Go Back   MP3Car.com > Mp3Car Technical Software > Front Ends > Road Runner > RR Plugins > RR Plugins No Longer Supported
Closed Thread
Old 07-05-2008, 04:41 PM   #1
ivanmx6's Avatar
ivanmx6 is an unknown quantity at this point
Stopwatch / lap timer
Has anyone released a pluging which, with a touch of the screen would allow lap times to be captured, stopwatch wise?
I've had a browse but can't find anything.
Thanks,
ivanmx6 is offline
Old 07-05-2008, 05:18 PM   #2
Confusion Master
Enforcer's Avatar
Enforcer has a reputation beyond reputeEnforcer has a reputation beyond reputeEnforcer has a reputation beyond reputeEnforcer has a reputation beyond reputeEnforcer has a reputation beyond reputeEnforcer has a reputation beyond reputeEnforcer has a reputation beyond reputeEnforcer has a reputation beyond reputeEnforcer has a reputation beyond reputeEnforcer has a reputation beyond reputeEnforcer has a reputation beyond repute
if there isn't, it should be very easy to do.
If you want to mock up a rough idea of what you want on the screen I can have a look at doing something.
Enforcer is online now
Old 07-05-2008, 06:21 PM   #3
ivanmx6's Avatar
That'd be great if you could, thanks.
It's for a mate who does a fair bit of track driving at Silverstone.
I gave him a basic large readout speedo based on a clear BMV2 background. All it does is display the GPSSPD label so isn't at all sophisticated.
Wouldn't it be nice if there was a reset-able TIMER label?
Something like this below would do the trick. At top is the GPSSPD label and "mph" text.
With a button bottom right to start and stop the timer, and timer readout to the left of that.
ivanmx6 is offline
Old 07-05-2008, 10:40 PM   #4
Confusion Master
Enforcer's Avatar
Ok give this a go, the timer might be a bit clunky, but the end time and lap time should be fairly accurate.
bear in mind this is my first RR extension plugin, normally I just do programs that can be embedded.
Version 1 - very much a beta nae alpha
Extract zip to RoadRunner folder
run register.bat
read the instructions in RRStopWatch.txt for label and button info
Run RR
Good Luck
Enforcer
*edit known bug, it keeps counting the secs to 99 not 59
Old 07-06-2008, 05:30 AM   #5
ivanmx6's Avatar
Blimey, that was quick.
I'll give it a go and get back to you.
ivanmx6 is offline
Old 07-06-2008, 09:28 AM   #6
MGD
MGD's Avatar
MGD is on a distinguished road
Here is a little flash timer I made for my skin. Only three functions. START, STOP and RESET.
Start command is "SETFLASHVAR;TIMER;1"
Stop Command is "SETFLASHVAR;TIMER;2"
Reset Command is "SETFLASHVAR;TIMER;3"
Right Click and Save Target As
MGD is offline
Old 07-06-2008, 10:15 AM   #7
ivanmx6's Avatar
Enforcer, you sir are a genius. It works a treat.
I shall be installing it on my pals PC as soon as possible.
ivanmx6 is offline
Old 07-06-2008, 10:27 AM   #8
Confusion Master
Enforcer's Avatar
Before you install I need to adjust the formating, as at the moment it (as I said earlier) it counts to 99 seconds not 59 before adding to the minutes.
*edit, just thought, hitting Start after a Stop shouldn't reset the counter.
Will do the corrections tonight.
Glad you like it.
Old 07-06-2008, 10:44 AM   #9
ivanmx6's Avatar
Looking forward to it.
You know, it's times like this make me think of ditching CF and switching to RR myself.
The only thing that turned me away in the first place was MapMonkey, and now there are so many more Nav progs to choose from...
ivanmx6 is offline
Old 07-06-2008, 05:55 PM   #10
Confusion Master
Enforcer's Avatar
Ok version 1.1
Changelog
Version 1.1
corrected seconds counting to 99 rather than 59
changed start/stop so that on restart it continues counting from where it left off.
Version 1.0
the original
Unzip over the old one.
Notice, this versionis fine for countries that use a '.' as a decimal point, for european countries that use a ',' please look further in the thread for version 1.4
Old 07-07-2008, 03:45 AM   #11
ivanmx6's Avatar
Nice one, thanks again.
ivanmx6 is offline
Old 07-08-2008, 11:34 AM   #12
ivanmx6's Avatar
Installed this today on my pals carPC and he's over the moon.
Cheers Enforcer.
ivanmx6 is offline
Old 07-08-2008, 01:42 PM   #13
Confusion Master
Enforcer's Avatar
No probs.
It was good practice with the RR extension plugin
If he wants anything else added to it, just let me know.
Old 07-09-2008, 04:55 PM   #14
xpluis's Avatar
xpluis is an unknown quantity at this point
Quote: Originally Posted by Enforcer View Post
No probs.
Is posible start the time when velocity start, and finish the timer when are in 100kph ?
it could be exelent for 0-100kph test.
maybe you can start the timer when gps indicate 4kph, and finish when indicate 100kph.
i have speed race car, and maybe is not very exactly but could be very nice and for a testing purposes.
xpluis is offline
Old 07-09-2008, 05:38 PM   #15
Confusion Master
Enforcer's Avatar
Well I can simply add a request to RR for GPS speed and work off that, but to be honest a button to start the counter would be better and then it could stop when a set speed, 100KPh or 60MPh is attained.
Closed Thread
12 Volt Timer For Computer kozmo Power Supplies 20 02-18-2007 10:02 AM
555 Timer Problem.. Need it To Trigger when key removed fire Power Supplies 19 07-27-2006 03:44 AM
VB6 Crew, Timer Control Question kamikaze2112 Coders Corner 3 04-09-2006 06:23 PM
Timer Circuit Fox_Mulder General Hardware Discussion 3 11-04-2005 09:47 AM
Racers Lap Timer eastcoastbumps Hardware Development 2 09-08-2005 12:35 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
