio Input line automatically by UnMuting the Audio line:
-Check the "Use Line In Plugin" Option in RRConfig
-Download and install the LINE-IN plugin for winamp:
http://www.winamp.com/plugins/details.php?id=84040
-PLEASE: Read the documentation of the plugin for information on using other input lines (Aux/Mic etc) -- Basically you have to select which input line to record from using the Windows Mixer.
Ride Runner RR's Myspace
guino is online now
Advertisement Sponsored links
Closed Thread
7" screen, which mobo/gfx to buy for 16:9 TV out? Vittel LCD/Display 12 08-08-2003 01:15 PM
Epia 9000 Problem w/ TV Out blazinlow General Hardware Discussion 1 03-05-2003 12:15 PM
FS. VGA to TV (composite and s-VHS) converters. Casper Classified Archive 0 08-13-2002 05:33 PM
VGA to TV converters anyone? Casper LCD/Display 1 08-12-2002 07:03 PM
tv out allways that bad ? gerard LCD/Display 7 06-17-2001 10:54 PM
