Quote: Originally Posted by kolemieux
Kill me for the stupid question - I've done a lot of work with RR but am finally getting around to posting on some of my ?-s. I try to search hard before asking stupid stuff at all costs.
1 - Have you managed to fully seamlessly integrate this with transit controls and such - I've not had much luck but looks like you've nailed it.
2 - Can you tell me if you (or anyone) has the command syntax or process that I would use to automount with Daemon Tools the ISO and then play automatically in the following player or MPC.
Thanks so much for any guidance, and I will search more as well.
Guino>
A's & about PowerDVD and WinDVD
In case others have the same questions:
-MPC is used by RR when you set the DVD player to INTERNAL in RRConfig. RR will then use the SAME video controls to control MPC for DVD playback as it does for VIDEOS.
-There's nothing you need to do in order to make this work. Just make sure MPC's path is specified in RRConfig and that you have the DVD player set to Internal.
There's also a direct "control" interface for PowerDVD and WinDVD:
Change the button code on menu.skin from "DVD" to either:
"LOAD;PowerDVD_Player.skin"
or
"LOAD;WinDVD_Player.skin"
then set the player in RRConfig to EXTERNAL and set the
path and window title of the DVD application you're using. Note that so far I only know the brushed skins to have the above skin files required for this interface to work.
